22.22.9.024.4000
22.22.9.024.4000
    FINDER
22.22.9.024.4000 数据手册
Modular monostable relays 20 A Hotel room energy-enabling units Garden and night lighting Streetlights and car park lighting Bathrooms lighting control Office lighting control Pump control 22 SЕRIES 22 SERIES Modular monostable relays 20 A 1 or 2 pole, 20 A relay for direct 35 mm rail (EN 60715) mounting 22 SERIES 22.21 22.22 • 17.4 mm wide • Test button • Identification label • AC coils and DC coils • 35 mm rail (EN 60715) mount • Cadmium free contact material X-2017, www.findernet.com 22.21/22 Screw terminals For outline drawing see page 6 Contact specification Contact configuration A Rated current/Maximum peak current Rated voltage/ Maximum switching voltage V AC Rated load AC1 VA VA Rated load AC15 (230 V AC) Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Nominal lamp rating: 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W CFL W 230 V LED W LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W mW (V/mA) Minimum switching load  Standard contact material Coil specification V AC (50/60 Hz) Nominal voltage (UN) V DC Rated power AC/DC  VA (50 Hz)/W Operating range  AC (50 Hz) DC Technical data Mechanical life AC/DC cycles Electrical life at rated load in AC1 cycles Operate/release time ms Maximum impulse duration Insulation between coil and contacts (1.2/50 μs) kV Ambient temperature range °C Protection category • Single phase switch 1 NO • Double phase switch 2 NO (SPST-NO) • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount 1 NO (SPST-NO) 20/30 2 NO (DPST-NO) 20/30 250/400 5000 1000 — 20/0.3/0.12 250/400 5000 1000 — 20/0.3/0.12 1000 1000 400 400 360 200 200 360 200 200 200 200 400 1000 (10/10) AgSnO2 400 1000 (10/10) AgSnO2 (DPST-NO) 12 - 24 - 230 12 - 24 3/1.25 (0.85…1.1)UN (0.9…1.1)UN 12 - 24 3/1.25 (0.85…1.1)UN (0.9…1.1)UN 500 · 103 50 · 103 15/8 continuous 500 · 103 50 · 103 15/8 continuous 4 –40…+40 IP 20 4 –40…+40 IP 20 L Approvals relay (according to type) 3 22 SERIES 22 SERIES Modular monostable relays 20 A 1 or 2 pole, 20 A relay for direct 35 mm rail (EN 60715) mounting 22.23 22.24 • 17.4 mm wide • Test button • Identification label • AC coils and DC coils • 35 mm rail (EN 60715) mount • Cadmium free contact material 22.23/24 Screw terminals • Double phase switc 1 NO + 1 NC • Double phase switch 2 NC (SPST-NO + SPST-NC) (DPST-NC) • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount Approvals relay (according to type) 4 2 NC (DPST-NC) 20/30 250/400 5000 1000 — 20/0.3/0.12 1000 400 360 200 200 200 400 1000 (10/10) AgSnO2 12 - 24 3/1.25 (0.85…1.1)UN (0.9…1.1)UN 500 · 103 50 · 103 15/8 continuous 4 –40…+40 IP 20 X-2017, www.findernet.com L For outline drawing see page 6 Contact specification Contact configuration 1 NO + 1 NC (SPST-NO + SPST-NC) A 20/30 Rated current/Maximum peak current Rated voltage/ Maximum switching voltage V AC 250/400 Rated load AC1 VA 5000 VA Rated load AC15 (230 V AC) 1000 Single phase motor rating (230 V AC) kW — Breaking capacity DC1: 30/110/220 V A 20/0.3/0.12 Nominal lamp rating: 230 V incandescent/halogen W 1000 fluorescent tubes with electronic ballast W 400 fluorescent tubes with electromechanical ballast W 360 CFL W 200 230 V LED W 200 LV halogen or LED with electronic ballast W 200 LV halogen or LED with electromechanical ballast W 400 mW (V/mA) Minimum switching load  1000 (10/10) Standard contact material AgSnO2 Coil specification V AC (50/60 Hz) 12 - 24 - 230 Nominal voltage (UN) V DC 12 - 24 Rated power AC/DC  VA (50 Hz)/W 3/1.25 Operating range  AC (50 Hz) (0.85…1.1)UN DC (0.9…1.1)UN Technical data Mechanical life AC/DC cycles 500 · 103 Electrical life at rated load in AC1 cycles 50 · 103 Operate/release time ms 15/8 Maximum impulse duration continuous Insulation between coil and contacts (1.2/50 μs) kV 4 Ambient temperature range °C –40…+40 Protection category IP 20 22 SERIES Modular monostable relays 20 A 22 SERIES Ordering information Example: 22 series 35 mm rail mount relay, 1 NO (SPST-NO) 20 A contact, coil rated 24 V DC, contact material AgSnO2. 2 2 . 2 1 . 9 . 0 2 4 . 4 Series 0 0 0 Contact material 4 = AgSnO2 Type 2 = 35 mm rail (EN 60715) mount Coil voltage See coil specifications No. of poles 1 = 1 NO (SPST-NO) 2 = 2 NO (DPST-NO) 3 = 1 NO + 1 NC (SPST-NO + SPST-NC) 4 = 2 NC (DPST-NC) Coil version 8=A  C (50/60 Hz) 9=D  C Technical data Insulation Dielectric strength between supply and contacts V AC 3500 between open contacts V AC 2000 between adjacent contacts V AC 2000 Other data Bounce time: NO/NC ms 5/10 Power lost to the environment without contact current W 1.2 with rated current W 3.2 (22.21, 22.23) Screw torque 5.2 (22.22, 22.24) Nm 0.8 0.8 Coil terminals Max. wire size solid cable mm2 1 x 4 / 2 x 2.5 AWG 1 x 12 / 2 x 14 Contact terminals stranded cable solid cable stranded cable 1 x 2.5 / 2 x 2.5 1 x 6 / 2 x 6 1 x 6 / 2 x 4 1 x 14 / 2 x 14 1 x 10 / 2 x 10 1 x 10 / 2 x 12 If the coil is operated for a prolonged period of time, adequate ventilation of the relays must be provided - suggested gap of 9 mm between adjacent relays. Coil specifications DC version data Nominal voltage Coil code UN AC version data Operating range Umin R I at UN Nominal voltage Coil code UN Operating range Umin Resistance Consumption Umax R Ω I at UN (50 Hz) V V Ω mA V V V 12 9.012 10.8 13.2 115 104 12 8.012 10.2 13.2 13.5 245 24 9.024 21.6 24.6 460 24 8.024 20.4 26.4 41 135 230 8.230 52.2 196 253 4200 mA L 12.5 X-2017, www.findernet.com V Umax Resistance Consumption 5 22 SERIES 22 SERIES Modular monostable relays 20 A Outline drawing Type 22.21 Screw terminal Type 22.22 Screw terminal Type 22.23 Screw terminal Type 22.24 Screw terminal Accessories Adaptor for panel mounting, 17.5 mm wide 020.01 Sheet of marker tags, plastic, 24 tags, 9 x 17 mm 020.24 Separator for rail mounting, plastic, 9 mm wide 022.09 020.01 020.24 L X-2017, www.findernet.com 022.09 6 Please see general technical information
22.22.9.024.4000 价格&库存
很抱歉,暂时无法提供与“22.22.9.024.4000”相匹配的价格&库存,您可以联系我们找货
  • 1+310.12407
库存:288
22.22.9.024.4000
  • 1+416.103141+53.94205
  • 10+370.6179710+48.04553
  • 25+353.8881725+45.87674
  • 50+341.7267550+44.30018
  • 100+329.97547100+42.77679
  • 250+315.05163250+40.84211
库存:273
22.22.9.024.4000
  • 2+533.392642+69.14702
  • 3+502.405933+65.13002
  • 5+360.366815+46.71660
  • 10+360.2534110+46.70190
库存:69
