99 SERIES
Coil indication and EMC suppression modules
99
SERIES
99.02
A
Diagrams
Code
99.02.9.024.99
99.02.9.060.99
99.02.9.220.99
Green LED + diode module (standard polarity)
Recovery diode modules + LED are used for DC only. The reverse voltage peaks of
the coil are short circuited by the recovery diode (positive to terminal A1).
The release time increases by an approximate factor from 3 to 5.
If an increase of the release time is undesirable use a Varistor or RC module.
The LED indicator lights up when the coil is energized.
99.02.0.024.98
99.02.0.060.98
99.02.0.230.98
Green LED + Varistor module
LED modules + Varistor are used for both AC and DC coils.
The reverse voltage peaks of the relay coil are limited by the Varistor to
approximately 2.5 times the nominal voltage of the supply. When using DC coils
it is essential that positive is connected to terminal A1. The relay release time
increases insignificantly.
99.02.0.024.59
99.02.0.060.59
99.02.0.230.59
Green LED module
LED modules are used for AC and DC.
When using DC it is essential that positive is connected to terminal A1.
99.02.3.000.00
Diode module (standard polarity)
Recovery diode modules are used for DC only. The reverse voltage peaks of the coil
99.02.0.024.09
99.02.0.060.09
99.02.0.230.09
RC module
RC circuit modules are used for AC and DC coils. The reverse voltage peaks of the
coil are limited by the RC module to approximately 2.5 times the nominal voltage
of the supply. The relay release time increases insignificantly.
99.02.8.230.07
Residual current bypass module
Bypass modules are advisable if 110 or 230 V AC relays show any tendency to fail
to release. Failure to release can be caused by residual currents from AC proximity
switches or inductive coupling caused through long parallel lying AC control lines.
Voltage-current characteristic when switching a
resistive load (fig. 1).
U
R U
R
I
U
I
I
U
ON
OFF
ON
OFF
t
I
t
II-2016, www.findernet.com
relay coil (fig. 2).U
R
UL
R
L
I
U
I
I
I
U
ON
OFF
ON
OFF
Functions
t
t
Switching Relay Coils.
When switching a resistive load, the current
follows the phase of the voltage directly (Fig 1).
When switching relay coils the current and
voltage waveforms are different due to the
inductive nature of the coil (Fig 2). A brief
explanation of this mechanism is as follows.
On energisating the coil, the build up of
the magnetic field gives rise to counter
electromotive forces which in turn delay the rise
in coil current. On de-energisation, the sudden
interruption of the coil current causes a sudden
collapse of the magnetic field, which in turn
induces a high voltage of reverse polarity across
the coil. This reverse polarity voltage peak can
reach a value typically 15 times higher than
the supply voltage, and as a consequence can
disturb or destroy electronic devices.
To counteract this potentially damaging effect,
relays coils can be suppressed with a Diode, a
Varistor (voltage dependent resistor) or a RC
(resistor/capacitor) module – dependent on the
operating voltage. (See above for descriptions
of the various Modules available.)
Whilst the above description is based on the
working of a DC coil, the reverse polarity voltage
peak on de-energisation applies similarly to AC
coils. However, when energising AC coils there
will also be a coil inrush current of 1.3 to 1.7
times the nominal coil current – dependent
on coil size. If coils are fed via a transformer
(and particularly if several are energised at the
same time) then this may need to taken into
account when calculating the VA rating of the
transformer.
1
很抱歉,暂时无法提供与“99.02.3.000.00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+21.18309
- 10+17.43997
- 国内价格 香港价格
- 1+26.043521+3.36913
- 国内价格 香港价格
- 25+30.5994225+3.95851
