48.31.8.120.0060SPA
48.31.8.120.0060SPA
    FINDER
    通用 继电器 SPDT(1 Form C) 120VAC 线圈 DIN 轨道
48.31.8.120.0060SPA 数据手册
48 SЕRIES Relay Interface Modules 8 - 10 -16 A Control panels Carousel warehouses Medical and dentistry Shipyards Elevators and liſts Panels for electrical distribution Building automation Hoists and cranes FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 48 48 SERIES Relay interface modules 8 A SERIES 48.12 / 48.P2 2 CO relay interface modules, 15.8 mm wide 48.32 Type 48.12 and 48.P2 Ideal for safety applications - 2 CO 8 A - Relay with forcibly guided contacts according to EN 61810-3 Type B (previously EN 50205) Type 48.32 Ideal for energy applications - 2 CO 8 A - Breaking capacity DC inductive (L/R=40 ms) - 110 V = 0.5 A - 220 V = 0.2 A - Screw terminals B • 2 CO 8 A • Push-in or screw terminals • 2 CO 8 A • Screw terminals • DC coils • Identification label • UL Listing (certain relay / socket combinations) • 35 mm rail (EN 60715) mounting • Cadmium-free contact material 48.12/32 Screw terminal 48.P2 Push-in terminal According to EN 61810-3 only 1 NO and 1 NC (11-14 and 21-22 or 11-12 and 21-24) shall be used as forcibly guided contacts (Type 48.12/P2). 48.12 48.12 For outline drawing see page 11 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 2 CO (DPDT) 2 CO (DPDT) 8/15 8/15 250/400 250/400 Rated load AC1 VA 2000 2000 Rated load AC15 (230 V AC) VA 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material 0.37 0.37 8/0.65/0.4 8/0.65/0.4 50 (5/5) 50 (5/5) AgNi+Au AgNi+Au 12 - 24 24 Coil specification Nominal voltage (UN) V DC Rated power DC W 0.7 0.7 Operating range DC (0.75…1.2)UN (0.75…1.2)UN Holding voltage DC 0.4 UN 0.4 UN Must drop-out voltage DC 0.1 UN 0.1 UN Mechanical life DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 ms 10/4 10/4 kV 6 (8 mm) 6 (8 mm) 1500 1500 –40…+70 –40…+70 IP 20 IP 20 Technical data XII-2020, www.findernet.com Operate/release time Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Protection category V AC °C Approvals relay (according to type) 3 48 SERIES 48 SERIES Relay interface modules 10 A 48.P3 1 CO relay interface modules, 15.8 mm wide 48.31 Ideal interface for PLC and electronic systems Type 48.P3 - 1 CO 10 A - Push-in terminals • AC coils or DC sensitive coils • Supply status indication and EMC coil • 1 CO 10 A • Push-in terminals suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • Cadmium-free contact material 48.P3 Push-in terminal • 1 CO 10 A • Screw terminals 48.31 Screw terminal For outline drawing see page 11 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 1 CO (SPDT) 1 CO (SPDT) 10/20 10/20 250/400 250/400 Rated load AC1 VA 2500 2500 Rated load AC15 (230 V AC) VA 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material 0.37 0.37 10/0.3/0.12 10/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 1.2/0.5 1.2/0.5 Coil specification Nominal voltage (UN)  V AC (50/60 Hz)  Rated power AC/sens. DC V DC VA (50 Hz)/W  AC (0.8…1.1)UN (0.8…1.1)UN  sens. DC (0.73…1.5)UN (0.73…1.5)UN Holding voltage AC/DC 0.8 UN / 0.4 UN 0.8 UN / 0.4 UN Must drop-out voltage AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 200 · 103 200 · 103 ms 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) kV 6 (8 mm) 6 (8 mm) 1000 1000 –40…+70 –40…+70 IP 20 IP 20 Operating range Technical data Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Protection category Approvals relay (according to type) 4 V AC °C XII-2020, www.findernet.com B Type 48.31 - 1 CO 10 A - Screw terminals 48 48 SERIES Relay interface modules 8 A SERIES 48.P5 2 CO relay interface modules, 15.8 mm wide 48.52 Ideal interface for PLC and electronic systems Type 48.P5 - 2 CO 8 A - Push-in terminals Type 48.52 - 2 CO 8 A - Screw terminals B • AC coils or DC sensitive coils • Supply status indication and EMC coil • 2 CO 8 A • Push-in terminals suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • Cadmium-free contact material 48.P5 Push-in terminal • 2 CO 8 A • Screw terminals 48.52 Screw terminal 48.52 / 72 48.52 / 72 2 CO (DPDT) 2 CO (DPDT) 8/15 8/15 250/400 250/400 For outline drawing see page 11 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1 VA 2000 2000 Rated load AC15 (230 V AC) VA 400 400 Single phase motor rating (230 V AC) kW 0.3 0.3 Breaking capacity DC1: 30/110/220 V A 8/0.3/0.12 8/0.3/0.12 mW (V/mA) 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 1.2/0.5 1.2/0.5 Minimum switching load Standard contact material Coil specification Nominal voltage (UN)  V AC (50/60 Hz)  Rated power AC/sens. DC V DC VA (50 Hz)/W  AC (0.8…1.1)UN (0.8…1.1)UN  sens. DC (0.73…1.5)UN (0.73…1.5)UN Holding voltage AC/DC 0.8 UN / 0.4 UN 0.8 UN / 0.4 UN Must drop-out voltage AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 ms 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) kV 6 (8 mm) 6 (8 mm) 1000 1000 –40…+70 –40…+70 IP 20 IP 20 Operating range Technical data XII-2020, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Protection category V AC °C Approvals relay (according to type) 5 48 SERIES 48 SERIES Relay interface modules 16 A 48.P6 1 CO relay interface modules, 15.8 mm wide 48.61 Ideal interface for PLC and electronic systems Type 48.P6 - 1 CO 16 A - Push-in terminals • AC coils or DC sensitive coils • Supply status indication and EMC coil • 1 CO 16 A • Push-in terminals suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • Cadmium-free contact material available 48.P6 Push-in terminal • 1 CO 16 A • Screw terminals 48.61 Screw terminal 48.61 / 81 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). For outline drawing see page 11 48.61 / 81 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 1 CO (SPDT) 1 CO (SPDT) 16*/30 16*/30 250/400 250/400 Rated load AC1 VA 4000 4000 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW 0.55 0.55 Breaking capacity DC1: 30/110/220 V A 16/0.3/0.12 16/0.3/0.12 mW (V/mA) 500 (10/5) 500 (10/5) AgCdO AgCdO 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 1.2/0.5 1.2/0.5 Minimum switching load Standard contact material Coil specification Nominal voltage (UN)  V AC (50/60 Hz)  Rated power AC/sens. DC Operating range V DC VA (50 Hz)/W  AC (0.8…1.1)UN (0.8…1.1)UN  sens. DC (0.8…1.5)UN (0.8…1.5)UN Holding voltage AC/DC 0.8 UN / 0.4 UN 0.8 UN / 0.4 UN Must drop-out voltage AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 10 100 · 103 ms 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) kV 6 (8 mm) 6 (8 mm) Technical data Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Protection category Approvals relay (according to type) 6 V AC °C 3 1000 1000 –40…+70 –40…+70 IP 20 IP 20 XII-2020, www.findernet.com B Type 48.61 - 1 CO 16 A - Screw terminals 48 48 SERIES Relay interface modules 10 A SERIES 48.P8 2 CO relay interface modules, 15.8 mm wide 48.62 Ideal interface for PLC and electronic systems Type 48.P8 - 2 CO 10 A - Push-in terminals Type 48.62 - 2 CO 10 A - Screw terminals B • DC sensitive coils • Supply status indication and EMC coil • 2 CO 10 A • Push-in terminals suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • Cadmium-free contact material 48.P8 Push-in terminal • 2 CO 10 A • Screw terminals 48.62 Screw terminal 48.62 / 82 48.62 / 82 For outline drawing see page 11 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 2 CO (DPDT) 2 CO (DPDT) 10/20 10/20 250/400 250/400 Rated load AC1 VA 2500 2500 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material 0.37 0.37 10/0.6/0.25 10/0.6/0.25 300 (5/5) 300 (5/5) AgNi AgNi — — 12 - 24 - 125 12 - 24 - 125 —/0.5 —/0.5 Coil specification Nominal voltage (UN)  V AC (50/60 Hz)  Rated power AC/sens. DC Operating range V DC VA (50 Hz)/W  AC  sens. DC — — (0.8…1.5)UN (0.8…1.5)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 10 100 · 103 ms 12/12 (DC) 12/12 (DC) kV 6 (8 mm) 6 (8 mm) Technical data XII-2020, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Protection category V AC °C 3 1000 1000 –40…+70 –40…+70 IP 20 IP 20 Approvals relay (according to type) 7 48 48 SERIES Relay interface modules 8 - 10 - 16 A SERIES Ordering information Example: 48 series, 35 mm rail (EN 60715) mount, Push-in terminal relay interface module, 2 CO 8 A contacts, 24 V sensitive DC coil, green LED + diode, 99.02 coil indication. 4 8 . P B C D 5 . 7 . 0 2 4 . 0 0 5 0 Series D: Special versions 0 = Standard 7 = Standard (for 48.12/48.P2 only) A: Contact material 0 = Standard AgNi for 48.P3/P5/P8/31/52/62 AgCdO, Standard for 48.P6/61 4 = AgSnO2, for 48.P6/P8/ 61/62 only 5 = AgNi + Au, for 48.12/P2 and 48.P3/P5/31/52 only Standard for 48.32 Type Screw terminal 1 = 35 mm rail (EN 60715) mount, forcibly guided contacts relay 3 = 35 mm rail (EN 60715) mount 5 = 35 mm rail (EN 60715) mount 6 = 35 mm rail (EN 60715) mount Push-in terminal P = 35 mm rail (EN 60715) mount Type Screw terminal 1 = for 48.31, 1 pole, 10 A 48.61, 1 pole, 16 A 2 = for 48.12/48.32 (DC only), 48.52, 2 poles, 8 A 48.62 (DC only), 2 poles, 10 A Push-in terminal 2 = for 48.P2 (DC only), 2 pole, 8 A 3 = for 48.P3, 1 pole, 10 A 5 = for 48.P5, 2 pole, 8 A 6 = for 48.P6, 1 pole, 16 A 8 = for 48.P8 (DC only), 2 pole, 10 A C: Options 0 = Standard (for 48.12/48.P2 only) 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC and 48.32: green LED + Varistor B: Contact circuit 0 = CO (nPDT) Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 7 48.12/48.P2 DC 5 0 0 48.32 DC 5 0 6 0 48.P3/P5/31/52 AC 0-5 0 6 0 Coil version 7 = Sensitive DC 8 = AC (50/60 Hz) 9 = DC (for 48.12/48.P2 only) 48.P3/P5/31/52 Sensitive DC 0-5 0 5 0 48.P6/61 AC 0-4 0 6 0 Coil voltage See coil specifications 48.P6/61 Sensitive DC 0-4 0 5 0 48.P8/62 Sensitive DC 0-4 0 5 0 Technical data Insulation Insulation according to EN 61810-1 48.12/P2/31/32/61/P3/P6 48.52/P5 insulation rated voltage V 250 48.12/31/61/62/P3/P6/P8 250 400 kV 4 4 4 pollution degree 3 2 2 overvoltage category III III III rated impulse withstand voltage Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) Dielectric strength between open contacts V AC 1000; 1500 (48.12/P2/32) Dielectric strength between adjacent contacts V AC 2000 (48.P5/52); 2500 (48.P8/62) 3000 (48.12/P2/32) Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV (1.2/50 µs) 2 Other data Bounce time: NO/NC ms 2/5; 2/10 (48.12/P2/32) Vibration resistance (10…200)Hz: NO/NC g 20/5 (for 1 pole) Power lost to the environment without contact current W 0.7 with rated current W 1.2 (48.12/P2/31/32/P3) Wire strip length Screw torque (only for 48.12/31/32/52/61/81) Min. wire size Max. wire size 8 15/3; 20/6 (48.12/P2/32) for 2 pole 2 (48.52/P5/61/62/P6/P8) mm 8 Nm 0.5 Screw terminal solid cable mm2 0.5 AWG 21 Screw terminal solid cable Push-in terminal stranded cable solid cable stranded cable 0.5 0.5 0.5 21 21 21 Push-in terminal stranded cable solid cable stranded cable mm2 1 x 6 / 2 x 2.5 1 x 4 / 2 x 2.5 2 x 1.5 / 1 x 2.5 2 x 1.5 / 1 x 2.5 AWG 1 x 10 / 2 x 14 1 x 12 / 2 x 14 2 x 16 / 1 x 14 2 x 16 / 1 x 14 XII-2020, www.findernet.com B A 48 48 SERIES Relay interface modules 8 - 10 - 16 A SERIES Contact specification F 48 - Electrical life (AC) v contact current Types 48.P3/P6/31/61 F 48 - Electrical life (AC) v contact current Types 48.P8/62 Cycles Cycles Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 B Resistive load - cosϕ = 1 Inductive load AC15 limit for 48.31 8 DC breaking current (A) H 48 - Maximum DC1 breaking capacity Types 48.P3/P5/P6/31/52/61 48.P6/61 current limit 48.P3/31 current limit 48.P5/52 current limit 2 contacts in series single contact DC voltage (V) Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 Cycles Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 F 48 - Electrical life (AC) v contact current Type 48.12/P2/32 H 48 - Maximum DC1 breaking capacity Types 48.P8/62 DC breaking current (A) Cycles F 48 - Electrical life (AC) v contact current Types 48.P5/52 12 2 contacts in series single contact DC voltage (V) DC breaking current (A) XII-2020, www.findernet.com H 48 - Maximum DC1 breaking capacity Type 48.12/P2/32 • When switching a resistive load (DC1) having voltage and current DC voltage (V) values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 9 48 48 SERIES Relay interface modules 8 - 10 - 16 A SERIES Coil specifications DC coil data (0.5 W sensitive) Nominal voltage Coil code UN V B 12 AC coil data Operating range 7.012 Umin* Umax V V 8.8 24 7.024 17.5 125 7.125 91 Rated coil consumption I at UN Nominal voltage UN mA V 12 Coil code Operating range Umin V 8.012 Umax V mA 18 41 36 22.2 24 8.024 19.2 188 4 110 8.110 88 121 10.1 120 8.120 96 132 11.8 230 8.230 184 253 7.0 * Umin = 0.8 UN for 48.61, 48.62, 48.P6, 48.P8 9.6 Rated coil consumption I at UN (50 Hz) 13.2 90.5 26.4 46 DC coil data, (0.7 W standard) - Type 48.12/48.P2/48.32, (48.32 available only 24 V DC) Nominal voltage UN Coil code Operating range Umin V Umax V Resistance R Rated coil consumption I at UN V Ω mA 12 9.012 9 14.4 205 58.5 24 9.024 18 28.8 820 29.3 R 48 - DC coil operating range v ambient temperature 48.P3/P5/31/52 48.P6/P8/61/62 R 48 - AC coil operating range v ambient temperature 1 1 48.P6/P8/61/62 48.P3/P5/31/52 2 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 2 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. R 48 - DC coil operating range v ambient temperature Type 48.12/P2/32 XII-2020, www.findernet.com 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 10 48 48 SERIES Relay interface modules 8 - 10 - 16 A Combinations SERIES Code Type of socket Type of relay Module Retaining clip 48.12 95.05.7 50.12 — 095.71 48.P2 48.32 48.31   95.P5.7 50.12 — 095.71 95.05 50.12 99.02 095.01 95.03 40.31 99.02 095.01 95.05 40.52 99.02 095.01 48.61 95.05 40.61 99.02 095.01 48.62 95.05 40.62 99.02 095.01 48.52    95.P3 40.31 99.02 095.91.3 95.P5 40.52 99.02 095.91.3 48.P6 95.P5 40.61 99.02 095.91.3 48.P8 95.P5 40.62 99.02 095.91.3  48.P3 48.P5 B    Outline drawings  64.5    25.9 17.5 17.5 25.5 35.4 78.6  21.6  15.8    32 Types 4  8.31 48.32 / 48.52 / 48.61 / 48.62 Screw terminal 3.6 58.1 29.5 35.5 95.5 30.5 15.8 Type 48.12 Screw terminal 30.4 Types 48.P2 48.P3 48.P5 48.P6 48.P8 Push-in terminal XII-2020, www.findernet.com Push-in terminal 11 48 SERIES 48 SERIES Relay interface modules 8 - 10 - 16 A Accessories 8-way jumper link for type 48.P3/P5/P6/P8 097.58 Rated values 10 A - 250 V 2-way jumper link for type 48.P3/P5/P6/P8 097.52 Rated values 10 A - 250 V 2-way jumper link for type 48.P3/P5/P6/P8 097.42 Rated values 10 A - 250 V Marker tag holder for type 48.P3/P5/P6/P8 and 48.12/31/32/52/61/62 097.00 097.58 B 097.52 097.42 P A N T E PEAN 095.18 PEAN O O T EUR EUR 097.00 8-way jumper link for screw terminal version 095.18 (blue) Rated values 10 A - 250 V Sheet of marker tags (CEMBRE Thermal transfer printers), plastic, 48 tags, 6 x 12 mm 095.18.0 (black) 060.48 060.48 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 4 8 . P 5 . 7 . 0 2 4 . 0 0 5 0 S P A SP Plastic retaining clip 12 Please see general technical information XII-2020, www.findernet.com A Standard packaging B Blister packaging
48.31.8.120.0060SPA
物料型号: - 48系列继电器接口模块,包括8A、10A、16A型号。
器件简介: - 这些继电器接口模块适用于多种应用,如控制面板、自动化仓库、医疗牙科设备、造船厂、电梯、电气配电板、建筑自动化、起重机和PLC等。
引脚分配: - 根据模块类型,有2个常开(CO)8A继电器或1个常开10A继电器等不同配置。
参数特性: - 额定电流/最大峰值电流为8/15A或10/20A,额定电压/最大切换电压为250/400V AC。 - 有直流线圈和交流线圈版本,工作电压范围为12V至24V DC或交流版本为50/60Hz。 - 机械寿命高达10^6至10^7次循环。
功能详解: - 模块具有强制导向接触点,符合EN 61810-3标准,适合安全应用。 - 有的模块具有供应状态指示和EMC线圈抑制模块。 - 某些继电器/插座组合具有UL认证。
应用信息: - 适用于需要高电流承载能力的场合,如工业自动化、建筑管理系统和电力系统。
封装信息: - 模块安装在35mm导轨上,符合EN 60715标准。
48.31.8.120.0060SPA 价格&库存
很抱歉,暂时无法提供与“48.31.8.120.0060SPA”相匹配的价格&库存,您可以联系我们找货
48.31.8.120.0060SPA
  • 1+175.084891+22.60000
  • 10+165.6303110+21.37960
  • 20+156.1757220+20.15920
  • 50+137.2665550+17.71840
48.31.8.120.0060SPA
  • 1+217.270281+28.04530
