653181100300
653181100300
    FINDER
    FINDER - 653181100300 - Power Relay, SPST-NO, 110 VAC, 30 A, 65 Series, Panel Mount
653181100300 数据手册
65 SЕRIES Power relays 20 - 30 A Infrared and microwave ovens Industrial washing machines Burners, boilers and furnaces Jacuzzis and hot tubs Power generators Panels for electrical distribution Back-up generators Industrial motors FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 65 SERIES Power relays 20 - 30 A 65 SERIES 65.31 20 A Power relays 1 NO + 1 NC (SPST-NO + SPST-NC) 65.61 Type 65.31  - Flange mount and Faston 250 connections Type 65.61  - PCB mount A • AC coils & DC coils • Cadmium Free option available • 20 A rated contacts • Faston 250 (6.3 x 0.8 mm) connection • Flange mount • 20 A rated contacts • PCB mount • Bifurcated terminals * With the AgSnO2 material the maximum peak current is 120 A - 5 ms on NO contact. For UL ratings see: “General technical information” page V For outline drawing see page 7 Copper side view Contact specification Contact configuration 1NO + 1NC (SPST-NO+SPST-NC) 1NO + 1NC (SPST-NO+SPST-NC) Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  A V AC 20/40* 20/40* 250/400 250/400 VA 5000 5000 Rated load AC15 (230 V AC)  VA 1000 1000 Single phase motor rating (230 V AC)  kW 1.1 1.1 Breaking capacity DC1: 30/110/220 V  A Rated load AC1  Minimum switching load  mW (V/mA) Standard contact material 20/0.8/0.5 20/0.8/0.5 1000 (10/10) 1000 (10/10) AgCdO AgCdO Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC  VA (50 Hz)/W 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400 6 - 12 - 24 - 48 - 60 - 110 - 125 - 220 2.2/1.3 2.2/1.3 AC (0.8…1.1)UN (0.8…1.1)UN DC (0.85…1.1)UN (0.85…1.1)UN Holding voltage  AC/DC 0.8 UN / 0.6 UN 0.8 UN / 0.6 UN Must drop-out voltage  AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life AC/DC  cycles 10 · 106 / 30 · 106 10 · 106 / 30 · 106 Electrical life at rated load AC1  cycles 80 · 10 80 · 103 ms 10/12 10/12 kV 4 4 Operating range Technical data II-2018,www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 μs)  Dielectric strength between open contacts  Ambient temperature range  Environmental protection V AC °C 3 1500 1500 –40…+75 –40…+75 RT I RT I Approvals (according to type) 3 65 SERIES 65 SERIES Power relays 20 - 30 A 65.31-0300 30 A Power relays 1 NO (SPST-NO) 65.61-0300 Type 65.31-0300  - Flange mount and Faston 250 connections Type 65.61-0300 - PCB mount A • ≥ 3 mm contact gap • AC coils & DC coils • Cadmium Free option available • 30 A rated contacts • Faston 250 (6.3 x 0.8 mm) connection • Flange mount • 30 A rated contacts • PCB mount • Bifurcated terminals * Distance between contacts ≥ 3 mm (EN 60335-1). ** With the AgSnO2 material the maximum peak current is 120 A - 5 ms on NO contact. Copper side view For UL ratings see: “General technical information” page V For outline drawing see page 7 Contact specification Contact configuration Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  1 NO (SPST-NO), ≥ 3 mm* 1 NO (SPST-NO), ≥ 3 mm* A 30/50** 30/50** V AC 250/400 250/400 VA 7500 7500 Rated load AC15 (230 V AC)  VA 1250 1250 Single phase motor rating (230 V AC)  kW 1.5 1.5 Breaking capacity DC1: 30/110/220 V  A 30/1.1/0.7 30/1.1/0.7 1000 (10/10) 1000 (10/10) AgCdO AgCdO Rated load AC1  Minimum switching load  mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC  VA (50 Hz)/W 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 2.2/1.3 2.2/1.3 AC (0.8…1.1)UN (0.8…1.1)UN DC (0.85…1.1)UN (0.85…1.1)UN Holding voltage  AC/DC 0.8 UN / 0.6 UN 0.8 UN / 0.6 UN Must drop-out voltage  AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life AC/DC  cycles 10 · 106 / 30 · 106 10 · 106 / 30 · 106 Electrical life at rated load AC1  cycles 50 · 10 50 · 103 ms 15/4 15/4 kV 4 4 Operating range Operate/release time  Insulation between coil and contacts (1.2/50 μs)  Dielectric strength between open contacts  Ambient temperature range  Environmental protection Approvals (according to type) 4 V AC °C 3 2500 2500 –40…+75 –40…+75 RT I RT I II-2018,www.findernet.com Technical data 65 SERIES Power relays 20 - 30 A 65 SERIES Ordering information Example: 65 series power relay, PCB with bifurcated terminals, 1 NO + 1 NC (SPST-NO + SPST-NC) contact, 12 V DC coil. 6 5 . 6 A B C D 1 . 9 . 0 1 2 . 0 0 0 0 Series A: Contact material 0 = Standard AgCdO 4 = AgSnO2 Type 3 = Faston 250 (6.3 x 0.8 mm) with rear flange mount 6 = PCB with bifurcated terminals D: Special versions 0 = Standard 9 = Type 65.31 without rear flange mount B: Contact circuit 0 = 1 NO + 1 NC (SPST-NO + SPST-NC) 3 = NO (≥ 3 mm contact gap) No. of poles 1 = 1 NO + 1 NC (SPST-NO + SPST-NC) A C: Options 0 = None Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 65.31 AC-DC 0-4 0-3 0 0-9 65.61 AC-DC 0-4 0-3 0 0 Technical data Insulation according to EN 61810-1 1 NO + 1 NC Nominal voltage supply system  V AC 230/400 Rated insulation voltage  V AC 250 Pollution degree 3 1 NO 230/400 400 250 400 2 3 2 Insulation between coil and contact set Type of insulation Basic Basic III III kV (1.2/50 μs) 4 4 Overvoltage category Rated impulse voltage  Dielectric strength  V AC 2500 2500 Insulation between open contacts Type of disconnection Micro-disconnection Full-disconnection — III kV (1.2/50 μs) — 4 Overvoltage category Rated impulse voltage  Dielectric strength  V AC/kV (1.2/50 μs) 1500/2 2500/4 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV (1.2/50 µs) 4 Other data II-2018,www.findernet.com Bounce time: NO/NC  ms 5/6 (1 NO + 1 NC) Vibration resistance (10…150)Hz: NO/NC  g 20/13 Shock resistance  g 20 Power lost to the environment without contact current  W 1.3 with rated current  W 2.1 (65.31, 65.61) Recommended distance between relays mounted on PCB  7/— (1 NO) 3.1 (65.31/.61.0300) mm ≥ 5 5 65 SERIES Power relays 20 - 30 A 65 SERIES Contact specification F 65 - Electrical life (AC) v contact current H 65 - Maximum DC1 breaking capacity Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 limit for 1NO+1NC types DC breaking current (A) A 1 normally open type 1 normally open + 1 normally closed type DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 80 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data AC coil data Coil code Operating range Umin UN V Resistance Rated coil consumption Nominal voltage Umax R I at UN UN Ω mA V Coil code Operating range Umin Resistance Rated coil consumption Umax R I at UN (50 Hz) Ω V V V V 6 9.006 5.1 6.6 28 214 6 8.006 4.8 6.6 12 9.012 10.2 13.2 110 109 12 8.012 9.6 13.2 24 9.024 20.4 26.4 445 48 9.048 40.8 52.8 1770 60 9.060 51 110 9.110 93.5 mA 4.6 19 183 54 24 8.024 19.2 26.4 74 90 27.1 48 8.048 38.4 52.8 290 47 66 2760 21.7 60 8.060 48 66 450 37 121 9420 11.7 110 8.110 88 121 1600 20 125 9.125 106 138 12000 10.4 120 8.120 96 132 1940 18.6 220 9.220 187 242 37300 5.8 230 8.230 184 253 7250 10.5 240 8.240 192 264 8500 400 8.400 320 440 19800 R 65 - DC coil operating range v ambient temperature R 65 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 6 367 9.2 6 II-2018,www.findernet.com Nominal voltage 65 SERIES Power relays 20 - 30 A 65 SERIES Outline drawings Type 65.31 Type 65.61 Type 65.31- 0300 Type 65.61- 0300 A Accessories Top flange mount for types 65.31.xxxx.xxx9 065.05 065.05 065.05 065.05 with relay 065.05 with relay Top 35 mm rail (EN 60715) mount for types 65.31.xxxx.xxx9 065.07 065.07 065.07 065.07 with relay 065.07 with relay Rear 35 mm rail (EN 60715) mount for types 65.31.xxxx.xxx9 065.08 II-2018,www.findernet.com 065.08 065.08 065.08 with relay 065.08 with relay Please see general technical information 7
653181100300 价格&库存
很抱歉,暂时无法提供与“653181100300”相匹配的价格&库存,您可以联系我们找货
