7T SERIES
Panel Thermostat
7T
SERIES
Panel thermostat
7T.81.0.000.240x
• Small, compact size (17.5 mm wide)
• Snap action themostatic Bimetal sensor
• Wide temperature setting range
• Long electrical life
• 35 mm rail (EN 60715) mount
• Heating control
7T.81.0.000.230x
• Ventilation control
Max
Min
Heating control - Should the panel temperature fall below the (minimum)
set temperature the contact will close to call for heat. The contact will open
when this set temperature is exceeded.
Ventilation control - Should the panel temperature exceed the (maximum) set
temperature then the contact will close to call for cooling. The contact will open
when the temperature falls below this set temperature.
For outline drawing see page 2
G
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
1 NC
1 NO
10/20
10/20
250/250
250/250
A
V AC
Rated load AC1
VA
2500
2500
Rated load AC15 (230 V AC)
VA
250
250
Single phase motor rating AC3 (230 V AC)kW
1.1
1.1
Breaking capacity DC1: 30/110/220 V
Minimum switching load
A
1/0.3/0.15
1/0.3/0.15
mW (V/mA)
500 (12/10)
500 (12/10)
AgNi
AgNi
Standard contact material
Temperature setting range
Setting range (ventilation)
Switch temperature differential
Setting range (heating)
°C
K
°C
K
–20…+40
–20…+40
+0…+60
7 ± 4
+0…+60
7 ± 4
100 · 103
100 · 103
–45…+80
–45…+80
IP 20
IP 20
Technical data
Electrical life at rated load AC1
Ambient temperature range
Protection category
cycles
°C
IX-2016, www.findernet.com
Approvals (according to type)
1
7T
SERIES
7T SERIES
Panel Thermostat
Ordering information
Example: 7T Series, thermostat for ventilation control, contact activates ventilation should the panel temperature exceed the set value (max+60 °C),
35 mm rail (EN 60715) mount.
7 T . 8
1 . 0 . 0 0 0 . 2
3
Control function
(Temperature only)
1 = (–20…+40)°C
3 = (0…+60)°C
Series
Type
8 = 35 mm rail (EN 60715) mount
No. of contacts
1 = 1 contact
3 = 1 NO contact
4 = 1 NC contact
Voltage type
0 = No operating voltage required
Monitoring function
2 = Temperature, adjustable
Rated operating voltage
000 = No operating voltage required
Technical data
Insulation
Dielectric strength between open contacts
V AC
500
Nm
0.5
0.5
solid cable
stranded cable
Other data
Screw torque
Max. wire size
mm
2
AWG
1 x 2.5
1 x 1.5
1 x 12
1 x 16
G
Outline drawings
7T.81
Screw terminal
2
很抱歉,暂时无法提供与“7T.81.0.000.2403”相匹配的价格&库存,您可以联系我们找货
