9402SMA
9402SMA
    FINDER
    FINDER - 9402SMA - Relay Socket, DIN Rail, Panel, Screw, 14 Pins, 10 A, 250 V, 94 Series
9402SMA 数据手册
Search By Part Number 94 Series - Sockets and Accessories for 55 Series Relays Relay type 55.32 Colour BLUE BLACK BLUE 55.33 BLACK BLUE BLACK Clamp terminal socket: panel or 35 mm rail (EN 50022) mount retaining clip 094.71 supplied with socket packaging code SMA 94.02 94.02.0 94.03 94.03.0 94.04 94.04.0 Metal retaining clip 94.04 Approvals (according to type): 094.71 Plastic retaining and release clip 094.01 6-way jumper link for 94.02, 94.03 and 94.04 sockets 094.06 094.06.0 094.06 094.06.0 094.06 094.06.0 Identification tag 094.00.4 Modules (see table below) 86.10, 86.20 Sheet of marker tags for retaining and release clip 094.01 27 25.9 27 60.9 17.5 17.5 35.6 18.9 34.9 34.9 mm2 1x6 / 2x2.5 1x4 / 2x2.5 Ø3 76 Ø3 76 Ø3 Ø 3.2 Ø 3.2 21.5 27 34.9 RATED VALUES: 10 A - 250 V DIELECTRIC STRENGTH: ≥ 2 kV AC PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C SCREW TORQUE: 0.5 Nm WIRE STRIP LENGTH: 8 mm MAX WIRE SIZE: solid wire stranded wire 060.72 Ø 3.2 55 - U 99.02 Timer modules 76 GOST C ® 55.32, 55.34 AWG 1x10 / 2x14 1x12 / 2x14 32 41 12 11 9 COM 31 9 21 8 11 7 COM 41 12 31 11 21 10 11 9 COM 44 8 14 5 NO 34 6 24 5 14 4 NO 44 8 34 7 24 6 14 5 NO 42 4 12 1 NC 32 3 22 2 12 1 NC 42 4 32 3 22 2 12 1 NC A2 14 A1 13 35.5 094.01 A2 14 FOR 94.02, 94.03 AND 94.04 SOCKETS: A1 13 A2 14 COIL 94.02 6-way jumper link A1 13 COIL COIL 94.04 94.03 094.06 135 3.3 - RATED VALUES: 10 A - 250 V 10.3 7 5.1 094.06 0.75 26.25 27 86 Series Module Timers (see technical data pages 126/131) BLUE Mono-function: 12…24 V AC/DC; function AI; (1.5s…60min) 86.10.0.024.0000 Mono-function: 12…24 V AC/DC; function DI; (1.5s…60min) 86.20.0.024.0000 86.10 99.02 coil indication and EMC suppression modules (see technical data page 179) Diode** (+A1, standard polarity) (6...220) V DC Diode (+A2, non standard polarity) (6...220) V DC LED (6...24) V DC/AC 99.02 LED (28...60) V DC/AC Approvals LED (110...240) V DC/AC (according to type): LED + Diode** (+A1, standard polarity) (6...24) V DC ® LED + Diode** (+A1, standard polarity) (28...60) V DC GOST C US LED + Diode** (+A1, standard polarity) (110...220) V DC * Modules in Black LED + Diode (+A2, non standard polarity) (6...24) V DC housing are LED + Diode (+A2, non standard polarity) (28...60) V DC available on request. LED + Diode (+A2, non standard polarity) (110...220) V DC LED + Varistor (6...24) V DC/AC **For DC supply, (28...60) V DC/AC apply the positive LED + Varistor LED + Varistor (110...240) V DC/AC to terminal A1. RC circuit (6...24) V DC/AC RC circuit (28...60) V DC/AC RC circuit (110...240) V DC/AC 48 Residual current by-pass (62 kΩ/1W) (110...240) V AC BLUE* 99.02.3.000.00 99.02.2.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.9.024.79 99.02.9.060.79 99.02.9.220.79 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 27 27 26.25 94 Series - Sockets and Accessories for 55 Series Relays Relay type 55.32 Colour BLUE BLACK BLUE BLACK BLUE BLACK Screw terminal socket: panel or 35 mm rail (EN 50022) mount retaining clip 094.71 supplied with socket packaging code SMA 94.72 94.72.0 94.73 94.73.0 94.74 94.74.0 Retaining clip 94.74 = Ø3 solid wire 24 NO 24 5 14 4 NC 32 3 22 2 12 1 A1 42 4 12 1 A2 14 A1 13 COIL 35 36.3 26 34 6 23 24 23 30 27 14 5 19 19 = 23 24 30 44 8 70.5 Ø 4.1 Ø 4.2 35 68.5 35 36.3 C - RATED VALUES: 10 A - 250 V - DIELECTRIC STRENGTH: ≥ 2 kV AC - PROTECTION CATEGORY: IP 20 - AMBIENT TEMPERATURE: (-40…+70)°C SCREW TORQUE: 0.5 Nm - WIRE STRIP LENGTH: 8 mm - MAX WIRE SIZE: Ø3 Ø3 19 US Ø 4.2 C 70.5 ® R ICACIO TIFI ER C FAB N CONFORMIDAD DE LA 16.5 14.5 16.5 99.01 GOST N DE 55.32, 55.34 094.71 Modules (see table below) Approvals (according to type): IO AC 55.33 30 27 NO 44 8 34 7 24 6 14 5 NO NC 42 4 32 3 22 2 12 1 NC COIL A2 14 A1 13 COIL COM 41 12 31 11 21 10 11 9 COM 55 stranded wire mm2 1x2.5 / 2x1.5 1x2.5 / 2x1.5 41 12 11 9 A2 31 9 COM 21 8 11 7 94.72 Relay type 55.32 Colour BLUE BLACK Screw terminal socket: panel or 35 mm rail (EN 50022) mount retaining clip 094.71 supplied with socket packaging code SMA 94.82 94.82.0 Retaining clip 99.01 RATED VALUES: 10 A - 250 V DIELECTRIC STRENGTH: ≥ 2 kV AC PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C SCREW TORQUE: 0.5 Nm WIRE STRIP LENGTH: 9 mm 99.01 GOST * Modules in Black housing are available on request. 12 1 NC 44 8 14 5 NO 41 12 11 9 COM A2 14 A1 13 COIL 23 29.5 Ø 4.2 - MAX WIRE SIZE: solid wire stranded wire mm 1x2.5 / 2x1.5 1x2.5 / 2x1.5 2 AWG 1x14 / 2x16 1x14 / 2x16 94.82 FOR 94.72, 94.73, 94.74 AND 94.82 SOCKETS: Approvals (according to type): 42 4 35 GOST US 15.5 ® C 99.01 coil indication and EMC suppression modules (see technical data pag. 179) BLUE* Diode** (+A1, standard polarity) (6...220) V DC 99.01.3.000.00 Diode (+A2, non standard polarity) (6...220) V DC 99.01.2.000.00 (6...24) V DC/AC 99.01.0.024.59 LED (28...60) V DC/AC 99.01.0.060.59 LED (110...240) V DC/AC 99.01.0.230.59 LED LED + Diode** (+A1, standard polarity) (6...24) V DC 99.01.9.024.99 LED + Diode** (+A1, standard polarity) (28...60) V DC 99.01.9.060.99 LED + Diode** (+A1, standard polarity) (110...220) V DC 99.01.9.220.99 LED + Diode (+A2, non standard polarity) (6...24) V DC 99.01.9.024.79 LED + Diode (+A2, non standard polarity) (28...60) V DC 99.01.9.060.79 99.01.9.220.79 LED + Diode (+A2, non standard polarity) (110...220) V DC **For DC supply, apply the positive to terminal A1. LED + Varistor (6...24) V DC/AC 99.01.0.024.98 LED + Varistor (28...60) V DC/AC 99.01.0.060.98 LED + Varistor (110...240) V DC/AC 99.01.0.230.98 Green LED is standard. Red LED available on request. RC circuit (6...24) V DC/AC 99.01.0.024.09 RC circuit (28...60) V DC/AC 99.01.0.060.09 RC circuit (110...240) V DC/AC 99.01.0.230.09 (110...240) V AC 99.01.8.230.07 Residual current by-pass (62 kΩ/1W) 40.3 Approvals (according to type): 094.71 Modules (see table below) 71.3 94.82 - 94.74 94.73 20.8 AWG 1x14 / 2x16 1x14 / 2x16 26 49 94 Series - Sockets and Accessories for 55 Series Relays 94.84.3 Approvals (according to type): Relay type 55.32 Colour BLUE BLACK 55.32, 55.34 BLUE BLACK Clamp terminal socket: panel or 35 mm rail (EN 50022) mount retaining clip 094.71 supplied with socket packaging code SMA 94.82.3 94.82.30 94.84.3 94.84.30 Retaining clip 094.71 Plastic retaining and release clip 094.91.3 Identification tag 094.80.2 Modules (see table below) 99.80 86.12 solid wire 64.81 27 14 5 NO 44 8 34 7 24 6 14 5 NO 42 4 12 1 NC 42 4 32 3 22 2 12 1 NC A2 14 A1 13 31 11 21 10 A2 14 stranded wire mm 1x6 / 2x2.5 1x4 / 2x2.5 2 AWG 1x10 / 2x14 1x12 / 2x14 46.81 20.8 44 8 A1 13 41 12 COIL 11 9 COM 41 12 94.82.3 35.6 COIL 11 9 COM 19.9 RATED VALUES: 10 A - 250 V DIELECTRIC STRENGTH: ≥ 2 kV AC PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C SCREW TORQUE: 0.5 Nm WIRE STRIP LENGTH: 7 mm MAX WIRE SIZE: 76.22 55 - 94.84.3 24.8 Relay type 94.54.1 Approvals (according to type): 55.32, 55.34 Colour BLUE BLACK Screwless terminal socket: 35 mm rail (EN 50022) mount retaining clip 094.91 supplied with socket packaging code SPA 94.54.1 94.54.10 Retaining clip 094.71 Plastic retaining and release clip 094.91 Identification tag — Modules (see table below) 99.80 42.5 33.2 31 RATED VALUES: 10 A - 250 V DIELECTRIC STRENGTH: ≥ 2 kV AC PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-25…+70)°C WIRE STRIP LENGTH: 7 mm MAX WIRE SIZE: solid wire 41 12 31 11 21 10 11 9 COM 44 8 34 7 24 6 14 5 NO 42 4 32 3 22 2 12 1 NC A1 13 COIL 30 24 stranded wire 35 - mm2 2x(0.2…1.5) 2x(0.2…1.5) A2 14 30 AWG 2x(24…18) 2x(24…18) 6 94.54.1 15.45 FOR 94.82.3, 94.84.3 AND 94.54.1 SOCKETS: 99.80 coil indication and EMC suppression modules (see technical data page 179) Diode** (+A1, standard polarity) 99.80 Approvals (according to type): 50 BLUE* (6...220) V DC 99.80.3.000.00 LED (6...24) V DC/AC 99.80.0.024.59 LED (28...60) V DC/AC 99.80.0.060.59 LED (110...240) V DC/AC 99.80.0.230.59 LED + Diode** (+A1, standard polarity) (6...24) V DC 99.80.9.024.99 LED + Diode** (+A1, standard polarity) (28...60) V DC 99.80.9.060.99 99.80.9.220.99 GOST LED + Diode** (+A1, standard polarity) (110...220) V DC * Modules in Black housing are available on request. LED + Varistor (6...24) V DC/AC 99.80.0.024.98 LED + Varistor (28...60) V DC/AC 99.80.0.060.98 LED + Varistor (110...240) V DC/AC 99.80.0.230.98 **For DC supply, apply the positive to terminal A1. RC circuit (6...24) V DC/AC 99.80.0.024.09 RC circuit (28...60) V DC/AC 99.80.0.060.09 RC circuit (110...240) V DC/AC 99.80.0.230.09 (110...240) V AC 99.80.8.230.07 Green LED is standard. Residual current by-pass (62 kΩ/1W) Red LED available on request. 27 94 Series - Sockets and Accessories for 55 Series Relays 55.32 BLUE BLACK BLUE BLACK BLUE BLACK P.C.B. socket retaining clip 094.51 supplied with socket packaging code SMA 94.12 94.12.0 94.13 94.13.0 94.14 94.14.0 Metal retaining clip ICACIO C US N C - RATED VALUES: 10 A - 250 V - DIELECTRIC STRENGTH: ≥ 2 kV AC - AMBIENT TEMPERATURE: (-40…+70)°C 3.7 11.5 25.5 ® R 21.5 29.5 FAB 29.5 CONFORMIDAD DE LA TIFI ER C N DE 21.5 29.5 21.5 IO AC 55.32, 55.34 094.51 Approvals (according to type): GOST 55.33 8.5 = 13.2 = 6.6 = 5.3 4.1 5.3 4.1 29.5 1.5 29.5 1.5 = = 6.3 6.3 7.5 4.4 = 5.3 4.1 29.5 1.5 94.14 Relay type Colour 6.3 55 7.5 7.5 21.5 21.5 21.5 94.12 94.13 94.14 Copper side view 55.32 Colour BLUE BLACK BLUE BLACK BLUE BLACK Panel mount solder socket: 1 mm thick panel retaining clip 094.51 supplied with socket packaging code SMA 94.22 94.22.0 94.23 94.23.0 94.24 94.24.0 17 21.5 ICACIO C US 25.5 ® R 29.5 FAB 29.5 CONFORMIDAD DE LA 29.5 N DE TIFI ER C IO AC 21.8 9.5 94.22 94.23 2 94.24 N C Relay type 55.32 Colour BLUE BLACK BLUE BLACK BLUE BLACK Panel mount socket: M3 screw mount - solder connections retaining clip 094.51 supplied with socket packaging code SMA 94.32 94.32.0 94.33 94.33.0 94.34 94.34.0 55.33 Metal retaining clip 7.5 ® 17 8.5 3 US 40.5 40.5 40.5 26.5 C - RATED VALUES: 10 A - 250 V - DIELECTRIC STRENGTH: ≥ 2 kV AC - AMBIENT TEMPERATURE: (-40…+70)°C 21.5 21.5 = C 34 R 21.5 Ø 3.2 = FAB ICACIO TIFI ER C CONFORMIDAD DE LA N DE ION AC 55.32, 55.34 094.51 Approvals (according to type): GOST 21.5 1 21.5 - RATED VALUES: 10 A - 250 V - DIELECTRIC STRENGTH: ≥ 2 kV AC - AMBIENT TEMPERATURE: (-40…+70)°C 94.34 55.32, 55.34 094.51 Approvals (according to type): GOST 55.33 Metal retaining clip 25.8 94.22 Relay type 7.5 22.5 94.32 94.33 94.34 51 94 Series - Sockets and Accessories for 55 Series Relays ACCESSORIES Sheet of marker tags for retaining clip 094.01 (72 tags): 6x12mm 060.72 PACKAGING CODES How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 55 9 4 .0 4 S M A A Standard packaging SM Metal retaining clip SP Plastic retaining clip SX No retaining clip 52 060.72
9402SMA 价格&库存
很抱歉,暂时无法提供与“9402SMA”相匹配的价格&库存,您可以联系我们找货
