66.82.8.230.0000
66.82.8.230.0000
    FINDER
66.82.8.230.0000 数据手册
40 SЕRIES Miniature PCB Relays 8 - 10 - 12 - 16 A Medical and dentistry Control panels Panels for electrical distribution Toys Automation for blinds, grilles and shutters Door and gate openers Electronic circuit boards Vending machines FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 40 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Power relays 1 and 2 pole for direct PCB or socket mount SERIES 40.31/51 40.52 40.61 Type 40.31/51 - 1 CO 12 A (3.5 mm pin pitch) - 1 CO 12 A (5.0 mm pin pitch) A Type 40.52 - 2 CO 8 A (5.0 mm pin pitch) Type 40.61 - 1 CO 16 A (5.0 mm pin pitch) • Pin length 3.5 mm for PCB mount • Pin length 5.3 mm for Plug-in mount • DC coils (650 mW or 500 mW) and AC coils • Cadmium-free contact material available • 8 mm Creepage and Clearance, 6 kV (1.2/50µs) • 1 CO 12 A on PCB, 10 A with socket • 3.5 mm pin pitch (40.31), 5.0 mm pin pitch (40.51) • PCB or 95 Series socket mount • 2 CO 8 A • 1 CO 16 A • 5.0 mm pin pitch • 5.0 mm pin pitch • PCB or 95 Series socket mount • PCB or 95 Series socket mount between coil and contact • Meets EN 60335-1 glow wire requirements • 95 series sockets for PCB or 35 mm rail mounting (EN 60715) with Screw, Screwless or Push-in terminals • Coil Indication and EMC suppression modules 99 series and Timer module 86.30 options • Environmental protection: RT II - flux proof (Standard) RT III - wash tight (Option) 40.31 * Mounted on sockets ≤ 10 A ** With the AgSnO2 material the maximum peak current on normally open contact, is 120 A - 5 ms (for 40.61) and 60 A - 5 ms (for 40.52) For UL ratings see: “General technical information” page V X-2021, www.findernet.com For outline drawing see page 10 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/ Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material Coil specification V AC (50/60 Hz) Nominal voltage (UN) V DC Rated power AC/DC/sensitive DC VA (50 Hz)/W/W Operating range AC DC/sensitive DC Holding voltage AC/DC Must drop-out voltage AC/DC Technical data Mechanical life cycles Electrical life at rated load AC1 cycles Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range °C Environmental protection 40.51 Copper side view Pin length 3.5 mm for PCB only Pin length 5.3 mm for PCB or sockets See ordering information Copper side view Pin length 5.3 mm for PCB or sockets See ordering information Copper side view Pin length 3.5 mm for PCB only Pin length 5.3 mm for PCB or sockets See ordering information 1 CO (SPDT) 12*/20 2 CO (DPDT) 8/15** 1 CO (SPDT) 16/30** 250/400 3000 1000 0.55 12/0.6/0.25 300 (5/5) AgNi 250/400 2000 750 0.37 8/0.6/0.25 300 (5/5) AgNi 250/400 4000 1000 0.55 16/0.6/0.25 500 (10/5) AgCdO 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 5 - 6 - 7 - 9 - 12 - 14 - 18 - 21 - 24 - 28 - 36 - 48 - 60 - 90 - 110 - 125 1.2/0.65/0.5 1.2/0.65/0.5 1.2/0.65/0.5 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.73…1.5)UN/(0.73…1.5)UN (0.73…1.5)UN/(0.73…1.5)UN (0.73…1.5)UN/(0.8…1.5)UN 0.8 UN/0.4 UN 0.8 UN/0.4 UN 0.8 UN/0.4 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 10 · 106 200 · 103 7/3 (10/3 sensitive) 10 · 106 100 · 103 7/3 (12/4 sensitive) 10 · 106 100 · 103 7/3 (10/3 sensitive) 6 (8 mm) 6 (8 mm) 6 (8 mm) 1000 –40…+85 RT II*** 1000 –40…+85 RT II*** 1000 –40…+85 RT II*** Approvals (according to type) *** See general technical information “Guidelines for automatic flow solder processes” page II. 3 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Power relays 1 and 2 pole for direct PCB or socket mount Type 40.62 - 2 CO 10A (5.0 mm pin pitch) - DC coils (650 mW or 500 mW) and AC coils - Meets EN 60335-1 glow wire requirements Type 40.xx.6 - Bistable versions of the types 40.31, 40.51, 40.52 and 40.61 - Bistable (single coil) • Cadmium-free contact material available • 8 mm Creepage and Clearance, 6 kV (1.2/50µs) between coil and contact • 2 CO 10 A • Bistable (single coil) • 5.0 mm pin pitch • 3.5 or 5.0 mm pin pitch • PCB or 95 Series sockets mount • PCB or 95 Series socket mount • 95 series sockets for PCB or 35 mm rail mounting (EN 60715) with Screw, Screwless or Push-in terminals • Environmental protection: RT II - flux proof (Standard) RT III - wash tight (Option) Bistable version (1 coil) types: 40.31.6… 40.51.6… 40.52.6… 40.61.6… * With the AgSnO2 material the maximum peak current on normally open contact is 60 A - 5 ms (for 40.62) For UL ratings see: “General technical information” page V Copper side view For wiring diagrams see page 10 Pin length 5.3 mm for PCB or sockets Pin length 5.3 mm for PCB or sockets For outline drawing see page 10 Contact specification Contact configuration 2 CO (DPDT) Rated current/Maximum peak current Rated voltage/ Maximum switching voltage Rated load AC1 A V AC VA 10/20* 250/400 2500 See relays 40.31 Rated load AC15 (230 V AC) VA 750 40.51 Single phase motor rating (230 V AC) kW 0.37 40.52 Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material 10/0.6/0.25 40.61 300 (5/5) page 3 AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC/sens. DC V DC VA (50 Hz)/W/W Operating range AC DC/sens. DC 110 - 120 - 230 - 240 5 - 6 - 7 - 9 - 12 - 14 - 18 - 21 - 24 - 28 - 48 - 60 - 110 - 125 1.2/0.65/0.5 5 - 6 - 12 - 24 - 48 - 110 1.0/1.0/— (0.8…1.1)UN (0.8…1.1)UN (0.73…1.5)UN / (0.73..1.5) UN (0.8…1.1)UN / — Holding voltage AC/DC 0.8/0.4 UN — Must drop-out voltage AC/DC 0.2/0.1 UN — Mechanical life cycles 10 · 106 See relays Electrical life at rated load AC1 cycles 100 · 103 40.31 ms 7/3 (12/4 sensitive) 40.51 kV 6 (8 mm) 40.52 V AC °C 1000 –40…+85 RT II 40.61 Min. impulse duration ≥ 20 ms Technical data Operate/release time Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) ** See general technical information “Guidelines for automatic flow solder processes” page II. 4 X-2021, www.findernet.com A 40.xx.6 40.62 40 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A SERIES Ordering information Example: 40 series PCB relay, 2 CO, 230 V AC coil. 4 0 . 5 A B C D 2 . 8 . 2 3 0 . 0 0 0 0 A: Contact material See table below Series Type 3 = PCB/Plug-in - 3.5 mm pinning 5 = PCB/Plug-in - 5 mm pinning 6 = PCB/Plug-in - 5 mm pinning B: Contact circuit 0 = CO (nPDT) 3 = NO (nPST) A D: Special versions 0 = Standard 1 = Wash tight (RT III) 3 = High temperature (+125 °C) wash tight C: Options 0 = Pin length 5.3 mm (Plug-in relays) 2 = Pin length 3.5 mm (PCB relays) No. of poles 1 = 1 pole 2 = 2 pole Coil version 6 = AC/DC bistable 7 = Sensitive DC, 0.5 W 8 = AC (50/60 Hz) 9 = Standard DC, 0.65 W Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Terminal pin Type Coil version A B C D PCB relay, pin length 3.5 mm 40.31/51 Standard DC/sensitive DC 1 (AgNi) 0-3 2 0-1 40.61 Standard DC/sensitive DC 1 (AgNi) - 2 (AgCdO) 0-3 2 0-1 PCB/Plug-in relay pin length 5.3 mm 40.31/51 AC/sensitive DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1 40.31/51 Standard DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1-3 40.52 AC/sensitive DC 0 (AgNi) - 4 (AgSnO2) - 5 (AgNi+Au) 0-3 0 0-1 40.52 Standard DC 0 (AgNi) - 4 (AgSnO2) - 5 (AgNi+Au) 0-3 0 0-1-3 40.61 AC/sensitive DC 0 (AgCdO) - 4 (AgSnO2) 0-3 0 0-1 40.61 Standard DC 0 (AgCdO) - 4 (AgSnO2) 0-3 0 0-1-3 AC/DC/sensitive DC 0 (AgNi) - 4 (AgSnO2) 0 0 0-1 Bistable 0 (AgNi) 0 0 0 40.61 Bistable 0 (AgCdO) 0 0 0 X-2021, www.findernet.com 40.62 40.31/51/52 5 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Technical data Insulation according to EN 61810-1 1 pole Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 3 2 pole 230/400 400 250 400 2 3 2 Insulation between coil and contact set Type of insulation Reinforced (8 mm) Reinforced (8 mm) III III kV (1.2/50 µs) 6 6 Overvoltage category Rated impulse voltage Dielectric strength V AC 4000 4000 Insulation between adjacent contacts (40.52) Type of insulation — Basic Overvoltage category — II Rated impulse voltage kV (1.2/50 µs) — Dielectric strength 2.5 V AC — 2000 Type of insulation — Basic Overvoltage category — III kV (1.2/50 µs) — 4 Insulation between adjacent contacts (40.52 + 40.62) Rated impulse voltage Dielectric strength V AC — 2500 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1000/1.5 Micro-disconnection 1000/1.5 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV (1.2/50 µs) 2 Other data Bounce time: NO/NC ms 2/5 Vibration resistance (10…150)Hz: NO/NC g 20/5 (1 changeover) 15/4 (2 changeover) Shock resistance NO/NC g 20/13 (1 changeover) 20/12 (2 changeover) Power lost to the environment without contact current W 0.65 with rated current W 1.2 (40.31/51) Recommended distance between relays mounted on PCB 2 (40.61/52/62) mm ≥ 5 X-2021, www.findernet.com A 6 40 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A SERIES Contact specification F 40.1 - Electrical life (AC) v contact current Types 40.31/51/61 F 40.2 - Electrical life (AC) v contact current Type 40.52 Limit for 40.31/51 Cycles Cycles Resistive load - cosφ = 1 Inductive load AC15 A Resistive load - cosφ = 1 Inductive load AC15 F 40.6 - Electrical life (AC) v contact current Type 40.62 Cycles Resistive load - cosφ = 1 Inductive load AC15 12 X-2021, www.findernet.com 8 7 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Contact specification H 40.1 -Maximum DC1 breaking capacity Types 40.31/51/52/61 H 40.6 -Maximum DC1 breaking capacity Type 40.62 40.52 - 2 contacts in series single contact DC voltage (V) DC breaking current (A) 40.61 current limit 40.31/51 current limit 40.52 current limit DC breaking current (A) 2 contacts in series single contact DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. X-2021, www.findernet.com A 8 40 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A SERIES Coil specifications DC coil data - 0.65 W standard (types 40.31/51/52/61/62) Nominal Coil Operating range Resistance Rated coil voltage code consumption Umin Umax R I at UN UN V V V mA Ω 5 9.005 3.65 7.5 38 130 6 9.006 4.4 9 55 109 7 9.007 5.1 10.5 75 94 9 9.009 6.6 13.5 125 72 12 9.012 8.8 18 220 55 14 9.014 10.2 21 300 47 18 9.018 13.1 27 500 36 21 9.021 15.3 31.5 700 30 24 9.024 17.5 36 900 27 28 9.028 20.5 42 1200 23 36 9.036 26.3 54 2000 18 48 9.048 35 72 3500 14 60 9.060 43.8 90 5500 11 90 9.090 65.7 135 12500 7.2 110 9.110 80.3 165 18000 6.2 125 9.125 91.2 188 23500 5.3 DC coil data - 0.5 W sensitive (types 40.31/51/52/61/62) Nominal Coil Operating range Resistance Rated coil voltage code consumption Umin* Umax R I at UN UN V V V mA Ω 5 7.005 3.7 7.5 50 100 6 7.006 4.4 9 75 80 7 7.007 5.1 10.5 100 70 9 7.009 6.6 13.5 160 56 12 7.012 8.8 18 288 42 14 7.014 10.2 21 400 35 18 7.018 13.2 27 650 27.7 21 7.021 15.4 31.5 900 23.4 24 7.024 17.5 36 1150 21 28 7.028 20.5 42 1600 17.5 36 7.036 26.3 54 2600 13.8 48 7.048 35 72 4800 10 60 7.060 43.8 90 7200 8.4 90 7.090 65.7 135 16200 5.6 110 7.110 80.3 165 23500 4.7 125 7.125 91.2 188 32000 3.9 * Umin = 0.8 UN for 40.61 Resistance R Ω 21 80 320 1350 2100 6900 9000 28000 31500 Rated coil consumption I at UN (50 Hz) mA 168 90 45 21 16.8 9.4 8.4 5 4.1 AC/DC coil data - bistable (types 40.31/51/52/61) Nominal Coil Operating range Resistance Rated coil DC: Release consumption resistance** voltage code UN Umin Umax R I at UN RDC V V V mA Ω Ω 5 6.005 4 5.5 23 215 37 6 6.006 4.8 6.6 33 165 62 12 6.012 9.6 13.2 130 83 220 24 6.024 19.2 26.4 520 40 910 48 6.048 38.4 52.8 2100 21 3,600 110 6.110 88 121 11000 10 16,500 ** RDC = Resistance in DC, RAC = 1.3 x RDC 1 W X-2021, www.findernet.com AC coil data (types 40.31/51/52/61/62) Nominal Coil Operating range voltage code Umin Umax UN V V V 6 8.006 4.8 6.6 12 8.012 9.6 13.2 24 8.024 19.2 26.4 48 8.048 38.4 52.8 60 8.060 48 66 110 8.110 88 121 120 8.120 96 132 230 8.230 184 253 240 8.240 192 264 9 A 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Coil specifications R 40 - DC coil operating range v ambient temperature Sensitive coil, types 40.31/51/52/61/62 40.61 40.31/51/52/62 R 40 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Wiring diagram for 40 series bistable coil version AC Operation On momentary closure of the SET switch the relay is magnetised through the diode and the relay contacts transfer to the set position and remain in this position. On momentary closure of the RESET switch the relay is demagnetised through limiting resistor (RAC) and the contacts return to the reset position. DC Operation On momentary closure of the SET switch the relay is magnetised and the relay contacts transfer to the set position and remain in this position. On momentary closure of the RESET switch the relay is demagnetised through limiting resistor (RDC) and the contacts return to the reset position. Notes: T he minimum SET or RESET impulse time is 20 ms. The maximum time can be continuous. In practice, always ensure that the SET and RESET contacts cannot be operated simultaneously. Outline drawings Types 40.31/51/52/61/62 * (3.5 or 5.3 mm) see ordering code 10 X-2021, www.findernet.com A R 40 - DC coil operating range v ambient temperature Standard coil 40 95 SERIES Socket overview for 40 series relays SERIES Module Socket Relay Description Mounting Accessories 99.02 95.P3 40.31 40.51 40.52 40.61 40.62 Panel or 35 mm rail (EN 60715) mount - Coil indication and EMC 95.P5 Push-in terminal sockets - For fast cable connection - Top terminals - Contacts - Bottom terminals - Coil 95.P5 See page 12 Relay Description 99.02 95.03 40.31 95.05 40.51 40.52 40.61 40.62 Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount - Top terminals - Contacts - Bottom terminals - Coil See page 14 Module Socket 99.80 Relay 95.83.3 40.31 95.85.3 40.51 40.52 40.61 40.62 95.85.3 A clip Module Socket 95.05 suppression modules - Jumper link - Timer modules - Plastic retaining and release Mounting Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Plastic retaining and release clip Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail - Top terminals - NO and COM (EN 60715) mount Contacts - Bottom terminals - Coil and NC Contacts Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retaining and release clip See page 15 Module Socket 99.80 Relay 95.93.3 40.31 95.95.3 40.51 40.52 40.61 40.62 95.95.3 Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail - Top terminals - Contacts (EN 60715) mount - Bottom terminals - Coil Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retaining and release clip See page 16 Module Socket 99.01 Relay Description 95.63 40.31 - Metal retaining clip 95.65 40.51 40.52 40.61 40.62 Screw terminal (Box clamp) socket Panel or 35 mm rail - Top terminals - Contacts (EN 60715) mount - Bottom terminals - Coil Relay Description Mounting Accessories 95.13.2 40.31 PCB socket PCB mounting - Metal retaining clip - Plastic retaining clip 95.65 See page 17 Module Socket 95.13.2 95.15.2 40.51 40.52 40.61 40.62 Accessories X-2021, www.findernet.com See page 18 — — Mounting 11 40 SERIES 95 SERIES Socket and accessories for 40 series relays A 95.P5 Approvals (according to type): 095.91.3 060.48 Push-in terminals socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link 2-way jumper link (12.5 mm pitch) 2-way jumper link (4.6 mm pitch) Marker tag holder (for tags 060.48 type) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfert printer Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Wire strip length mm Min. wire size for 95.P3 and 95.P5 sockets mm2 AWG Max. wire size for 95.P3 and 95.P5 sockets mm2 AWG 95.P3 40.31 95.P5 40.51, 40.52, 40.61, 40.62 095.71 095.91.3 097.58 097.52 097.42 097.00 095.00.4 99.02 86.30 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 10 solid wire 0.5 21 solid wire 2 x 1.5 / 1 x 2.5 2 x 16 / 1 x 14 stranded wire 0.5 21 stranded wire 2 x 1.5 / 1 x 2.5 2 x 16 / 1 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Total socket current (A) L 95 - Total socket current v ambient temperature 11 A2 COM 14 NO 12 NC A1 COIL 95.P3 95.P3 95.P5 95.P5 8-way jumper link for 95.P3 and 95.P5 sockets Rated values 097.58 10 A - 250 V 2-way jumper link for 95.P3 and 95.P5 sockets Rated values 097.52 10 A - 250 V 097.58 X-2021, www.findernet.com 097.52 12 40 95 SERIES Socket and accessories for 40 series relays 2-way jumper link for 95.P3 and 95.P5 sockets Rated values SERIES 097.42 10 A - 250 V A 097.42 Marker tag holder for 95.P3 and 95.P5 sockets 097.00 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 86.30.8.120.0000 86.30.8.240.0000 097.00 86.30 99.02 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.P3 and 95.P5 sockets Diode (+A1, standard polarity) (6…220)V DC 99.02.3.000.00 LED(6…24)V DC/AC 99.02.0.024.59 LED(28…60)V DC/AC 99.02.0.060.59 LED(110…240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.02.9.220.99 LED + Varistor (6…24)V DC/AC 99.02.0.024.98 LED + Varistor (28…60)V DC/AC 99.02.0.060.98 LED + Varistor (110…240)V DC/AC 99.02.0.230.98 RC circuit (6…24)V DC/AC 99.02.0.024.09 RC circuit (28…60)V DC/AC 99.02.0.060.09 RC circuit (110…240)V DC/AC 99.02.0.230.09 Residual current by-pass* (110…240)V AC 99.02.8.230.07 * Additional 0.9 W power dissipation X-2021, www.findernet.com DC Modules with non-standard polarity (+A2) on request. Approvals (according to type): 13 40 95 SERIES Socket and accessories for 40 series relays SERIES A 95.05 Approvals (according to type):  ertain relay/socket C combinations 095.01 Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Marker tag holder (for tags 060.48 type) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.01 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Screw torque 95.03 (blue) 40.31 95.03.0 (black) 95.05 (blue) 95.05.0 (black) 40.51, 40.52, 40.61, 40.62 095.71 095.01 095.18 095.01.0 095.18.0 095.01 095.18 097.00 095.00.4 99.02 86.30 095.01.0 095.18.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) Nm 0.5 Wire strip length Max. wire size for 95.03 and 95.05 sockets mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 060.48 Total socket current (A) * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. L 95 - Total socket current v ambient temperature 11 A2 COM 14 NO 12 NC A1 COIL P A PEAN N T E O O T 95.03 95.05 8-way jumper link for 95.03 and 95.05 sockets Rated values 095.18 (blue) 10 A - 250 V 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 86.30.8.120.0000 86.30.8.240.0000 095.18.0 (black) EUR EUR 95.03 PEAN 095.18 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 14 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.03 and 95.05 sockets Diode (+A1, standard polarity) (6…220)V DC 99.02.3.000.00 LED(6…24)V DC/AC 99.02.0.024.59 LED(28…60)V DC/AC 99.02.0.060.59 LED(110…240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.02.9.220.99 LED + Varistor (6…24)V DC/AC 99.02.0.024.98 LED + Varistor (28…60)V DC/AC 99.02.0.060.98 LED + Varistor (110…240)V DC/AC 99.02.0.230.98 RC circuit (6…24)V DC/AC 99.02.0.024.09 RC circuit (28…60)V DC/AC 99.02.0.060.09 RC circuit (110…240)V DC/AC 99.02.0.230.09 Residual current by-pass* (110…240)V AC 99.02.8.230.07 * Additional 0.9 W power dissipation X-2021, www.findernet.com 86.30 40 95 SERIES Socket and accessories for 40 series relays SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Marker tag holder Sheet of marker tags for plastic retaining and release clip 095.91.3, 48 tags, 6 x 12 mm, for CEMBRE thermal transfert printer Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C 95.85.3 Approvals (according to type): 095.91.3 Screw torque 95.83.3 (blue) 95.83.30 (black) 95.85.3 (blue) 95.85.30 (black) 40.31 40.51, 40.52, 40.61, 40.62 A 095.71 095.91.3 095.08 095.91.30 095.08.0 095.91.3 095.08 095.00.4 99.80 097.00 095.91.30 095.08.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 2 kV Nm 0.5 Wire strip length Max. wire size for 95.83.3 and 95.85.3 sockets 060.48 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 Total socket current (A) * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. L 95 - Total socket current v ambient temperature P A PEAN N T E O O T 8-way jumper link for 95.83.3 and 95.85.3 sockets Rated values 95.85.3 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR 95.83.3 PEAN 095.08 99.80 X-2021, www.findernet.com Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 99.80 coil indication and EMC suppression modules for 95.83.3 and 95.85.3 sockets Blue* Diode (+A1, standard polarity) (6…220)V DC 99.80.3.000.00 LED(6…24)V DC/AC 99.80.0.024.59 LED(28…60)V DC/AC 99.80.0.060.59 LED(110…240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.80.9.220.99 LED + Varistor (6…24)V DC/AC 99.80.0.024.98 LED + Varistor (28…60)V DC/AC 99.80.0.060.98 LED + Varistor (110…240)V DC/AC 99.80.0.230.98 RC circuit (6…24)V DC/AC 99.80.0.024.09 RC circuit (28…60)V DC/AC 99.80.0.060.09 RC circuit (110…240)V DC/AC 99.80.0.230.09 Residual current by-pass* (110…240)V AC 99.80.8.230.07 * Additional 0.9 W power dissipation 15 40 SERIES 95 SERIES Socket and accessories for 40 series relays Screw (Box clamp) terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C A 95.95.3 Approvals (according to type): 095.91.3 Screw torque 95.93.30 (black) 95.95.3 (blue) 95.95.30 (black) 40.51, 40.52, 40.61, 40.62 095.71 095.91.3 095.08 095.91.30 095.08.0 095.91.3 095.08 095.00.4 99.80 095.91.30 095.08.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) Nm 0.5 Wire strip length Max. wire size for 95.93.3 and 95.95.3 sockets 060.48 95.93.3 (blue) 40.31 mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Total socket current (A) L 95 - Total socket current v ambient temperature P A N T E O O T 8-way jumper link for 95.93.3 and 95.95.3 sockets Rated values 95.95.3 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR 95.93.3 PEAN PEAN 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 16 99.80 coil indication and EMC suppression modules for 95.93.3 and 95.95.3 sockets Blue* Diode (+A1, standard polarity) (6…220)V DC 99.80.3.000.00 LED(6…24)V DC/AC 99.80.0.024.59 LED(28…60)V DC/AC 99.80.0.060.59 LED(110…240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.80.9.220.99 LED + Varistor (6…24)V DC/AC 99.80.0.024.98 LED + Varistor (28…60)V DC/AC 99.80.0.060.98 LED + Varistor (110…240)V DC/AC 99.80.0.230.98 RC circuit (6…24)V DC/AC 99.80.0.024.09 RC circuit (28…60)V DC/AC 99.80.0.060.09 RC circuit (110…240)V DC/AC 99.80.0.230.09 Residual current by-pass* (110…240)V AC 99.80.8.230.07 * Additional 0.9 W power dissipation X-2021, www.findernet.com 095.08 40 95 SERIES Socket and accessories for 40 series relays SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip 8-way jumper link Modules (see table below) Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C 95.63 Approvals (according to type): Screw torque Wire strip length Max. wire size for 95.63 and 95.65 sockets 95.65 95.63 40.31 95.65 40.51, 40.52, 40.61, 40.62 A 095.71 095.08 — 095.08 99.01 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 2 kV Nm 0.5 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Approvals (according to type): Total socket current (A) L 95 - Total socket current v ambient temperature P A PEAN N T E O O T 95.65 8-way jumper link for 95.63 and 95.65 sockets Rated values 095.08 (blue) 10 A - 250 V EUR EUR 95.63 PEAN 095.08 99.01 coil indication and EMC suppression modules for type 95.63 socket Blue* Diode (+A1, standard polarity) (6…220)V DC 99.01.3.000.00 Diode (+A2, non-standard polarity) (6…220)V DC 99.01.2.000.00 LED(6…24)V DC/AC 99.01.0.024.59 99.01 Approvals (according to type): X-2021, www.findernet.com * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. LED(28…60)V DC/AC 99.01.0.060.59 LED(110…240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.01.9.220.99 LED + Diode (+A2, non-standard polarity) (6…24)V DC 99.01.9.024.79 LED + Diode (+A2, non-standard polarity) (28…60)V DC 99.01.9.060.79 LED + Diode (+A2, non-standard polarity) (110…220)V DC 99.01.9.220.79 LED + Varistor (6…24)V DC/AC 99.01.0.024.98 LED + Varistor (28…60)V DC/AC 99.01.0.060.98 LED + Varistor (110…240)V DC/AC 99.01.0.230.98 RC circuit (6…24)V DC/AC 99.01.0.024.09 RC circuit (28…60)V DC/AC 99.01.0.060.09 RC circuit (110…240)V DC/AC 99.01.0.230.09 Residual current by-pass* (110…240)V AC 99.01.8.230.07 * Additional 0.9 W power dissipation 17 95.13.2 95.15.2 Approvals (according to type): PCB socket For relay type Accessories Metal retaining clip (supplied with socket packaging code SMA) Plastic retaining clip Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C 95.13.2 (blue) 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 40.31 40.51, 40.52, 40.61, 40.62 095.51 095.52 12 A - 250 V 6 kV IP 20 –40…+70 10 A - 250 V* * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. 40.51 A1 12 11 14 A2 22 21 24 12 14 22 24 3.5 11 1.5 30 20 13 7.5 3.5 40.31 21 A1 A2 40.52 95.13.2 95.13. 2 95.15.2 = 5 5 1.5 7.5 Copper side view 3 20 29 6 12 .4 A 95 SERIES Socket and accessories for 40 series relays Copper side view = 40 SERIES 40.61 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 5 S P A A Standard packaging SM Metal retaining clip SP Plastic retaining clip Please 18 see general technical information X-2021, www.findernet.com 9 5 . P
66.82.8.230.0000 价格&库存
很抱歉,暂时无法提供与“66.82.8.230.0000”相匹配的价格&库存,您可以联系我们找货
  • 10+178.2986710+23.17448
