457170120310
457170120310
    FINDER
    FINDER - 457170120310 - Power Relay, SPST-NO, 12 VDC, 16 A, 45 Series, PCB
457170120310 数据手册
45 SЕRIES Miniature PCB Relays 10 - 16 A Burners, boilers and furnaces Film projectors Infrared and microwave ovens Jacuzzis and hot tubs Electronic circuit boards FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 45 SERIES Miniature PCB relays 10 - 16 A 45 SERIES 45.31…x310 Relay for +105 °C ambient use PCB mount - high contact gap - 45.31…x310, 1 Pole normally open (≥ 3 mm contact gap) 45.31…0610 A - 45.31…0610, 1 Pole normally open (≥ 3.6 mm contact gap) • Contact gap ≥ 3 mm or ≥ 3.6 mm according to EN 60730-1 • Sensitive DC coil - 360 mW (45.31…x310 type) • Cadmium Free contact material • Reinforced insulation between coil and • 1 NO (SPST-NO), contacts according to EN 60335-1, EN 50178, EN 60204 with safe separation and 8 mm clearance and creepage distance • 6 kV (1.2/50 µs) isolation, coil-contacts • Flux proof: RT II • 1 NO (SPST-NO), ≥ 3 mm gap • Max ambient temperature +105 °C • PCB mounting ≥ 3.6 mm gap • Max ambient temperature +105 °C • PCB mounting 45.31…x310 (1 NO/SPST-NO) 45.31…0610 (1 NO/SPST-NO) Copper side view Copper side view 1NO (SPST-NO) ≥ 3 mm gap 1NO (SPST-NO) ≥ 3.6 mm gap 16/30 10/30 For outline drawing see page 7 For UL ratings see: “General technical information” page V Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A 250/400 500/500 Rated load AC1 VA 4000 5000 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW 0.55 0.55 Breaking capacity DC1: 30/110/220 V A 16/4/1 10/4/1 500 (10/5) 500 (10/5) AgNi AgNi Minimum switching load V AC mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC Operating range VA (50 Hz)/W — — 6 - 12 - 24 - 48 - 60 6 - 12 - 24 - 48 - 60 —/0.36 —/0.55 AC — — DC (0.7…1.2)UN (0.8…1.2)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life AC/DC cycles —/10 · 106 —/2 · 106 Electrical life at rated load AC1 cycles 30 · 10 10 · 103 ms 12/2 12/2 kV 6 (8 mm) 6 (8 mm) Technical data XII-2018, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C 3 2500 3000 –40…+105 –40…+105 RT II RT II Approvals (according to type) 3 45 SERIES 45.71 Relays for +125 °C ambient use PCB mount - Faston 250 contact connections - 45.71, 1 Pole normally open or normally closed - 45.91, 1 Pole normally open (≥ 3 mm contact gap) 45.91 • Contact gap ≥ 3 mm according to EN 60730-1 (45.91 type) • Sensitive DC coil - 360 mW • Cadmium Free option available • Reinforced insulation between coil and • 1 NO or 1 NC contacts according to EN 60335-1, EN 50178, EN 60204 with safe separation and 8 mm clearance and creepage distance • 6 kV (1.2/50 µs) isolation, coil-contacts • Flux proof: RT II standard, (RT III option) • 1 NO (SPST-NO), (SPST-NO or SPST-NC) • Max ambient temperature +125 °C • PCB mounting + Faston 250 ≥ 3 mm gap • Max ambient temperature +125 °C • PCB mounting + Faston 250 45.71…0310 (1 NO)/(SPST-NO) 45.91…0310 (1 NO/SPST-NO) 45.71…0410 (1 NC)/(SPST-NC) For outline drawing see page 7 For UL ratings see: “General technical information” page V Copper side view Copper side view 1NO or 1NC (SPST-NO or SPST-NC) 1NO (SPST-NO) ≥ 3 mm gap 16/30 16/30 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A 250/400 250/400 Rated load AC1 VA 4000 4000 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW 0.55 0.55 Breaking capacity DC1: 30/110/220 V A 16/0.3/0.13 16/4/1 mW (V/mA) 500 (10/5) 500 (10/5) AgCdO AgNi Minimum switching load V AC Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC Operating range VA (50 Hz)/W — — 6 - 12 - 24 - 48 - 60 6 - 12 - 24 - 48 - 60 —/0.36 —/0.36 AC — — DC (0.7…1.2)UN (0.7…1.2)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life AC/DC cycles —/10 · 106 —/10 · 106 Electrical life at rated load AC1 cycles 100 · 10 30 · 103 ms 10/2 12/2 kV 6 (8 mm) 6 (8 mm) Technical data Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) 4 V AC °C 3 1000 2500 –40…+125 –40…+125 RT II RT II XII-2018, www.findernet.com A 45 SERIES Miniature PCB relays 16 A 45 SERIES Miniature PCB relays 10 - 16 A 45 SERIES Ordering information Example: 4  5 series for PCB relay + Faston 250, 1 NO (SPST-NO), 12 V DC coil. 4 5 . 7 A B C D 1 . 7 . 0 1 2 . 0 3 1 0 Series A: Contact material 0 = S tandard AgCdO for 45.71, Standard AgNi for 45.31 and 45.91 1 = AgNi 2 = AgCdO Type 3 = PCB mount, ≥ 3 mm or ≥ 3.6 mm contact gap 7 = PCB + Faston 250 mount 9 = PCB + Faston 250 mount, ≥ 3 mm No. of poles 1 = 1 pole, 16 A A D: Special versions 0 = Flux proof (RT II) 1 = Wash tight (RT III) 45.71 and 45.91 only C: Options 1 = None B: Contact circuit 3 = NO (SPST) 4 = NC (SPST) 45.71 only 6 = NO (SPST), ≥ 3.6 mm Coil version 7 = Sensitive DC 9 = Standard DC (45.31…0610 only) Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Type 45.31 Coil version A B C D sensitive DC 0-2 3 1 0 standard DC 0 6 1 0 45.71 sensitive DC 0-1 3-4 1 0-1 45.91 sensitive DC 0-2 3 1 0-1 Technical data Insulation according to EN 61810-1 45.71 Nominal voltage of supply system V AC 230/400 45.31 / 45.91 230/400 Rated insulation voltageV AC 250 400 250 400 Pollution degree 2 3 2 3 Insulation between coil and contact set Type of insulation Reinforced (8 mm) Reinforced (8 mm) III III kV (1.2/50 µs) 6 6 Overvoltage category Rated impulse voltage Dielectric strength V AC 4000 4000 Insulation between open contacts Type of disconnection Micro-disconnection Full-disconnection — III kV (1.2/50 µs) — 4 Overvoltage category Rated impulse voltage Dielectric strength V AC/kV (1.2/50 µs) 1000/1.5 2500/4 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 2 Other data 45.71 XII-2018, www.findernet.com Bounce time: NO/NC ms 3/3 Vibration resistance (10…150)Hz: NO/NC g 20/10 Shock resistance g 20 Power lost to the environment without contact current with rated current Recommended distance between relays mounted on PCB 45.31 / 45.91 2/— 20/— W 0.4 W 1.8 mm ≥ 5 5 45 SERIES Miniature PCB relays 10 - 16 A 45 SERIES Contact specification F 45 - Electrical life (AC) v contact current Type 45.31/45.91 Resistive load - cosφ = 1 Cycles Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 H 45 - Maximum DC1 breaking capacity • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 cycles (45.71) and ≥ 30 · 103 cycles (45.31, 45.91) can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. DC breaking current (A) DC voltage (V) Coil specifications DC coil data - 0.36 W sensitive Nominal voltage Coil code UN V DC coil data - 0.55 W standard Operating range Resistance Rated coil consumption Nominal voltage I at UN UN Coil code Operating range Umin Umax R V V Ω mA V 60 6 9.006 4.2 7.2 8.4 6 7.006 4.2 7.2 100 12 7.012 8.4 14.4 400 30 12 9.012 24 7.024 16.8 28.8 1600 15 24 9.024 48 7.048 33.6 57.6 6400 7.5 48 60 7.060 42 72 6 60 10000 Resistance Rated coil consumption I at UN Umin Umax R V V Ω mA 72 83 14.4 300 40 16.8 28.8 1150 21 9.048 33.6 57.6 4400 11 9.060 42 72 7200 8.3 R 45 - DC coil operating range v ambient temperature limit for 45.31 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 6 XII-2018, www.findernet.com A F 45 - Electrical life (AC) v contact current Type 45.71 45 SERIES Miniature PCB relays 10 - 16 A 45 SERIES Outline drawings Type 45.31 Types 45.71/91 XII-2018, www.findernet.com A Please see general technical information 7
457170120310 价格&库存
很抱歉,暂时无法提供与“457170120310”相匹配的价格&库存,您可以联系我们找货
