222482304000
222482304000
    FINDER
    FINDER - 222482304000 - Power Relay, DPST-NC, 230 VAC, 20 A, 22 Series, DIN Rail, Panel, Non Latchin...
222482304000 数据手册
22 Series - Modular Monostable Relays 20 A 22.21 22.22 One module (17.5mm) wide Test button Identification label AC and DC coils 35 mm rail (EN 50022) mount - Single phase switch 1 NO - 35 mm rail (EN 50022) 58.4 43.5 26.5 17.5 2 3 4 58.4 43.5 26.5 45 84 84 17.5 A2 2 1 84 A2 A1 1 45 A1 - Double phase switch 2 NO - 35 mm rail (EN 50022) 84 - Contact specifications Contact configuration Rated current/Max. peak current A Rated voltage/Max. switching voltage V AC 1 NO 2 NO 20/30 20/30 250/400 250/400 Rated load in AC1 VA 5,000 5,000 Rated load in AC15 (230 VAC) VA 1,000 1,000 Single phase motor rating (230 VAC) Breaking capacity: 30/110/220 V Minimum switching load kW/HP — — A 20/0.3/0.12 20/0.3/0.12 mW(V/mA) 1,000 (10/10) 1,000 (10/10) AgNi AgNi Standard contact material Coil specifications Nominal voltage V AC (50/60Hz) V DC 8 - 12 - 24 - 48 - 110 - 120 - 230 - 240 12 - 24 - 48 - 110 12 - 24 - 48 - 110 Rated power AC/DC VA (50Hz)/W 2.3/1.25 2.3/1.25 Operating range AC (50Hz)/W (0.85…1.1)UN (0.85…1.1)UN (0.9…1.1)UN (0.9…1.1)UN DC Technical data Mechanical life cycles 500 · 103 500 · 103 Electrical life at rated load in AC1 cycles 50 · 10 50 · 103 Maximum impulse duration Surge test (1.2/50µs) between coil and contacts V Ambient temperature range Protection category Approvals: (according to type) 136 °C 3 continuous continuous 4,000 4,000 –40…+40 IP 20 –40…+40 IP 20 22 Series - Modular Monostable Relays 20 A 22.23 22.24 One module (17.5mm) wide Test button Identification label AC and DC coils 35 mm rail (EN 50022) mount - Double phase switch 1 NO + 1 NC - 35 mm rail (EN 50022) A2 2 A2 4 58.4 43.5 26.5 45 2 3 4 58.4 43.5 26.5 84 17.5 84 17.5 A1 1 1 3 45 84 A1 - Double phase switch 2 NC - 35 mm rail (EN 50022) 84 - Contact specifications Contact configuration Rated current/Max. peak current A Rated voltage/Max. switching voltage V AC 1 NO + 1 NC 2 NC 20/30 20/30 250/400 250/400 Rated load in AC1 VA 5,000 5,000 Rated load in AC15 (230 VAC) VA 1,000 1,000 Single phase motor rating (230 VAC) Breaking capacity: 30/110/220 V Minimum switching load kW/HP A mW(V/mA) Standard contact material — — 20/0.3/0.12 20/0.3/0.12 1,000 (10/10) 1,000 (10/10) AgNi AgNi Coil specifications Nominal voltage V AC (50/60Hz) V DC 8 - 12 - 24 - 48 - 110 - 120 - 230 - 240 12 - 24 - 48 - 110 12 - 24 - 48 - 110 Rated power AC/DC VA (50Hz)/W 2.3/1.25 2.3/1.25 Operating range AC (50Hz)/W (0.85…1.1)UN (0.85…1.1)UN (0.9…1.1)UN (0.9…1.1)UN DC Technical data Mechanical life cycles 500 · 103 500 · 103 Electrical life at rated load in AC1 cycles 50 · 10 50 · 103 Maximum impulse duration Surge test (1.2/50µs) between coil and contacts V Ambient temperature range Protection category °C 3 continuous continuous 4,000 4,000 –40…+40 IP 20 –40…+40 IP 20 Approvals: (according to type) 137 22 Series - Modular Monostable Relays 20 A ORDERING INFORMATION Example: a 22 series 35 mm rail (EN 50022) mount relay with 1 NO (SPST-NO) - 20 A contacts, with coil rated at 24 V DC, contact material AgSnO2. 2 2 . 2 1 . 9 . 0 2 4 . 4 Series 0 0 0 Contact material 0 = AgNi standard 4 = AgSnO2 Type 2 = 35 mm rail (EN 50022) mount Coil voltage see coil specifications No. of poles 1 = 1 NO (SPST-NO) 2 = 2 NO (DPST-NO) 3 = 1 NO (SPST-NO) +1 NC (SPST-NC) 4 = 2 NC (DPST-NC) Coil version 8 = AC (50/60 Hz) 9 = DC TECHNICAL DATA CONTACT SPECIFICATIONS NOMINAL RATE LAMPS - incandescence (230V) W 1,000 - compensated fluorescent (230V) W 360 INSULATION DIELECTRIC STRENGTH - between supply and contacts V AC 3,500 - between open contacts V AC 2,000 - between adjacent contacts V AC 2,000 V 4,000 SURGE TEST (1.2/50µs) - between supply and contacts OTHER DATA 22.21 POWER LOST IN THE ENVIRONMENT - without contact current W - with rated current W 22.22, 22.23, 22.24 1.2 1.2 3.2 5.2 COIL CLAMPS MAX WIRE SIZE flexible cable solid cable flexible cable mm 1x4 / 2x2.5 1x2.5 / 2x2.5 1x6 / 2x6 1x6 / 2x4 AWG 1x12 / 2x14 1x14 / 2x14 1x10 / 2x10 1x10 / 2x12 2 TORQUE CONTACT CLAMPS solid cable Nm 0.8 0.8 If the coil is operated for a prolonged period of time, adaquate ventilation of the relays must be provided, for example leaving a gap of about 9mm between pairs of relays. COIL SPECIFICATIONS AC VERSION DATA Nominal voltage UN V 8 12 24 48 110 120 230 240 138 Coil code 8.008 8.012 8.024 8.048 8.110 8.120 8.230 8.240 DC VERSION DATA Operating range Umin V 6.8 10.2 20.4 40.8 93.5 102 195.5 204 Umax V 8.8 13.2 26.4 52.8 121 132 253 264 Resistance Absorption I at UN (50Hz) R Ω mA 6.5 275 13.5 185 42 95 185 48 980 21 1,400 18 4,250 10 4,400 9.5 Nominal voltage UN V 12 24 48 110 Coil code 9.012 9.024 9.048 9.110 Operating range Umin V 10.8 21.6 43.2 99 Umax V 13.2 26.4 52.8 121 Resistance Absorption I at UN R Ω mA 115 104.3 460 52.2 1,850 25.9 9,700 11.3
222482304000 价格&库存
很抱歉,暂时无法提供与“222482304000”相匹配的价格&库存,您可以联系我们找货
