90.03SMA
90.03SMA
    FINDER
    Module
90.03SMA 数据手册
60 SERIES 60 Series - General purpose relays 6 - 10 A Features 60.12 60.13 Plug-in mount 10 A General purpose relay 2 & 3 pole changeover contacts • Cadmium Free contacts (preferred version) • AC coils & DC coils • UL Listing (certain relay/socket combinations) • Contact material options • Lockable test button with mechanical flag indicator (preferred version) • 90 series sockets • Coil EMC suppression • Timer accessories 86 series • European Patent A • • • 2 pole, 10 A power contacts 8 pin plug-in • • 3 pole, 10 A power contacts 11 pin plug-in FOR UL RATINGS SEE: “General technical information” page V Contact specification Contact configuration 2 CO (DPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 3 CO (3PDT) 10/20 10/20 250/400 250/400 Rated load AC1 VA 2,500 2,500 Rated load AC15 (230 V AC) VA 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 10/0.4/0.15 10/0.4/0.15 500 (10/5) 500 (10/5) AgNi AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 V DC Rated power AC/DC Operating range VA (50 Hz)/W AC 2.2/1.3 2.2/1.3 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 DC Technical data Mechanical life AC/DC Electrical life at rated load AC1 IV-2014, www.findernet.com Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 3 200 · 10 200 · 103 11/4 11/4 4 3.6 1,000 1,000 –40…+70 –40…+70 RT I RT I Approvals (according to type) 1 60 SERIES 60 Series - General purpose relays 6 - 10 A Features 60.13 - 5200 Plug-in mount - 6 A Bifurcated contacts for low level switching 2 & 3 pole changeover contacts Cadmium Free contacts (Gold plated Silver Nickel) • AC coils & DC coils • Lockable test button with mechanical flag indicator (preferred version) • 90 series sockets • Coil EMC suppression • Timer accessories 86 series • European Patent • • • • 2 pole, 6 A bifurcated contacts 8 pin plug-in • • 3 pole, 6 A bifurcated contacts 11 pin plug-in FOR UL RATINGS SEE: “General technical information” page V Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 3 CO (3PDT) 6/10 6/10 250/400 250/400 Rated load AC1 VA 1,500 1,500 Rated load AC15 (230 V AC) VA 250 250 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.185 0.185 6/0.3/0.12 6/0.3/0.12 50 (5/5) 50 (5/5) AgNi + Au bifurcated contacts AgNi + Au bifurcated contacts Coil specification Nominal voltage (UN) V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC DC 2.2/1.3 2.2/1.3 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/50 · 106 Electrical life at rated load AC1 cycles 250 · 103 250 · 103 11/4 11/4 4 3.6 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) 2 V AC °C 1,000 1,000 –40…+70 –40…+70 RT I RT I IV-2014, www.findernet.com A 60.12 - 5200 60 SERIES 60 Series - General purpose relays 6 - 10 A Features 60.62 60.63 Flange mount - General purpose relay 10 A A Faston 187, 4.8x0.8 mm 2 & 3 pole changeover contacts • AC coils & DC coils • Cadmium Free contacts • Contacts material options • • • • 2 pole, 10 A power contacts Flange mount/Faston 187 • • 3 pole, 10 A power contacts Flange mount/Faston 187 FOR UL RATINGS SEE: “General technical information” page V Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 3 CO (3PDT) 10/20 10/20 250/400 250/400 Rated load AC1 VA 2,500 2,500 Rated load AC15 (230 V AC) VA 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 10/0.4/0.15 10/0.4/0.15 500 (10/5) 500 (10/5) AgNi AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC DC 2.2/1.3 2.2/1.3 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 Technical data Mechanical life AC/DC Electrical life at rated load AC1 IV-2014, www.findernet.com Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C 3 200 · 10 200 · 103 11/4 11/4 4 3.6 1,000 1,000 –40…+70 –40…+70 RT I RT I Approvals (according to type) 3 60 SERIES 60 Series - General purpose relays 6 - 10 A Ordering information Example: 60 series plug-in relay, 3 CO (3PDT), 12 V DC coil, test button and mechanical indicator. A 6 0 . 1 A B C D 3 . 9 . 0 1 2 . 0 0 4 0 Series A: Contact material 0 = Standard 5 = AgNi + Au Type 1 = 8/11 pin plug-in 6 = Faston 187 (4.8x0.8 mm) with flange mount B: Contact circuit 0 = CO (nPDT) 2 = Bifurcated contacts 60.12/13 - 6 A only No. of poles 2 = 2 pole 3 = 3 pole Coil version 4 = Current sensing (60.12/13 only) 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version 60.12/13 AC AC AC AC DC DC DC DC current sensing 60.62/63 AC-DC A 0 0 5 5 0 0 5 5 0 0-5 B 0 0 000 0 000 0 2 2 2 2 C 0-2-3-4-5 54 0-2-3-4-5 54 0-2-4-6-7 74 0-2-4-6-7 74 4 0 D: Special versions 0 = Standard C: Options 0 = None 2 = Mechanical indicator 3 = LED (AC) 4 = Lockable test button + mechanical indicator 5* = Lockable test button + LED (AC) 54* = Lockable test button + LED (AC) + mechanical indicator 6* = LED + diode (DC, polarity positive to pin 2) 7* = Lockable test button + LED + diode (DC, polarity positive to pin 2) 74* = Lockable test button + LED + diode (DC, polarity positive to pin 2) + mechanical indicator * Options not available for 220 V DC and 400 V AC versions. D 0 / 0 / 0 / 0 / 0 0 Descriptions: Options and Special versions 2 4 N T E T The dual-purpose Finder test button can be used in two ways: Case 1) The plastic pip (located directly above the test button) remains intact. In this case, when the test button is pushed, the contacts operate. When the test button is released the contacts return to their former state. Case 2) The plastic pip is broken-off (using an appropriate cutting tool). In this case, (in addition to the above function), when the test button is pushed and rotated, the contacts are latched in the operating state, and remain so until the test button is rotated back to its former position. In both cases ensure that the test button actuation is swift and decisive. IV-2014, www.findernet.com 3 P A PEAN PEAN Lockable test button and mechanical flag indicator (0040, 0050, 0054, 0070, 0074) 1 O EUR EUR C: Option 6, 7, 74 LED + diode (DC, polarity positive to pin 2) O C: Option 3, 5, 54 LED (AC) 60 SERIES 60 Series - General purpose relays 6 - 10 A Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC Rated insulation voltage V AC Pollution degree Insulation between coil and contact set Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC Insulation between adjacent contacts Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC Insulation between open contacts Type of disconnection Dielectric strength V AC/kV (1.2/50 µs) Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 Surge (1.2/50 µs) on A1 - A2 (differential mode) Other data Bounce time: NO/NC ms Vibration resistance (5…55)Hz: NO/NC g Shock resistance g Power lost to the environment without contact current W with rated current W 2 pole 230/400 250 3 3 pole 230/400 250 3 400 2 A 400 2 Basic III 4 2,000 Basic III 3.6 2,000 Basic III 4 2,000 Basic III 3.6 2,000 Micro-disconnection 1,000/1.5 Micro-disconnection 1,000/1.5 EN 61000-4-4 EN 61000-4-5 level 4 (4 kV) level 4 (4 kV) 1/4 22/22 20 1.3 2.7 (60.12, 60.62) 1.3 3.4 (60.13, 60.63) Contact specification H 60 - Maximum DC1 breaking capacity Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 contacts in series DC breaking current (A) Cycles F 60 - Electrical life (AC) v contact current DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. AC coil data Coil specifications IV-2014, www.findernet.com DC coil data Nominal voltage UN V 6 12 24 48 60 110 125 220 Coil code 9.006 9.012 9.024 9.048 9.060 9.110 9.125 9.220 Operating range Umin V 4.8 9.6 19.2 38.4 48 88 100 176 Umax V 6.6 13.2 26.4 52.8 66 121 138 242 Resistance Rated coil consumption R I at UN Ω mA 28 214 110 109 445 53.9 1,770 27.1 2,760 21.7 9,420 11.7 12,000 10.4 37,300 5.8 Nominal voltage UN V 6 12 24 48 60 110 120 230 240 400 Coil code 8.006 8.012 8.024 8.048 8.060 8.110 8.120 8.230 8.240 8.400 Operating range Umin V 4.8 9.6 19.2 38.4 48 88 96 184 192 320 Umax V 6.6 13.2 26.4 52.8 66 121 132 253 264 440 Resistance Rated coil consumption R I at UN (50Hz) Ω mA 4.6 367 19 183 74 90 290 47 450 37 1,600 20 1,940 18.6 7,250 10.5 8,500 9.2 19,800 6 5 60 SERIES 60 Series - General purpose relays 6 - 10 A Coil specifications R 60 - DC coil operating range v ambient temperature R 60 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. A Current sensing version Current sensing DC coil data Coil code 4202 4182 4162 4142 4122 4102 4092 4062 4032 4012 L N Imin (A) 1.7 1.5 1.4 1.2 1.0 0.85 0.8 0.5 0.25 0.085 IN (A) 2.0 1.8 1.6 1.4 1.2 1.0 0.9 0.6 0.3 0.1 Imax (A) 2.4 2.2 1.9 1.7 1.4 1.2 1.1 0.7 0.4 0.15 R (Ω) 0.15 0.19 0.24 0.31 0.42 0.61 0.75 1.70 6.70 61 IN (A) 2.5 1.8 1.6 1.2 1.0 0.5 0.4 0.3 0.2 0.1 Imax (A) 3.0 2.2 1.9 1.4 1.2 0.6 0.5 0.4 0.25 0.15 R (Ω) 0.05 0.10 0.12 0.22 0.32 1.28 2.00 3.57 8.0 32.1 Current sensing AC coil data Typical application with current sensing relays. An open circuit filiment of lamp L1 is detected by the current sensing relay coil (K1) which causes the back-up safety lamp L2 to be energised, and indication of failure at the control panel via lamp S1. Example: navigation light. L1 = Light L2 = Safety light S1 = Control light K1 = Relay Coil code 4251 4181 4161 4121 4101 4051 4041 4031 4021 4011 Imin (A) 2.1 1.5 1.4 1.0 0.85 0.42 0.34 0.25 0.17 0.085 Other types of current sensing relays are available on request. Sheet of marker tags for relay types 60.12 and 60.13, plastic, 72 tags, 6x12 mm 060.72 6 060.72 IV-2014, www.findernet.com Accessories 90 Series - Socket overview for 60 series relays Module Socket 99.02 90.02 90.03 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Double A1 terminal Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Metal retaining clip Module Socket 99.01 90.20 90.21 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Metal retaining clip Module Socket Relay Description — 90.82.3 60.12 Screw terminal (Box clamp) socket — 90.83.3 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.22 — 90.23 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.26 — 90.27 Relay Description 60.12 Screw terminal (Plate clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.12 — 90.13 Relay Description 60.12 Flange mount solder socket 60.13 Mounting M3 screw fixing Accessories — Module — — — — Relay Description 60.12 PCB socket 60.12 60.13 60.13 Mounting PCB Accessories — 90.03 60 SERIES A See page 8 90.21 See page 9 90.83.3 See page 10 90.23 See page 10 90.26 See page 11 90.12 See page 1 90.15 IV-2014, www.findernet.com See page 12 Socket 90.14 90.14.1 90.15 90.15.1 7 60 SERIES Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip 90.03 6-way jumper link Identification tag Approvals (according to type): Modules (see table below) Timer modules (see table below) Technical data Rated values Dielectric strength Protection category Certain relay/socket Ambient temperature combinations Screw torque Wire strip length Max. wire size for 90.02 and 90.03 sockets 90.02 Blue 60.12 N T E PEAN 090.06 86.00 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 8 90.03.0 Black °C Nm mm 10 A - 250 V 2 kV AC IP 20 –40...+70 0.6 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x4 / 2x2.5 1x12 / 2x14 T 6-way jumper link for 90.02 and 90.03 sockets Rated values 090.06 (blue) 10 A - 250 V 090.06.0 (black) Approvals (according to type): 86 series timer modules Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.00.0.240.0000 86.30.0.024.0000 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 90.02 and 90.03 sockets Diode (+A1, standard polarity) (6...220)V DC 99.02.3.000.00 LED (6...24)V DC/AC 99.02.0.024.59 LED (28...60)V DC/AC 99.02.0.060.59 LED (110...240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.02.9.220.99 LED + Varistor (6...24)V DC/AC 99.02.0.024.98 LED + Varistor (28...60)V DC/AC 99.02.0.060.98 LED + Varistor (110...240)V DC/AC 99.02.0.230.98 RC circuit (6...24)V DC/AC 99.02.0.024.09 RC circuit (28...60)V DC/AC 99.02.0.060.09 RC circuit (110...240)V DC/AC 99.02.0.230.09 Residual current by-pass (110...240)V AC 99.02.8.230.07 IV-2014, www.findernet.com P A 90.03 Blue 60.13 PEAN EUR EUR O 90.02.0 Black 090.33 090.06 090.00.2 99.02 86.00, 86.30 mm2 AWG O A 90 Series - Sockets and accessories for 60 series relays 60 SERIES 90 Series - Sockets and accessories for 60 series relays 90.21 Approvals (according to type): Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.20 and 90.21 sockets mm2 AWG 90.20 99.01 Approvals (according to type): * Modules in Black housing are available on request. 90.20.0 Black 90.21 Blue 60.13 90.21.0 Black A 090.33 99.01 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 90.21 99.01 coil indication and EMC suppression modules for 90.20 and 90.21 sockets See technical data page 215/216 Diode (+A1, standard polarity) (6...220)V DC Diode (+A2, non-standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Diode (+A2, non-standard polarity) (6...24)V DC LED + Diode (+A2, non-standard polarity) (28...60)V DC LED + Diode (+A2, non-standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC Blue* 99.01.3.000.00 99.01.2.000.00 99.01.0.024.59 99.01.0.060.59 99.01.0.230.59 99.01.9.024.99 99.01.9.060.99 99.01.9.220.99 99.01.9.024.79 99.01.9.060.79 99.01.9.220.79 99.01.0.024.98 99.01.0.060.98 99.01.0.230.98 99.01.0.024.09 99.01.0.060.09 99.01.0.230.09 99.01.8.230.07 IV-2014, www.findernet.com Green LED is standard. Red LED available on request. 90.20 Blue 60.12 9 SERIES 90 Series - Sockets and accessories for 60 series relays A 90.83.3 Approvals (according to type): Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip Technical data Rated values Dielectric strength Protection category Ambient temperature Screw torque Max. wire size for 90.82.3 and 90.83.3 sockets 90.82.3 Blue 60.12 90.23 10 A - 250 V 2 kV AC IP 20 °C –40…+70 Nm 0.8 solid wire mm2 1x6 / 2x4 AWG 1x10 / 2x14 Screw (Box clamp) terminal socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max wire size for 90.22 and 90.23 sockets mm2 AWG 90.22 10 90.83.3 Blue 60.13 90.83.30 Black 090.33 90.82.3 Approvals (according to type): 90.82.30 Black stranded wire 1x6 / 2x4 1x10 / 2x14 90.83.3 90.22 Blue 60.12 90.23 Blue 60.13 090.33 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 7 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 90.23 IV-2014, www.findernet.com 60 60 SERIES 90 Series - Sockets and accessories for 60 series relays 90.26 Approvals (according to type): Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.26 and 90.27 sockets mm2 AWG 90.12 90.27 Blue 60.13 90.27.0 Black A 090.33 10 A - 250 V 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x2.5 1x12 / 2x14 stranded wire 1x4 / 2x2.5 1x12 / 2x14 90.12 (black) 60.12 °C 90.13 (black) 60.13 10 A - 250 V 2 kV AC –40…+70 IV-2014, www.findernet.com Approvals (according to type): 90.26.0 Black 90.27 90.26 Flange mount solder socket mount with M3 screw For relay type Technical data Rated values Dielectric strength Ambient temperature 90.26 Blue 60.12 11 60 SERIES 90 Series - Sockets and accessories for 60 series relays PCB socket A 90.15 Approvals (according to type): Blue Blue For relay type Technical data Rated values Dielectric strength Ambient temperature °C 90.14 90.14 (Ø 20.5 mm) 90.14.1 (Ø 17.5 mm) 60.12 90.15 (Ø 22 mm) 90.15.1 (Ø 19 mm) 60.13 10 A - 250 V 2 kV AC –40…+70 90.15 Packaging code How to code and identify retaining clip and packaging options for sockets. Example: 9 0 . 2 1 S M A A Standard packaging SM Metal retaining clip 1 Without retaining clip IV-2014, www.findernet.com 9 0 . 2 12
90.03SMA 价格&库存
很抱歉,暂时无法提供与“90.03SMA”相匹配的价格&库存,您可以联系我们找货
90.03SMA
    • 1+79.85733
    库存:18
    90.03SMA
      • 8+107.474798+13.90351
      • 10+98.7321010+12.77251
      • 20+91.6475120+11.85601
      库存:569
