93.01.0.024
93.01.0.024
    FINDER
    继电器 插口 DIN 轨道
93.01.0.024 数据手册
93 Series - Sockets and accessories for 34 series relays 93.01 Approvals (according to type): Certain relay/socket combinations 93.21 Approvals (according to type): 6 Screw terminal socket 35 mm (EN 60715) mounting Supply voltage Relay type Socket type 12 V AC/DC 34.51.7.012.xx10 93.01.0.024 24 V AC/DC 34.51.7.024.xx10 93.01.0.024 48 V AC/DC 34.51.7.048.xx10 93.01.0.060 60 V AC/DC 34.51.7.060.xx10 93.01.0.060 (110…125)V AC/DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.0.125 (220…240)V AC/DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.0.240 (110…125)V AC/DC* 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.3.125* (220…240)V AC* 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.3.240* (220…240)V AC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.8.240 6 V DC 34.51.7.005.xx10 or 34.81.7.005.xxxx 93.01.7.024 12 V DC 34.51.7.012.xx10 93.01.7.024 24 V DC 34.51.7.024.xx10 or 34.81.7.024.xxxx 93.01.7.024 48 V DC 34.51.7.048.xx10 93.01.7.060 60 V DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.01.7.060 Accessories 20-way jumper link 093.20 (see specification next page) Plastic separator 093.01 (see specification next page) Sheet of marker tags 093.64 (see specification next page) Technical data Rated values 6A - 250 V Dielectric strength 6 kV (1.2/50 µs) between coil and contacts Protection category IP 20 Ambient temperature (–40…+70)°C (UN ≤ 60 V), (–40…+55)°C (UN > 60 V) Screw torque Nm 0.5 Wire strip length mm 10 Max. wire size for 93.01 socket solid wire stranded wire mm2 1x2.5 / 2x1.5 1x2.5 / 2x1.5 AWG 1x14 / 2x16 1x14 / 2x16 * Leakage current suppression. Slim timed socket for 34 series (refer to 38 series data sheet for technical data) Output Supply voltage Type of relay 1 pole 6A, electromechanical relay 12 V AC/DC 34.51.7.012.0010 1 pole 6A, electromechanical relay 24 V AC/DC 34.51.7.024.0010 Type of socket 93.21.0.024 93.21.0.024 1 output 2A 24 V DC, solid state relay 1 output 2A 240 V AC, solid state relay 93.21.0.024 93.21.0.024 24 V AC/DC 24 V AC/DC 34.81.7.024.9024 34.81.7.024.8240 93 Series - Sockets and accessories for 34 series relays 93.51 Approvals (according to type): Certain relay/socket combinations Screwless terminal socket 35 mm (EN 60715) mounting Supply voltage Relay type Socket type 12 V AC/DC 34.51.7.012.xx10 93.51.0.024 24 V AC/DC 34.51.7.024.xx10 93.51.0.024 (110…125)V AC/DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.0.125 (220…240)V AC/DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.0.240 (110…125)V AC/DC* 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.3.125* (220…240)V AC* 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.3.240* (220…240)V AC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.8.240 12 V DC 34.51.7.012.xx10 93.51.7.024 24 V DC 34.51.7.024.xx10 or 34.81.7.024.xxxx 93.51.7.024 60 V DC 34.51.7.060.xx10 or 34.81.7.060.xxxx 93.51.7.060 Accessories 20-way jumper link 093.20 (see table below) Plastic separator 093.01 (see table below) Sheet of marker tags 093.64 (see table below) Technical data Rated values 6A - 250 V Dielectric strength 6 kV (1.2/50 µs) between coil and contacts Protection category IP 20 Ambient temperature (–40…+70)°C (UN ≤ 60 V), (–40…+55)°C (UN > 60 V) Wire strip length mm 10 Max. wire size for 93.51 socket solid wire stranded wire mm2 1x2.5 1x2.5 AWG 1x14 1x14 * Leakage current suppression. Accessories 20-way jumper link for 93.01 and 93.51 sockets 093.20 (blue) Rated values 36 A - 250 V Plastic separator for 93.01 and 93.51 sockets 093.01 093.20.0 (black) 093.20 Approvals (according to type): 093.01 Thickness 2 mm, required at the start and the end of a group of interfaces. Can be used for visual separation of groups. Must be used for: - protective separation of different voltages of neighbouring PLC interfaces according to VDE 0106-101 - protection of cut jumper links Sheet of marker tags, plastic, 64 tags, 6x10 mm 093.64 for 93.01 and 93.51 sockets 093.64 7 93 Series - Sockets and accessories for 34 series relays PCB socket with retaining and release clip 93.11 (blue) For relay type 34.51, 34.81 Technical data 93.11 Approvals (according to type): Rated values 6 A - 250 V Dielectric strength ≥ 6 kV (1.2/50 µs) between coil and contacts Protection category Ambient temperature IP 20 °C –40…+70 Retaining and release clip use: Copper side view A2 A1 8 12 11 14 (+) (A)
93.01.0.024 价格&库存
很抱歉,暂时无法提供与“93.01.0.024”相匹配的价格&库存,您可以联系我们找货
  • 1+112.576991+14.56356
  • 10+100.2978010+12.97505
  • 30+94.9041730+12.27731
  • 50+92.4950650+11.96565
  • 100+89.31864100+11.55473
  • 250+85.28447250+11.03285
  • 500+82.35218500+10.65352
  • 1000+79.518701000+10.28696
库存:344
93.01.0.024
  • 7+127.785397+16.53099
  • 25+91.8826325+11.88642
  • 50+88.1855450+11.40815
库存:56
93.01.0.024
  • 7+127.752017+16.52668
  • 25+91.8590925+11.88338
  • 50+88.1628150+11.40521
库存:56
93.01.0.024
  • 1+83.44608
库存:273
93.01.0.024
  • 6+145.912476+18.87601
  • 10+132.7984410+17.17951
  • 50+92.2689850+11.93640
库存:81
