72 Series - Monitoring relays 16 A
Features
72.01
72.11
Level control relays for conductive liquids
72.01 - Adjustable sensitivity
72.11 - Fixed sensitivity
Emptying or filling functions
LED indicator
• Reinforced insulation (6 kV - 1.2/50 µs) between:
- supply and contacts
- electrodes and supply
- contacts and electrodes
• 35 mm rail (EN 50022) mount
• Control about a single level or between
Min./Max. limits
• 72.01 available also for supply 400 V
Sensitivity range (5...150) kΩ adjustable
Delay time (0.5s or 7s) switch selectable
Emptying or filling functions switch selectable
U = 24 V DC
24 V AC 50/60 Hz
(110...125)V AC 50/60 Hz
(230...240)V AC 50/60 Hz
L/+
N/54.6
35
42.3
Sensitivity fixed 150 kΩ
Delay time fixed: 1s
Emptying or filling functions link selectable
U = 24 V DC
24 V AC 50/60 Hz
L/+
N/-
FL
FS FS
ES
A1 A2
EL
11 14
A1
B1 B2
A2
12
11 14
F = Filling
Z1 Z2
LEVEL
LEVEL
44.8
84
12
E = Emptying
Z1 Z2
B3
B1 B2 B3 Z1 Z2
T=1s
R = 150 kΩ
R = (5…150)kΩ
58
FL = Filing – 7s delay
FS = Filling – 0.5s delay
ES = Emptying – 0.5s delay
EL = Emptying – 7s delay
FOR UL HORSEPOWER AND PILOT DUTY RATINGS
SEE “General technical information” page V
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/Maximum switching voltage V AC
Rated load AC1
1 CO (SPDT)
16/30
16/30
250/400
250/400
4,000
4,000
VA
Rated load AC15 (230 V AC)
Single phase motor rating (230 V AC)
Breaking capacity DC1: 30/110/220 V
Minimum switching load
1 CO (SPDT)
A
VA
750
750
kW
0.55
0.55
16/0.3/0.12
16/0.3/0.12
500 (10/5)
500 (10/5)
AgCdO
AgCdO
A
mW (V/mA)
Standard contact material
Supply specification
Nominal voltage (UN)
V AC
Rated power AC/DC
VA (50 Hz)/W
400
24 - 110...125 – 230...240
24
24
2.5/1.5
2.5/1.5
2.5/1.5
AC
(0.8...1.1)UN
(0.9...1.15)UN
(0.8...1.1)UN
DC
(0.8...1.1)UN
(0.8...1.1)UN
V DC
Operating range
Technical data
Electrical life at rated load AC1
cycles
Electrode voltage
V AC
Electrode current
mA
Run-on time
Max sensitivity range
s
kΩ
Insulation between supply/contacts/electrode (1.2/50 µs) kV
Ambient temperature
Protection category
°C
100 · 103
100 · 103
4
4
0.2
0.2
0.5 - 7 (selectable)
1
5…150 (adjustable)
150 (fixed)
6
6
–20…+60
–20…+60
IP20
IP20
Approvals (according to type)
1
72 Series - Monitoring relays 6 A
Features
72.31
3 Phase - Rotation and phase loss monitoring relay
Universal voltage monitoring
(UN from 208 V to 480 V, 50/60 Hz)
• Phase loss monitoring, under phase regeneration
• Positive safety logic - make contact opens
if the relay detects an error
• Small size (17.5 mm wide)
• European patent pending for the fully
innovative principle at the root of the 3 phase
monitoring and error survey system
Phase rotation monitoring
56.5
43.5
26.5
UN= (208...480) V AC 3~
(50/60 Hz)
L1
L2
L3
17.5
A2
A1
A3
45
84
A1
A2
A3
3~U
14
11
14
11
12
12
1 CO (SPDT)
A
Rated load AC1
VA
250/400
1,500
VA
250
kW
0.185
A
3/0.35/0.2
mW(V/mA)
500 (10/5)
6/15
AgCdO
Nominal system voltage (UN)
Frequency
Rated power
Operating range
V AC 3 ~
Hz
VA 50 Hz/ W
208...480
50/60
8/1
V AC 3 ~
170...500
cycles
100 · 103
s
很抱歉,暂时无法提供与“072.501”相匹配的价格&库存,您可以联系我们找货
