96.02SMA
96.02SMA
    FINDER
96.02SMA 数据手册
56 Series - Miniature power relays 12 A Features 56.32/56.34 56.32-0300/56.34-0300 Plug-in - 12 A Power relay, 2 & 4 pole Flange mount option (Faston 187, 4.8x0.5 mm termination) • AC coils & DC coils • Lockable test button and mechanical flag indicator • Cadmium Free contacts (standard version) • Contact material options • 96 series sockets • Coil EMC suppression • Accessories • European Patent • • • 56.32 2 or 4 pole normally open contact (≥1.5 mm gap) • Plug-in/Faston 187 • 2 or 4 pole changeover contact Plug-in/Faston 187 56.32-0300 56.34-0300 56.34 * For 4 CO (4PDT) or 4 NO only. FOR UL RATINGS SEE: “General technical information” page V 56.32 56.34 56.32-0300 56.34-0300 Contact specification Contact configuration 2 CO (DPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 4 CO (4PDT) 2NO (DPST-NO) - ≥1.5mm gap 4NO (4PST-NO) - ≥1.5mm gap 12/20 12/20 250/400 250/400 Rated load AC1 VA 3,000 3,000 Rated load AC15 (230 V AC) VA 700 700 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) 0.55 0.55 12/0.5/0.25 12/1/0.5 500 (10/5) 500 (10/5) AgNi AgNi Standard contact material Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400* V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range 6 - 12 - 24 - 48 - 60 - 110 - 125 - 220 1.5/1 1.5/— (0.8…1.1)UN AC DC 2/1.3 — (0.8…1.1)UN 2/— (0.85…1.1)UN (0.85…1.1)UN — Holding voltage AC/DC 0.8 UN/0.6 UN 0.85 UN/— Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/— Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/— Electrical life at rated load AC1 cycles 100 · 103 100 · 103 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C 8/3 10/4 4 5 8/4 4 5 1,000 2,000 –40…+70 –40…+70 RT I RT I Approvals (according to type) 1 56 Series - Miniature power relays 12 A Features 56.42/56.44 56.42-0300/56.44-0300 Printed circuit mount 12 A Power relay 2 & 4 pole AC coils & DC coils • Cadmium Free contacts (standard version) • Contact material option • RT III (wash tight) option available • • • • 56.42 2 or 4 pole normally open contact (≥ 1.5 mm gap) • PCB mount • 2 or 4 pole changeover contact PCB mount 56.42-0300 56.44 56.44-0300 56.42 Copper side view * For 4 CO (4PDT) or 4 NO only. FOR UL RATINGS SEE: “General technical information” page V 56.44 Copper side view 56.42-0300 Copper side view 56.44-0300 Copper side view Contact specification Contact configuration 2 CO (DPDT) Rated current/Maximum peak current 4 CO (4PDT) A Rated voltage/Maximum switching voltage V AC 2NO (DPST-NO) - ≥1.5mm gap 4NO (4PST-NO) - ≥1.5mm gap 12/20 12/20 250/400 250/400 Rated load AC1 VA 3,000 3,000 Rated load AC15 (230 V AC) VA 700 700 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) 0.55 0.55 12/0.5/0.25 12/1/0.5 500 (10/5) 500 (10/5) AgNi AgNi Standard contact material Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400* V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range 6 - 12 - 24 - 48 - 60 - 110 - 125 - 220 1.5/1 AC DC 2/1.3 — 1.5/— (0.8…1.1)UN (0.8…1.1)UN 2/— (0.85…1.1)UN (0.85…1.1)UN — Holding voltage AC/DC 0.8 UN/0.6 UN 0.85 UN/— Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/— Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/— Electrical life at rated load AC1 cycles 100 · 103 100 · 103 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) 2 V AC °C 8/3 10/4 4 5 8/4 4 5 1,000 2,000 –40…+70 –40…+70 RT I RT I 56 Series - Miniature power relays 12 A Ordering information Example: 56 series plug-in relay, 2 CO (DPDT), 12 V DC coil, lockable test button and mechanical indicator. 5 6 . 3 A B C D 2 . 9 . 0 1 2 . 0 0 4 0 A: Contact material 0 = Standard AgNi 2 = AgCdO 4 = AgSnO2 Series Type 3 = Plug-in 4 = PCB B: Contact circuit 0 = CO (nPDT) 3 = NO (nPST), ≥ 1.5 mm contact gap No. of poles 2 = 2 pole, 12 A 4 = 4 pole, 12 A Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type B C D 56.32 AC Coil version A 0-2-4 0 0-2-3-4-5 0 AC 0-2-4 0 54 AC 0-2-4 3 0-3-5 0 DC 0-2-4 0 0-2-4-6-7-8-9 0 DC 0-2-4 0 74 - 94 56.34 AC 0-2-4 0 0-2-3-4-5 0-6-8 AC 0-2-4 0 54 / AC 0-2-4 0-3 0-3-5 0 DC 0-2-4 0 0-2-4-6-7 0-6-8 / / DC 0-2-4 0 74 / 56.42 DC 0-2-4 0 0 0-1 AC 0-2-4 0-3 0 0-1 0-2-4 0 0 0-1 0-2-4 0-3 0 0-1 56.44 AC-DC AC D: Special versions 0 = Standard 1 = Wash tight (RT III) for 56.42 and 56.44 only 6 = Rear flange mount (4 pole only) 8 = Rear 35 mm rail mount (4 pole only) For other mounting options see page 6 C: Options 0 = None 2 = Mechanical indicator 3* = LED (AC) 4 = Lockable test button+mechanical indicator 5* = Lockable test button + LED (AC) 54* = Lockable test button + LED (AC) + mechanical indicator 6* = Double LED (DC non-polarized) 7* = Lockable test button + double LED (DC non-polarized) 74* = Lockable test button + double LED (DC non-polarized) + mechanical indicator 8* = LED + diode (DC, polarity positive to pin 7) for 56.32 only 9* = Lockable test button + LED + diode (DC, polarity positive to pin 7) for 56.32 only 94* = Lockable test button + LED + diode (DC, polarity positive to pin 7) + mechanical indicator for 56.32 only * Options not available for 220 V DC and 400 V AC versions. Special versions for Rail Applications on request C: Option 6, 7, 74 Double LED (DC non-polarized) O P A PEAN N T E PEAN 3 1 T EUR C: Option 8, 9, 94 LED + diode (DC, polarity positive to pin 7) (56.32 only) O C: Option 3, 5, 54 LED (AC) EUR Descriptions: options and special versions Lockable test button and mechanical flag indicator (0040, 0050, 0054, 0070, 0074, 0090, 0094) The dual-purpose Finder test button can be used in two ways: Case 1) The plastic pip (located directly above the test button) remains intact. In this case, when the test button is pushed, the contacts operate. When the test button is released the contacts return to their former state. Case 2) The plastic pip is broken-off (using an appropriate cutting tool). In this case, (in addition to the above function), when the test button is pushed and rotated, the contacts are latched in the operating state, and remain so until the test button is rotated back to its former position. 2 In both cases ensure that the test button actuation is swift and decisive. 3 56 Series - Miniature power relays 12 A Technical data *Only in applications where over voltage category II is permitted. In applications of over voltage category III: Micro-disconnection. Insulation according to EN 61810-1 Nominal voltage of supply system V AC Rated insulation voltage V AC Pollution degree Insulation between coil and contact set Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC Insulation between adjacent contacts Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC Insulation between open contacts Type of disconnection Overvoltage category Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC/(1.2/50 µs) Conducted disturbance immunity Burst (5...50) ns, 5 kHz, on A1 - A2 Surge (1.2/50 µs) on A1 - A2 (differential mode) Other data Bounce time: NO/NC ms Vibration resistance (10…150 Hz ): NO/NC g Shock resistance NO/NC g Power lost to the environment without contact current W with rated current W Recommended distance between relays mounted on PCB mm 2 CO - 4 CO 230/400 250 3 400 2 2 NO - 4 NO 230/400 250 3 400 2 Basic III 4 2,500 Basic III 4 2,500 Basic III 4 2,500 Basic III 4 2,500 Micro-disconnection — — 1,000/1.5 Full-disconnection* II 2.5 2,000/3 EN 61000-4-4 EN 61000-4-5 level 4 (4 kV) level 4 (4 kV) 1/4 (changeover) 17/14 20/14 1 (56.32, 56.42) 3.8 (56.32, 56.42) ≥ 5 3/— (normally open) 1.3 (56.34, 56.44) 6.9 (56.34, 56.44) Contact specification Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 DC breaking current (A) H 56 - Maximum DC1 breaking capacity Changeover version contacts in series DC voltage (V) H 56 - Maximum DC1 breaking capacity Normally open version DC breajking current (A) Cycles F 56 - Electrical life (AC) v contact current 2 - 4 pole relays contacts in series DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time of the load will be increased. 4 56 Series - Miniature power relays 12 A Coil specifications DC coil data, 2 pole relay Nominal Coil voltage code AC coil data, 2 pole relay Operating range Resistance Rated coil Nominal Coil consumption voltage code Operating range Resistance UN Umin Umax R I at UN UN Umin* Umax R V V V Ω mA V V V Ω 4.8 6.6 40 150 6 8.006 6 9.006 12 9.012 9.6 13.2 140 86 12 24 9.024 19.2 26.4 600 40 24 48 9.048 38.4 52.8 2,400 20 60 9.060 48 66 4,000 15 110 9.110 88 121 12,500 125 9.125 100 138 17,300 220 9.220 176 242 54,000 Rated coil consumption 4.8 6.6 8.012 9.6 8.024 19.2 48 8.048 60 8.8 7.2 4 I at UN (50Hz) mA 12 200 13.2 50 97 26.4 190 53 38.4 52.8 770 25 8.060 48 66 1,200 21 110 8.110 88 121 3,940 12.5 120 8.120 96 132 4,700 12 230 8.230 184 253 17,000 6 240 8.240 192 264 19,100 5.3 * Umin = 0.85 UN for normally open version. DC coil data, 4 pole relay Nominal Coil voltage code AC coil data, 4 pole relay or 4 NO Operating range Resistance Rated coil Nominal Coil consumption voltage code Operating range Resistance UN Umin Umax R I at UN UN Umin* Umax R V V V Ω mA V V V Ω 6 9.006 5.1 6.6 12 9.012 10.2 13.2 24 9.024 20.4 26.4 48 9.048 40.8 60 9.060 51 110 9.110 121 10,400 125 9.125 107 138 14,200 220 9.220 187 242 44,000 93.5 32.5 185 6 8.006 123 97 12 490 49 24 52.8 1,800 27 66 3,000 20 Rated coil consumption I at UN (50Hz) mA 4.8 6.6 5.7 300 8.012 9.6 13.2 22 150 8.024 19.2 26.4 81 90 48 8.048 38.4 52.8 380 37 60 8.060 48 66 600 30 10.5 110 8.110 88 121 1,900 16.5 8.8 120 8.120 96 132 2,560 13.4 5 230 8.230 184 253 7,700 9 240 8.240 192 264 10,000 7.5 400 8.400 320 440 26,000 4.9 * Umin = 0.85 UN for normally open version. R 56 - DC coil operating range v ambient temperature 2 pole relay R 56 - AC coil operating range v ambient temperature 2 pole relay normally open version changeover version R 56 - DC coil operating range v ambient temperature 4 pole relay R 56 - AC coil operating range v ambient temperature 4 pole relay or 4 NO normally open version changeover version 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 5 56 Series - Miniature power relays 12 A Accessories Top flange mount adaptor for 56.32 056.25 056.25 056.25 with relay 056.25 with relay 056.25 056.27 Rear flange mount adaptor for 56.32 056.26 056.27 with 056.26 relay 056.26 with relay 056.26 056.26 with relay Top 35 mm rail (EN 60715) adaptor for 56.32 056.27 056.27 with relay 056.27 Top flange mount adaptor for 56.34 056.45 6 056.45 056.45 with relay Top 35 mm rail (EN 60715) adaptor for 56.34 056.47 056.47 056.47 with relay 056.47 with relay Sheet of marker tags for relay type 56.34, plastic, 72 tags, 6x12 mm 060.72 056.27 with relay 056.45 with relay 056.45 056.47 056.27 060.72 96 Series - Sockets and accessories for 56 series relays 094.91.3 REG I ST L 96 - Rated current vs ambient temperature 86.30 060.72 ST TY — — 090.00.2 99.02 86.00, 86.30 — ERED UN MM CO D E S I ITY Rated current (A) G MM CO D E S I — 12 A - 250 V 2 kV AC IP 20 –40…+70 (see diagram L96) 0.8 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 ERED I UN 096.71 — 094.91.30 094.06.0 96.04.0 Black G Approvals (according to type): 094.06 095.00.4 96.04 Blue 56.34 I 96.04 094.71 094.91.3 REG Approvals (according to type): 96.02.0 Black N 96.02 96.02 Blue 56.32 N Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining and release clip (supplied with socket - packaging code SPA) 6-way jumper link Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 094.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 94.02/04 sockets mm2 AWG N T E O P A 96.02 96.04 96.04 PEAN T EUR EUR 96.02 O 6-way jumper link for 96.02 socket 094.06 (blue) Rated values 10 A - 250 V 86 series timer modules Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.00.0.240.0000 86.30.0.024.0000 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.240.0000 094.06.0 (black) PEAN 094.06 86.00 Approvals (according to type): 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 99.02 coil indication and EMC suppression modules for 96.02 and 96.04 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC sockets 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 7 96 Series - Sockets and accessories for 56 series relays 96.72 Approvals (according to type): Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 96.72 and 96.74 sockets mm2 AWG 96.72 Blue 56.32 96.72.0 Black 094.71 96.74 Blue 56.34 096.71 99.01 12 A - 250 V 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x4 1x12 / 2x12 stranded wire 1x4 / 2x2.5 1x12 / 2x14 96.74 Approvals (according to type): 96.72 96.74 99.01 coil indication and EMC suppression modules for types 96.72 and 96.74 sockets Blue* Diode (+A1, standard polarity) (6...220)V DC Diode (+A2, non-standard polarity) (6...220)V DC 99.01.3.000.00 99.01.2.000.00 99.01 LED (6...24)V DC/AC 99.01.0.024.59 Approvals (according to type): LED (28...60)V DC/AC 99.01.0.060.59 LED (110...240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.01.9.220.99 LED + Diode (+A2, non-standard polarity) (6...24)V DC 99.01.9.024.79 LED + Diode (+A2, non-standard polarity) (28...60)V DC 99.01.9.060.79 LED + Diode (+A2, non-standard polarity) (110...220)V DC 99.01.9.220.79 LED + Varistor (6...24)V DC/AC 99.01.0.024.98 99.01.0.060.98 * Modules in Black housing are available on request. LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC 99.01.0.230.98 RC circuit (6...24)V DC/AC 99.01.0.024.09 Green LED is standard. Red LED available on request. RC circuit (28...60)V DC/AC 99.01.0.060.09 RC circuit (110...240)V DC/AC 99.01.0.230.09 (110...240)V AC 99.01.8.230.07 8 Residual current by-pass 96.74.0 Black 96 Series - Sockets and accessories for 56 series relays 96.12 Approvals (according to type): PCB socket For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C 96.12 (blue) 56.32 96.12.0 (black) 96.14 (blue) 56.34 96.14.0 (black) 094.51 15 A - 250 V 2 kV AC IP 20 –40…+70 Copper side view 96.12 Copper side view 96.14 Packaging code How to code and identify retaining clip and packaging options for sockets. Example: 9 6 . 7 4 S M A A Standard packaging SM Metal retaining clip SP Plastic retaining clip 9 6 . 7 4 Without retaining clip 9
96.02SMA 价格&库存
很抱歉,暂时无法提供与“96.02SMA”相匹配的价格&库存,您可以联系我们找货
96.02SMA
  • 1+67.805901+8.79011
  • 10+60.4133510+7.83176
  • 30+57.1659230+7.41078
  • 50+55.7140650+7.22257
  • 100+53.80334100+6.97487
  • 250+51.37427250+6.65997
  • 500+49.60880500+6.43110
  • 1000+47.902891000+6.20996
库存:50
96.02SMA
    • 1+49.23663
    库存:293
