14.91.8.230.0000
14.91.8.230.0000
    FINDER
    TIMER RLY SPST-NO 16A 230VAC
14.91.8.230.0000 数据手册
14 Series - Electronic staircase timer 16 A Features 14.01 14.71 Range of electronic staircase timers 17.5 mm wide Time setting from 30 s to 20 min • “Zero crossing” load switching • “Switch-off early warning” - model 14.01 • Suitable for 3 or 4 wire systems, with automatic recognition (14.01 and 14.71) or via “pushbutton configuration” (14.81) • LED status indicators (14.01 and 14.71) • Cadmium free contact material • Can be used with illuminated push - buttons • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the function selector, the timing trimmer, and to disengage the 35 mm rail mounting clip • European Patent • • • Multi-function • Mono-function • 1 NO (SPST-NO) • 1 NO (SPST-NO) • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 NO (SPST-NO) 1 NO (SPST-NO) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 230/— 230/— Rated load AC1 VA 3,700 3,700 Rated load AC15 (230 V AC) VA 750 750 Nominal lamp rating:incandescent (230 V) W 3,000 3,000 compensated fluorescent (230 V) W 1,000 1,000 uncompensated fluorescent (230 V) W 1,000 1,000 halogen (230 V) W 3,000 3,000 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 230 230 Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power — — 3/1.2 3/1.2 (0.8…1.1)UN (0.8…1.1)UN — — cycles 100 · 103 100 · 103 min 0.5…20 0.5…20 VA (50 Hz)/W Operating range AC (50 Hz) DC Technical data Electrical life at rated load in AC1 Delay setting Max no. of illuminated push-button (≤ 1 mA) Maximum impulse duration Ambient temperature range Protection category °C 30 30 continuous continuous –10…+60 IP 20 –10…+60 IP 20 Approvals (according to type) 1 14 Series - Electronic staircase timer 16 A Features 14.81 14.91 Range of electronic staircase timers 17.5 mm wide Time setting from 30 s to 20 min • “Zero crossing” load switching • Types 14.81 and 14.91: wiring compatible with mechanical versions and with old type (low emission) illuminated pushbuttons • Suitable for 3 or 4 wire systems, with automatic recognition (14.01 and 14.71) or via “pushbutton configuration” (14.81) • Cadmium free contact material • Can be used with illuminated push - buttons • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the function selector, the timing trimmer, and to disengage the 35 mm rail mounting clip • • • Mono-function • 1 NO (SPST-NO) • 35 mm rail (EN 60715) mount • All terminals on same side • Mono-function • 1 NO (SPST-NO) • 35 mm rail (EN 60715) mount • 3 terminals, on same side Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 NO (SPST-NO) 1 NO (SPST-NO) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 230/— 230/— Rated load AC1 VA 3,700 3,700 Rated load AC15 (230 V AC) VA 750 750 Nominal lamp rating:incandescent (230 V) W 3,000 3,000 compensated fluorescent (230 V) W 1,000 1,000 uncompensated fluorescent (230 V) W 1,000 1,000 halogen (230 V) W 3,000 3,000 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 230 230 Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power — — 3/1.2 3/1.2 (0.8…1.1)UN (0.8…1.1)UN — — cycles 100 · 103 100 · 103 min 0.5…20 0.5…20 VA (50 Hz)/W Operating range AC (50 Hz) DC Technical data Electrical life at rated load in AC1 Delay setting Max no. of illuminated push-button (≤ 1 mA) Maximum impulse duration Ambient temperature range Protection category Approvals (according to type) 2 °C 25 25 continuous continuous –10…+60 IP 20 –10…+60 IP 20 14 Series - Electronic staircase timer 16 A Ordering information Example: 14 series multi-function relay, single phase switch 1 NO (SPDT-NO) 16 A contact, supply rated at 230 V AC. 1 4 . 0 1 . 8 . 2 3 0 . 0 0 0 0 Supply voltage 230 = 230 V Series Type 0 = 35 mm rail (EN 60715) mount, multi-function 7 = 35 mm rail (EN 60715) mount, mono-function 8 = 35 mm rail (EN 60715) mount mono-function, all terminals on same side 9 = 35 mm rail (EN 60715) mount, mono-function, 3 terminals Supply version 8 = AC (50/60 Hz) No. of poles 1 = Single phase switch, 16 A Technical data Insulation Dielectric strength between open contacts V AC 1,000 Other data Power lost to the environment without contact current W 1.2 with rated current W 2 Maximum cable length for push-button connection Screw torque m 200 Nm 0.8 Max. wire size solid cable stranded cable mm2 1x6 / 2x4 1x4 / 2x2.5 AWG 1x10 / 2x12 1x12 / 2x14 Zero crossing switching 1. Lower inrush current protects and increases lamp life 2. Lower inrush current reduces the possibility of contact welding 3. The current at switch-off is also lower, reducing stress and wear on the contacts Note Using the type 14.91, the lamps are switch on direct by the pushbuttom Accessories Adaptor for panel mounting, 17.5 mm wide 020.01 020.01 Sheet of marker tags, plastic, 72 tags, 6x12 mm 060.72 060.72 3 14 Series - Electronic staircase timer 16 A Wiring diagrams Type 14.01 14.71 Red LED indication: Continuous = relay ON Blinking = relay OFF L L N N 3 wire connection 4 wire connection Type 14.81 (pushbutton configuration required as per the Installation manual) L L N N 3 wire connection Type 14.91 (the push-buttons must be rated for the load current) L N 4 4 wire connection 14 Series - Electronic staircase timer 16 A Wiring diagrams Possibility of connection of 14.01 with PIR movement detectors (18 series) 3 wire connection (with 18.21.8.230.0300 or 18.31.8.230.0300 only) 4 wire connection (with 18.01.8.230.0000, 18.11.8.230.0000, 18.21.8.230.0300 or 18.31.8.230.0300) L L N N 18.21/18.31 18.21/18.31 14.01 14.01 L N 18.01/18.11 14.01 Functions Type 14.01 Functions selectable with front rotary selector (BE) Staircase relay On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. (BP) Staircase relay with early warning On initial impulse the output contact closes and the timing starts for the pre-set duration. After the timing period, the output contact blinks off once; 10secs later the contact blinks off twice, and after a further 10secs the contact opens. During the pre-set and 20 second warning time, it is possible, by a further impulse, to extend the time by the full pre-set value. (IT) Timing step relay On initial impulse the output contact closes and timing starts for the pre-set duration; On expiry of the time delay, the output contact opens. During the timing period it is possible to immediately open the contact with a further impulse. (IP) Timing step relay with early warning On initial impulse the output contact closes and timing starts for the pre-set duration; After the timing period, the output contact blinks off once; 10 secs later the contact blinks off twice, and after a further 10 secs the contact opens. During the pre-set and 20 second warning time, it is possible to immediately open the output contact by a further impulse. (RI) Step relay After every impulse, the output contact changes state - alternately switching from open to closed and vice versa. Light ON With this function set - the output contact stays permanently closed. NOTE: The blinking within the Early Warning functions (BP and IP) could cause re-start problems for fluorescent lamps with electromagnetic chokes (both conventional and compact types); We consequently suggest not to use such lamps with these functions. 5 14 Series - Electronic staircase timer 16 A Functions Type 14.71 Functions selectable with front selector Staircase relay On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. “Staircase maintenance” function An impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60' timing can be interrupted by a further impulse of ≥ 5 seconds, the output contact opens. Light ON With this function set - the output contact stays permanently closed. Type 14.81 Staircase relay On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. “Staircase maintenance” function An impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60' timing can be interrupted by a further impulse of ≥ 5 seconds, which will re-establish the staircase timer function; so on expiry of the staircase time delay, the output contact opens. Type 14.91 Signal ON pulse On initial impulse the output contact closes, and remain so for the duration of the preset delay. On expiry of the time delay, the output contact opens. 6
14.91.8.230.0000 价格&库存
很抱歉,暂时无法提供与“14.91.8.230.0000”相匹配的价格&库存,您可以联系我们找货
