48.51.7.024.0050SPA.
    FINDER
    FINDER - 48.51.7.024.0050SPA. - General Purpose Relay, 48 Series, Interface, SPDT, 24 VDC, 10 A
48.51.7.024.0050SPA. 数据手册
48 Series - Relay interface modules 8 - 10 - 16 A Features 48.31 48.52 48.61 1 & 2 Pole relay interface modules, 15.8 mm wide. Ideal interface for PLC and electronic systems 48.31 - 1 Pole 10 A 48.52 - 2 Pole 8 A 48.61 - 1 Pole 16 A • AC coils or DC sensitive coils ejection of relay using plastic retaining clip • Supply status indication and EMC coil suppression module as standard • Identification label • UL Listed • 35 mm rail (EN 50022) mounting • Instant • • 1 pole 10 A 35 mm rail mounting 75.3 COM 11 17.5 17.5 2 pole 8 A 35 mm rail mounting • • 1 pole 16 A 35 mm rail mounting 21 11 COM 21 11 COM 21 11 COM 21 11 COM 24 14 NO 24 14 NO 24 14 NO 24 14 NO 22 12 NC 22 12 NC 22 12 NC 22 12 NC 14 NO 12 NC 12 NC 78.6 25.9 • COM 11 14 NO 60.9 • A2 A1 A2 — A1 AC 15.8 15.8 DC + A2 A1 A2 — A1 AC DC + A2 A1 A2 — AC A1 DC + 32 48 48.31 48.52/61 Contact specification 1 CO (SPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 1 CO (SPDT) 10/20 8/15 16/30 250/400 250/250 250/400 Rated load AC1 VA 2,500 2,000 4,000 Rated load AC15 (230 V AC) VA 500 400 750 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.3 0.55 10/0.3/0.12 8/0.3/0.12 16/0.3/0.12 300 (5/5) 300 (5/5) 500 (10/5) AgNi AgNi AgCdO 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 12 - 24 - 125 Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/sens. DC VA (50 Hz)/W Operating range AC 1.2/0.5 1.2/0.5 1.2/0.5 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN sens. DC (0.73…1.75)UN (0.73…1.75)UN (0.8…1.5)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN 0.2 UN /0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/— 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 200 · 10 100 · 10 100 · 103 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category V AC °C 3 3 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) 6 (8 mm) 1,000 1,000 1,000 –40…+70 –40…+70 –40…+70 IP 20 IP 20 IP 20 Approvals relay (according to type) 125 48 Series - Relay interface modules 8 - 10 - 16 A Features 48.62 2 Pole relay interface module, 15.8 mm wide. Ideal interface for PLC and electronic systems 48.62 - 2 Pole 10 A • DC sensitive coil ejection of relay using plastic retaining clip • Supply status indication and EMC coil suppression module as standard • Identification label • Cadmium Free contacts • UL Listed • 35 mm rail (EN 50022) mounting • Instant • • 2 pole 10 A 35 mm rail mounting 75.3 60.9 17.5 17.5 21 11 COM 24 14 NO 22 12 NC 78.6 25.9 A2 — A1 DC 15.8 48 + 32 48.62 Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 10/20 250/400 Rated load AC1 VA 2,500 Rated load AC15 (230 V AC) VA 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) 0.37 10/0.3/0.12 300 (5/5) AgNi Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/sens. DC VA (50 Hz)/W Operating range AC — 12 - 24 - 125 —/0.5 — sens. DC (0.8…1.5)UN Holding voltage AC/DC —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN Mechanical life AC/DC cycles —/20 · 106 Electrical life at rated load AC1 cycles 100 · 103 Technical data Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category Approvals relay (according to type) 126 V AC °C 12/12 (DC) 6 (8 mm) 1,000 –40…+70 IP 20 48 Series - Relay interface modules 8 - 10 - 16 A Ordering information Example: 48 series, 35 mm rail (EN 50022) mount relay interface module, 2 CO (DPDT) 8 A contacts, 24 V sensitive DC coil, green LED + diode. 4 8 . 5 A B C D 2 . 7 . 0 2 4 . 0 0 5 0 Series Type 3 = 35 mm rail mount 5 = 35 mm rail mount 6 = 35 mm rail mount A: Contact material 0 = Standard D: Special versions 0 = Standard B: Contact circuit 0 = CO (nPDT) C: Options 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC: green LED + Varistor No. of poles 1 = 1 pole for 48.31, 10 A 48.61, 16 A 2 = 2 pole for 48.52, 8 A 48.62, 10 A, DC only Coil version 7 = Sensitive DC 8 = AC (50/60 Hz) Coil voltage see coil specifications 48 Technical data Insulation Insulation according to EN 61810-1 ed. 2 48.31/61/62 48.52 insulation rated voltage rated impulse withstand voltage V 250 kV 4 48.31/52/61/62 250 400 4 4 pollution degree 3 2 2 overvoltage category III III III Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) Dielectric strength between open contacts V AC 1,000 Dielectric strength between adjacent contacts V AC 2,000 (48.52); 2,500 (48.62) Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) Other data EN 61000-4-5 level 3 (2 kV) Bounce time: NO/NC ms 2/5 Vibration resistance (5…55)Hz, max. ± 1 mm: NO/NC Power lost to the environment without contact current with rated current Wire strip length Screw torque Max. wire size g/g 10/4 (for 1 pole) 15/3 (for 2 pole) W 0.7 W 1.2 (48.31) 1.3 (48.52) 1.2 (48.61) 1.2 (48.62) mm 8 Nm 0.5 solid cable stranded cable mm2 1x6 / 2x2.5 1x4 / 2x2.5 AWG 1x10 / 2x14 1x12 / 2x14 127 48 Series - Relay interface modules 8 - 10 - 16 A Contact specification F 48 - Electrical life (AC) v contact current Types 48.31/61 F 48 - Electrical life (AC) v contact current Type 48.62 7 7 10 Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 6 Cycles Cycles 10 10 6 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 limit for 48.31 5 5 10 10 0 4 8 12 0 16 (A) 4 8 12 16 (A) F 48 - Electrical life (AC) v contact current Types 48.52 7 Cycles 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 5 48 10 0 4 2 6 8 (A) H 48 - Maximum DC1 breaking capacity Types 48.31/52/61 10 6 4 20 48.61 current limit 48.31 current limit 48.52 current limit 2 DC breaking current (A) DC breaking current (A) 20 H 48 - Maximum DC1 breaking capacity Type 48.62 2 x 48.52 contacts in series 1 0.2 single contact 60 100 140 180 220 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 128 2 2 x 48.62 contacts in series 1 0.2 single contact 0.1 0.1 20 10 6 4 20 60 100 140 180 220 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 48 Series - Relay interface modules 8 - 10 - 16 A Coil specifications DC coil data (0.5 W sensitive) Nominal voltage UN V 12 24 125 AC coil data Coil code Operating range Umin* V 8.8 17.5 92 7.012 7.024 7.125 Rated coil consumption I at UN mA 41 22.2 4 Umax V 21 42 218 Nominal voltage UN V 12 24 110 120 230 *Umin = 0.8 UN for 48.61 and 48.62 R 48 - DC coil operating range v ambient temperature U 2.0 UN 48.61/62 Operating range Umin V 9.6 19.2 88 96 184 8.012 8.024 8.110 8.120 8.230 Rated coil consumption I at UN (50Hz) mA 90.5 46 10.1 11.8 7.0 Umax V 13.2 26.4 121 132 253 R 48 - AC coil operating range v ambient temperature U 2.0 UN 48.31/52 1 1.5 Coil code 1.5 1 1.0 1.0 48.61/62 2 2 48.31/52 0.5 0.5 -20 0 20 40 60 -20 80 (°C) 20 40 60 80 (°C) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Combinations 0 Code Type of socket Type of relay Module Retaining clip 48.31 95.03 40.31 99.02 095.01 48.52 95.05 40.52 99.02 095.01 48.61 95.05 40.61 99.02 095.01 48.62 95.05 44.62 99.02 095.01 48 Accessories 8-way jumper link 095.18 Rated values 10 A - 250 V 095.18 3.3 110.5 15 15.8 15.8 15.8 15.8 15.8 15 Sheet of marker tags, plastic, 72 tags, 6x12 mm 10.3 7 5.1 060.72 060.72 129 48 Series - Relay interface modules 8 - 10 - 16 A Packaging codes How to code and identify retaining clip and packaging options for relay interface module. Code options according to the last three letters: 4 8 . 5 2 . 7 . 0 2 4 . 0 0 5 0 S P A A B Standard packaging Blister packaging SP Plastic retaining clip 48 130
48.51.7.024.0050SPA. 价格&库存
很抱歉,暂时无法提供与“48.51.7.024.0050SPA.”相匹配的价格&库存,您可以联系我们找货
