78.36.1.230.2401
78.36.1.230.2401
    FINDER
78.36.1.230.2401 数据手册
78 SERIES Switch mode power supplies 78 SERIES 78.12….2400 12 W and 36 W Low profile Modular DC Power Supplies for electrical cabinets 78.12….1200 78.36 Type 78.12….2400 --Output 24 V DC, 12 W --17.5 mm (1 module) x 61 mm deep Type 78.12….1200 --Output 12 V DC, 12 W --17.5 mm (1 module) x 61 mm deep Type 78.36 --Output 24 V DC, 36 W --Input fuse: Easily replaceable plus spare --70 mm (4-module) wide x 61 mm deep • 24 V DC, 12 W output • Low ( 10 > 10 > 20 with 260 V AC input ms > 90 > 90 > 100 110…240 110…240 110…240 220 220 220 100…265*** 100…265*** 100…265*** 140…370 140…370 140…370 57.5 Input specification Nominal voltage (UN) V AC (50/60 Hz) V DC (not polarized) Operating range V AC (50/60 Hz) V DC Max power consumption  VA 28.2 32 (@ 100 V AC, 50 Hz) W 14.2 17.2 43 Stand-by power consumption W < 0.4 < 0.4 < 0.4 0.50 0.53 0.74 0.6 Power factor Max current consumption (@ 88 V AC) A 0.25 0.30 Max. inrush current (peak @ 265 V) for 3 ms A 10 10 12 — — 1A-T Replaceable input fuse Technical data Efficiency (@ 230 V AC) % MTTFh II-2016, www.findernet.com Start-up delay s Dielectric strength between input/output V AC Dielectric strength between input/PE V AC Ambient temperature range**** Protection category °C 85 87 86 > 400 · 103 > 400 · 103 > 600 · 103 150 110…240 110…240 Input specification Nominal voltage (UN) V AC (50/60 Hz) V DC (not polarized) Operating range 220 220 V AC (50/60 Hz) 88…265 88…265 V DC 140…370 140…370 Max power consumption  VA 90 89 (@ 100 V AC, 50 Hz) W 67.5 58.3 Stand-by power consumption W < 0.4 < 0.4 0.75 0.65 0.85 Power factor Max current consumption (@ 88 V AC) A 0.9 Max. inrush current (peak @ 265 V) for 3 ms A 30 30 1.6 A - T 1.6 A - T Replaceable input fuse Technical data Efficiency (@ 230 V AC) % MTTFh Start-up delay 90 > 400 · 103 30 with 260 V AC input ms > 130 > 150 110…240 110…240 F Input specification Nominal voltage (UN) V AC (50/60 Hz) V DC (not polarized) Operating range 220 220 V AC (50/60 Hz) 88…265 88…265 V DC 140…370 140…370 Max power consumption  VA 90 89 (@ 100 V AC, 50 Hz) W 67.5 58.3 Stand-by power consumption W < 0.4 < 0.4 0.75 0.65 0.85 Power factor Max current consumption (@ 88 V AC) A 0.9 Max. inrush current (peak @ 265 V) for 3 ms A 30 30 1.6 A - T 1.6 A - T Replaceable input fuse Technical data Efficiency (@ 230 V AC) % II-2016, www.findernet.com MTTFh Start-up delay 90 > 400 · 103 10 > 20 with 260 V AC input ms > 80 > 20 120…240 110…240 220 110…240 Input specification Nominal voltage (UN) V AC (50/60 Hz) V DC Operating range V AC (50/60 Hz) V DC Drop out DC Voltage 110…265 88…265 155…275 (polarized) 95…275 (non-polarized) V 140 (with Ioutput = 2.5 A) 80 Max power consumption VA 195 (@ 60 Hz) 145 (@ 50 Hz) (@ minimum V AC operating range) W 137 (@ 60 Hz) 145 (@ 50 Hz) Stand-by power consumption W < 2.1 < 3.3 0.7 0.998 1.6 (@ 88 V AC) Power factor Max current consumption A 1.7 (@ 110 V AC) Max. inrush current (peak @ 265 V) for 3 ms A 10 12 2.5 A - T 2.5 A - T Replaceable input fuse Technical data Efficiency (@ 230 V AC) % MTTFh Start-up delay 89 > 400 · 103 20 with 260 V AC input ms > 20 Input specification Nominal voltage (UN) Operating range V AC (50/60 Hz) 110…240 V DC 110…240 V AC (50/60 Hz) V DC Drop out DC Voltage 88…265 90…275 (non-polarised) V 80 Max power consumption VA 275 (@ 50 Hz) (@ minimum V AC operating range) W 274 (@ 50 Hz) Stand-by power consumption (@ 88 V) W Power factor ≤ 2.8 0.995 Max current consumption A Max. inrush current (peak @ 265 V) for 3 ms A Replaceable input fuse 3.0 (@ 88 V AC) 12 3.15 A - T Technical data Efficiency (@ 230 V AC) % II-2016, www.findernet.com MTTFh Start-up delay s 93 > 400 · 103
78.36.1.230.2401 价格&库存
很抱歉,暂时无法提供与“78.36.1.230.2401”相匹配的价格&库存,您可以联系我们找货
  • 5+569.068165+73.61766
