095.00.4
095.00.4
    FINDER
    MARKING TAG 95 SOCKETS
095.00.4 数据手册
95 Series - Sockets and accessories for 41 series relays 41 95.15.2 095.41.3 095.42 10 A - 250 V * ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 12 3.7 13 12 14 A1 14 9.5 12 11 14 A2 22 21 24 Ø 3.2 A2 1 21 7.45 A2 11 7.45 11 A1 30.3 6 5. 6 5. Ø Ø 3.2 11 A1 41.31 41.52 3.5 13 7.5 (22) 12 14 (24) 12 11 14 A2 22 21 24 30 20 A1 3.5 30 20 13 7.5 5 5 A2 4 13 12 14 22 24 A1 Ø Approvals (according to type): 95.13.2 (blue) 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 41.31 41.52, 41.61 30.3 95.13.2 PCB socket For relay type Accessories Metal retaining clip (supplied with socket - packaging code SNA) Plastic retaining clip Technical data Rated values Insulation Protection category Ambient temperature °C 11 (21) 95.13.2 Copper side view How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 3 . 2 S N A A Standard packaging SN Metal retaining clip SL Plastic retaining clip 9 5 . 1 36 3 . 2 95.15.2 Copper side view Packaging codes 9 5 . 1 A2 1.5 1.5 A1 41.61 Without retaining clip 9.2 95 Series - Socket overview for 40 series relays 95.05 40 Module Socket Relay 99.02 95.03 40.31 95.05 40.51 40.52 40.61 Description Screw terminal (Box clamp) socket Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Plastic retaining and release clip Module Socket Relay 99.80 95.83.3 40.31 95.85.3 40.51 40.52 40.62 Description Screw terminal (Box clamp) socket 95.83.3 wiring: Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retaining and release clip Module Socket Relay 99.80 95.93.3 40.31 95.95.3 40.51 40.52 40.61 Description Screw terminal (Box clamp) socket Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retaining and release clip Module Socket Relay 99.02 95.55 40.51 40.52 40.61 Description Screwless terminal socket For fast cable connections Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Timer modules - Plastic retaining and release clip Module Socket Relay 99.80 95.55.3 40.51 40.52 40.61 Description Screwless terminal socket For fast cable connections Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Plastic retaining and release clip Mounting PCB mounting Accessories - Metal retaining clip - Plastic retaining clip See page 27 95.85.3 See page 28 95.95.3 See page 29 95.55 See page 30 95.55.3 See page 31 95.13.2 See page 32 Top terminals Bottom terminals 26 Module Socket Relay Description — 95.13.2 40.31 PCB socket 40.41 — 95.15.2 40.51 40.52 40.61 95 Series - Sockets and accessories for 40 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip 95.05 (supplied with socket - packaging code SPA) Approvals 8-way jumper link (according to type): Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 095.01 Listed: certain relay/ plastic, 72 tags, 6x12 mm socket combinations Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm 095.01 Max. wire size for 95.03 and 95.05 sockets mm2 AWG 95.03 (blue) 40.31 95.03.0 (black) 95.05 (blue) 95.05.0 (black) 40.51, 40.52, 40.61 095.01 095.01.0 095.18 095.18.0 095.18 095.00.4 99.02 86.10, 86.20 060.72 095.71 095.01 095.01.0 40 095.18.0 10 A - 250 V * 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 0.5 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 75.3 60.9 060.72 22.4 COM 21 11 COM NO 24 14 NO 22 12 NC NC 17.5 17.5 A2 A1 28.3 28.3 Ø 3.2 A2 COIL 15.8 95.03 A1 35.4 78.6 Ø 3.2 = 14 12 78.6 = 11 COIL 15.8 95.05 32 36 8-way jumper link for 95.03 and 95.05 sockets 095.18 Rated values 10 A - 250 V 110.5 3.3 095.18 15 15.8 15.8 15.8 15.8 15.8 15 10.3 7 5.1 86 series timer modules (see technical data pages 182/185) Mono-function: (12…24)V AC/DC; function AI; (1.5s…60min) Mono-function: (12…24)V AC/DC; function DI; (1.5s…60min) 86.10 99.02 Approvals (according to type): * Modules in Black housing are available on request. Blue 86.10.0.024.0000 86.20.0.024.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.03 and 95.05 sockets See technical data pages 247/248 Blue* Diode (+A1, standard polarity) (6...220)V DC 99.02.3.000.00 LED (6...24)V DC/AC 99.02.0.024.59 LED (28...60)V DC/AC 99.02.0.060.59 LED (110...240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.02.9.220.99 LED + Varistor (6...24)V DC/AC 99.02.0.024.98 LED + Varistor (28...60)V DC/AC 99.02.0.060.98 LED + Varistor (110...240)V DC/AC 99.02.0.230.98 RC circuit (6...24)V DC/AC 99.02.0.024.09 RC circuit (28...60)V DC/AC 99.02.0.060.09 RC circuit (110...240)V DC/AC 99.02.0.230.09 Residual current by-pass (62 kΩ/1W) (110...240)V AC 99.02.8.230.07 27 95 Series - Sockets and accessories for 40 series relays 95.85.3 Approvals (according to type): 095.91.3 060.72 95.83.3 (blue) 40.31 95.83.30 (black) 95.85.3 (blue) 95.85.30 (black) 40.51, 40.52, 40.61 095.91.3 095.71 095.91.30 095.91.3 095.08 095.08.0 095.08 095.80.3 99.80 060.72 75 21 11 COM 14 NO 24 14 NO 21.6 12 NC Ø 3.2 95.83.3 A1 COIL 22 12 NC 35.5 78.8 21.6 A1 COIL A2 41 41 81.9 78.8 81.9 Ø 3.2 A2 28.8 15.5 15.5 COM 11 29.9 95.85.3 33.9 8-way jumper link for 95.83.3 and 95.85.3 sockets 095.08 Rated values 10 A - 250 V 113.1 095.08 13.9 10 3 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 99.80 coil indication and EMC suppression modules for 95.83.3 and 95.85.3 sockets Blue* See technical data pages 247/248 Diode (+A1, standard polarity) Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 28 095.08.0 10 A - 250 V * ≥ 6 kV (1.2/50 µs) between coil and contacts (95.83.3 only) IP 20 –40…+70 0.5 7 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 46.8 99.80 095.91.30 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 7 40 Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 95.83.3 and 95.85.3 sockets m2 AWG 95 Series - Sockets and accessories for 40 series relays 95.95.3 Approvals (according to type): 095.91.3 Screw (Box clamp) terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 95.93.3 and 95.95.3 sockets m2 AWG 95.93.3 (blue) 40.31 095.91.3 095.08 95.93.30 (black) 95.95.3 (blue) 95.95.30 (black) 40.51, 40.52, 40.61 095.71 095.91.30 095.91.3 095.08.0 095.08 095.80.3 99.80 060.72 095.91.30 095.08.0 40 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 0.5 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 75 64.8 060.72 46.8 15.5 15.5 11 COM NO NO 22 12 NC COIL 81.9 A2 A1 Ø 3.2 32.6 A1 COM 14 Ø 3.2 32.6 81.9 A2 11 24 NC 78.6 14 12 21 78.6 28.8 COIL 29.8 95.93.3 95.95.3 33.8 8-way jumper link for 95.93.3 and 95.95.3 sockets 095.08 Rated values 10 A - 250 V 113.1 095.08 7 10 3 13.9 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 99.80 coil indication and EMC suppression modules for 95.93.3 and 95.95.3 sockets Blue* See technical data pages 247/248 Diode (+A1, standard polarity) 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 29 95 Series - Sockets and accessories for 40 series relays 95.55 Approvals (according to type): 095.91.3 95.55 (blue) 40.51, 40.52, 40.61 095.71 095.91.3 99.02 86.10, 86.20 060.72 10 A - 250 V * 6 kV (1.2/50 µs) between coil and contacts IP 20 –25…+70 8 solid wire stranded wire 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 24.6 73.7 44 NO 22 12 NC A2 A1 COIL 15.8 Ø 3.2 34.7 COM 14 30.3 11 24 37 21 30.6 060.72 95.6 40 Screwless terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55 socket mm2 AWG 22.6 32.5 86 series timer modules (see technical data pages 182) Mono-function: (12…24)V AC/DC; function AI; (1.5s…60min) Mono-function: (12…24)V AC/DC; function DI; (1.5s…60min) 86.10 99.02 Approvals (according to type): * Modules in Black housing are available on request. 30 Blue 86.10.0.024.0000 86.20.0.024.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.55 socket See technical data pages 247/248 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (62 kΩ/1W) (110...240)V AC Blue* 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 95 Series - Sockets and accessories for 40 series relays 95.55.3 Approvals (according to type): 095.91.3 Screwless terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55.3 socket mm2 AWG 95.55.3 (blue) 40.51, 40.52, 40.61 095.71 095.91.3 40 99.80 060.72 10 A - 250 V * 6 kV (1.2/50 µs) between coil and contacts IP 20 –25…+70 8 solid wire stranded wire 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). COM 14 NO 22 12 NC Ø 3.2 A1 37.2 A2 COIL 34.7 11 24 30.3 21 95.6 060.72 73.7 44 30.6 24.6 15.8 22.6 32.5 99.80 coil indication and EMC suppression modules for 95.55.3 socket Blue* See technical data pages 247/248 Diode (+A1, standard polarity) 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 31 95 Series - Sockets and accessories for 40 series relays 95.13.2 40 PCB socket For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining clip Technical data Rated values Insulation Protection category Ambient temperature °C 95.13.2 (blue) 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 40.31, 40.41 40.51, 40.52, 40.61 095.51 095.52 10 A - 250 V * ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 95.15.2 12 3.7 13 12 14 14 9.5 A1 12 Ø A1 A2 11 (21) Ø 3.2 A2 1 30.3 A2 7.45 11 7.45 6 5. 6 5. Ø 3.2 11 A2 4 13 12 14 14 A1 40.51 A1 12 11 14 A2 22 21 24 13 7.5 12 14 22 24 21 A2 1.5 A1 40.52 95.13.2 Copper side view A1 12 11 14 A2 22 21 24 95.15.2 (22) 12 14 (24) 11 (21) A1 40.61 Packaging codes How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 9 5 . 0 5 S P A A Standard packaging SM Metal retaining clip SP Plastic retaining clip 9 5 . 0 32 5 Without retaining clip 30 20 3.5 11 1.5 30 20 5 5 13 7.5 3.5 40.31 11 30.3 A1 Ø Approvals (according to type): A2 Copper side view 9.2 95 Series - Socket overview for 44 series relays Module Socket Relay Description 99.02 95.05 44.52 Screw terminal (Box clamp) socket 44.62 Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Plastic retaining and release clip Module Socket Relay Description 99.80 95.85.3 44.52 Screw terminal (Box clamp) socket 44.62 Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Plastic retainig and release clip Module Socket Relay Description 99.80 95.95.3 44.52 Screw terminal (Box clamp) socket 44.62 Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Plastic retaining and release clip Module Socket Relay Description 99.02 95.55 44.52 Screwless terminal socket 44.62 For fast cable connections Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Timer modules - Plastic retaining and release clip Module Socket Relay Description 99.80 95.55.3 44.52 Screwless terminal socket 44.62 For fast cable connections Top terminals - Contacts Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Plastic retaining and release clip Module Socket Relay Description — 95.15.2 44.52 PCB socket 44.62 Mounting PCB mounting Accessories - Metal retaining clip 95.05 See page 45 44 95.85.3 See page 46 95.95.3 See page 47 95.55 See page 48 95.55.3 See page 49 95.15.2 See page 50 Top terminals Bottom terminals 44 95 Series - Sockets and accessories for 44 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip 95.05 (supplied with socket - packaging code SPA) Approvals 8-way jumper link (according to type): Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 095.01 plastic, 72 tags, 6x12 mm Listed: certain relay/ socket combinations Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm 095.01 Max. wire size for 95.05 socket mm2 AWG 95.05 (blue) 44.52, 44.62 95.05.0 (Black) 44.52, 44.62 095.71 095.01.0 095.01 095.18 095.18.0 095.00.4 99.02 86.10, 86.20 060.72 44 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 0.5 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 75.3 60.9 22.4 11 COM 24 14 NO 22 12 NC 17.5 17.5 28.3 A2 A1 35.4 Ø 3.2 = 78.6 = 060.72 21 COIL 32 36 15.8 8-way jumper link for 95.05 socket 095.18 Rated values 10 A - 250 V 110.5 3.3 095.18 15 15.8 15.8 15.8 15.8 15.8 15 10.3 7 5.1 86 series timer modules (see technical data pages 182/185) Mono-function: (12…24)V AC/DC; function AI; (1.5s…60min) Mono-function: (12…24)V AC/DC; function DI; (1.5s…60min) 86.10 99.02 Approvals (according to type): * Modules in Black housing are available on request. Blue 86.10.0.024.0000 86.20.0.024.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.05 socket See technical data pages 247/248 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (62 kΩ/1W) (110...240)V AC Blue* 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 45 95 Series - Sockets and accessories for 44 series relays 95.85.3 Approvals (according to type): 44 095.91.3 Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 95.85.3 sockets mm2 AWG 95.85.3 (blue) 44.52, 44.62 95.85.30 (black) 44.52, 44.62 095.71 095.91.30 095.91.3 095.08 095.08.0 095.80.3 99.80 060.72 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 0.5 7 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 75 060.72 46.8 28.8 21 11 COM 24 14 NO 21.6 15.5 22 12 NC 35.5 21.6 A1 COIL 41 A2 78.8 81.9 Ø 3.2 29.9 33.9 8-way jumper link for 95.85.3 socket 095.08 Rated values 10 A - 250 V 113.1 095.08 7 10 3 13.9 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 99.80 coil indication and EMC suppression modules for 95.85.3 socket Blue* See technical data pages 247/248 Diode (+A1, standard polarity) 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 46 95 Series - Sockets and accessories for 44 series relays 95.95.3 Approvals (according to type): 095.91.3 Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 95.95.3 sockets m2 AWG 95.95.3 (blue) 44.52, 44.62 95.95.30 (black) 44.52, 44.62 095.71 095.91.30 095.91.3 095.08 095.08.0 095.80.3 99.80 060.72 44 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 0.5 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 75 64.8 060.72 46.8 15.5 28.8 COM 14 NO 22 12 NC A1 32.6 A2 Ø 3.2 78.6 11 24 81.9 21 COIL 29.8 33.8 8-way jumper link for 95.85.3 socket 095.08 Rated values 10 A - 250 V 113.1 095.08 7 10 3 13.9 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 99.80 coil indication and EMC suppression modules for 95.95.3 socket Blue* See technical data pages 247/248 Diode (+A1, standard polarity) 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 47 95 Series - Sockets and accessories for 44 series relays 95.55 Approvals (according to type): 44 095.91.3 Screwless terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55 socket mm2 AWG 060.72 NO 22 12 NC A2 A1 COIL 15.8 Ø 3.2 34.7 14 30.3 COM 24 37 11 95.6 21 095.71 095.91.3 095.00.4 99.02 86.10, 86.20 060.72 10 A - 250 V 6 kV (1.2/50 µs) between coil and contacts IP 20 –25…+70 8 solid wire stranded wire 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) 73.7 44 30.6 24.6 95.55 (blue) 44.52, 44.62 22.6 32.5 86 series timer modules (see technical data pages 182) Mono-function: (12…24)V AC/DC; function AI; (1.5s…60min) Mono-function: (12…24)V AC/DC; function DI; (1.5s…60min) 86.10 99.02 Approvals (according to type): * Modules in Black housing are available on request. 48 Blue 86.10.0.024.0000 86.20.0.024.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.55 socket See technical data pages 247/248 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (62 kΩ/1W) (110...240)V AC Blue* 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 95 Series - Sockets and accessories for 44 series relays 95.55.3 Approvals (according to type): 095.91.3 Screwless terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Identification tag Modules (see table below) Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Insulation Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55.3 socket mm2 AWG 24.6 24 14 NO 22 12 NC Ø 3.2 A1 37.2 A2 44 10 A - 250 V 6 kV (1.2/50 µs) between coil and contacts IP 20 –25…+70 8 solid wire stranded wire 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) 73.7 44 COIL 34.7 COM 095.00.4 99.80 060.72 30.3 11 95.6 21 095.71 095.91.3 30.6 060.72 95.55.3 (blue) 44.52, 44.62 15.8 22.6 32.5 99.80 coil indication and EMC suppression modules for 95.55.3 socket Blue* See technical data pages 247/248 Diode (+A1, standard polarity) 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 (110...240)V AC 99.80.8.230.07 Residual current by-pass (62 kΩ/1W) 49 95 Series - Sockets and accessories for 44 series relays 95.15.2 Approvals (according to type): PCB socket For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining clip Technical data Rated values Insulation Protection category Ambient temperature °C 44 4 13 95.15.2 (blue) 44.52, 44.62 095.51 095.52 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 13 7.5 9.2 12 14 22 24 12 11 14 22 21 24 30.3 A2 1.5 A1 7.45 21 30 20 6 5. Ø 3.2 11 A2 5 5 Ø A1 95.15.20 (black) 44.52, 44.62 Copper side view Packaging codes How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 9 5 . 0 5 S P A A Standard packaging SM Metal retaining clip SP Plastic retaining clip 9 5 . 0 50 5 Without retaining clip 95 Series - Sockets and accessories for 43 series relays 95.23 Approvals (according to type): PCB socket (for changeover contacts only) For relay type Accessories Metal retaining clip (supplied with socket - packaging code SNA) Technical data Rated values Insulation Protection category Ambient temperature °C 43 4.5 10 95.23 (blue) 43.41 095.43 10 A - 250 V ≥ 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 10.5 11 A2 12 14 30.5 12 14 A1 11 A1 A2 43.41 2.8 1.5 3.2 30.5 22.2 3.2 10 7.5 95.23 Copper side view Packaging codes How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 9 5 . 2 3 S N A A Standard packaging SN Metal retaining clip 9 5 . 2 40 3 95.23.0 (black) 43.41 Without retaining clip
095.00.4 价格&库存
很抱歉,暂时无法提供与“095.00.4”相匹配的价格&库存,您可以联系我们找货
  • 10+2.9336510+0.38031
