36
SЕRIES
Miniature PCB relays
10 A
Burners, boilers
and furnaces
Jacuzzis and hot tubs
Washing machines
Hi-Fi systems
Refrigerators
Automation for
blinds, grilles
and shutters
Electronic
circuit boards
Electronic kits
FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
36 SERIES
Miniature PCB relays 10 A
36
SERIES
36.11-4011
Printed circuit mount 10 A relay
• New smaller size
• 1 Pole changeover contacts
• Miniature - “Sugar cube” package
• DC coil - 360 mW
• Wash tight: RT III
• Cadmium Free contact material
• RoHS conform
A
• 1 CO (SPDT), 10 A
• Sugar cube size
• PCB mount
Copper side view
Contact specification
Contact configuration
1 CO (SPDT)
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
10/15 (NO) - 5/10 (NC)
250/277
Rated load AC1
VA
2500 (NO) - 1250 (NC)
Rated load AC15 (230 V AC)
VA
500 (NO)
Single phase motor rating (230 V AC)
kW
0.37 (NO)
Breaking capacity DC1: 28 V
Minimum switching load
A
mW (V/mA)
Standard contact material
10 (NO)
500 (5/100)
AgSnO2
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
Rated power AC/DC
VA (50 Hz)/W
V DC
Operating range
3 - 5 - 6 - 9 - 12 - 18 - 24 - 48
—/0.36
AC
DC
(0.75…1.3)UN
Holding voltage
AC/DC
—/0.5 UN
Must drop-out voltage
AC/DC
—/0.1 UN
Mechanical life AC/DC
cycles
—/10 · 106
Electrical life at rated load AC1
cycles
50 · 103
Technical data
I-2017, www.findernet.com
Operate/release time
Insulation between coil
and contacts (1.2/50 µs)
Dielectric strength
between open contacts
Ambient temperature range
Environmental protection
ms
10/5
kV
3
V AC
°C
750
–40…+85
RT III
Approvals (according to type)
3
36 SERIES
36
SERIES
Ordering information
Example: 36 series miniature PCB relay, 1 CO (SPDT) - 10 A contacts, 12 V DC coil.
A
3 6 . 1
A
B
C
D
1 . 9 . 0 1 2 . 4
1
Series
Type
1 = PCB mount
A: Contact material
4 = AgSnO2
D: Special versions
1 = Wash tight (RT III)
B: Contact circuit
0 = CO (SPDT)
C: Options
1 = None
No. of poles
1 = 1 pole, 10 A
Coil version
9 = DC
Coil voltage
See coil specifications
Selecting features and options: only combinations in the same row are possible.
Preferred selections for best availability are shown in bold.
Type
Coil version
A
B
C
D
36.11
DC
4
1
Technical data
Insulation according to EN 61810-1
Nominal voltage of supply system
V AC 230/400
Rated insulation voltage
V AC 250
Pollution degree
2
Insulation between coil and contact set
Type of insulation
Basic
Overvoltage category
II
Rated impulse voltage
kV (1.2/50 µs) 4
Dielectric strength
V AC 2500
Insulation between open contacts
Type of disconnection
Dielectric strength
Micro-disconnection
V AC/kV (1.2/50 µs) 750/1.5
Other data
Shock resistance
g 10
Bounce time: NO/NC
ms 1/6
Vibration resistance (5…55 Hz): NO/NC
g 14/8
Power lost to the environment
without contact current
W 0.4
with rated current
W 1.4
mm ≥ 5
Recommended distance between relays mounted on PCB
4
36 SERIES
36
SERIES
F 36 - Electrical life (AC) v contact current
A
Cycles
Resistive load - cosϕ = 1
Inductive load - cosϕ = 0.4
Coil specifications
DC coil data
Nominal
voltage
R 36 - DC coil operating range v ambient temperature
Coil
code
Operating range
Umin
UN
V
Resistance
Rated coil
consumption
Umax
R
I at UN
Ω
V
V
3
9.003
2.2
3.9
25
120
mA
5
9.005
3.7
6.5
70
72
6
9.006
4.5
7.8
100
60
9
9.009
6.7
11.7
225
40
12
9.012
9
15.6
400
30
18
9.018
13.5
23.4
900
9.024
18
31.2
1600
15
48
9.048
36
62.4
6400
7.5
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
Please see general technical information
5
很抱歉,暂时无法提供与“36.11.9.012.4011”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+21.049391+2.72330
- 25+18.9531925+2.45210
- 100+16.76964100+2.16960
- 国内价格
- 25+26.86770
- 100+26.03460
- 200+25.60763
- 300+25.10777
- 国内价格
- 1+27.69040
- 25+26.86770
- 100+26.03460
- 200+25.60763
- 300+25.10777
