39.31.3.230.0060
39.31.3.230.0060
    FINDER
    Module
39.31.3.230.0060 数据手册
39 SERIES MasterINTERFACE - Relay interface modules Common features • Space saving 6.2 mm wide • Connections for 16-way jumper link • Integral coil indication and protection circuit • Secure retention and easy ejection by plastic • • clip Dual screw head (blade+cross) terminals and Push-in terminals versions 35 mm rail mounting (EN 60715) MasterBASIC 39 SERIES EMR Electromechanical Relays SSR Solid State Relays • 1 CO 6 A/250 V AC • High switching capability • 1 solid state output (options 0.1 A/48 V DC, 2 A/24 V DC, 2 A/240 V AC) • Silent, high speed switching, long electrical life 39.11/39.01 B 39.10/39.00 • For general use in any type of system • EMR: 6 to 24 and 125 V AC/DC, 230 V AC upply • SSR: 6 to 24 V DC, 125 V AC/DC, 230 V AC supply • Screw terminal and Push-in terminal MasterBASIC - EMR ATEX • Available on request - See page 14 MasterPLUS • Accepts the output fuse module, for the easy Page 4 39.31 - 39.31.3/39.61 - 39.61.3 Page 5 39.30 - 39.30.3/39.60 - 39.60.3 and space efficient protection of output circuits • EMR: 6 to 125 V AC/DC, 125 and 220 V DC, 230 V AC and 24…240 V AC/DC supply • SSR: 24 - 125 V AC/DC, 6 to 220 V DC, 230 V AC and 24…240 V AC/DC supply • Special 125 V AC/DC and 230 V AC leakage current suppression types (39.31.3, 39.61.3 EMR and 39.30.3, 39.60.3 SSR) • Screw terminal and Push-in terminal MasterINPUT • Jumper link option for the quick and easy Page 6 39.41/39.71 Page 7 39.40/39.70 distribution of supply voltage to proximity switches and similar input devices • EMR: 6 to 24 V and 125 V AC/DC, 230 V AC supply • SSR: 6 - 24 V DC, 24 - 125 V AC/DC, 230 V AC supply • Screw terminal and Push-in terminal Page 9 Page 8 MasterOUTPUT • Jumper link option for the quick and easy 39.21/39.51 39.20/39.50 distribution of supply voltage to output side and its connection to electromagnetic valves and similar output devices • EMR: 6 to 24 V and 125 V AC/DC, 230 V AC supply • SSR: 6 to 24 V DC, 125 V AC/DC, 230 V AC supply • Screw terminal and Push-in terminal MasterTIMER • Timer adjustment via top mounted rotary knob Page 11 Page 10 39.81/ 39.91 39.80/39.90 accessible after assembly XI-2016, www.findernet.com • Control signal terminal • DIP-switch for selection of 4 time scales and ­­­­ 8 functions • Output with fuse module option • EMR and SSR: 12 to 24 V AC/DC supply • Screw terminal and Push-in terminal Page 12 Page 13 39 SERIES 39 SERIES Typical applications MasterBASIC 39.11 - 39.10 - 39.01 - 39.00 MasterPLUS 39.31 - 39.30 - 39.31.3 - 39.30.3 - 39.61 - 39.60 - 39.61.3 - 39.60.3 • For general interface use in any type of system • This special version provides extra protection for the output circuit thanks to the replaceable fuse and application. • Can be used for input interface applications between auxiliary contacts, sensors etc. and controllers, PLC's or motors. Or for output interface between PLC's controllers and relays, solenoids etc. B Output devices module. • For general interface use in any type of system and application. • Can be used for input interface applications between auxiliary contacts, sensors etc. and controllers, PLC's or motors. Or for output interface between PLC’s controllers and relays, solenoids etc. 8012823356709 8012823356709 Output devices Fuse module 093.63 093.63.0.024 093.63.8.230 PLC - Output PLC - Output PLC - Input PLC - Input Input devices 2 Input devices XI-2016, www.findernet.com Fuse module 093.63 093.63.0.024 093.63.8.230 39 SERIES Typical applications MasterINPUT 39.41 - 39.40 - 39.71 - 39.70 • These models allow the full termination of • • input device to the interface without the need for additional terminals - saving component cost, time and panel space. Quick and easy distribution of supply voltage through the jumper link on the Bus-Bar (BB) connection. Ideal for interface applications between the auxiliary contacts, sensors, limit switches and Controllers or PLC’s. 39 SERIES MasterOUTPUT 39.21 - 39.20 - 39.51 - 39.50 • These models allow the full termination • • of output device to the interface without the need for additional terminals - saving component cost, time and panel space. Quick and easy distribution of supply voltage through the jumper link on the Bus-Bar (BB) connection. Ideal for interface applications between the PLC’s or Controllers and output devices such as electomagnetic valves or motors etc.. Output devices MasterTIMER 39.81 - 39.80 - 39.91 - 39.90 • Slim and Multifunction Timed Interface modules. B Output devices Fuse module 093.63 093.63.0.024 093.63.8.230 XI-2016, www.findernet.com PLC - Output PLC - Output PLC - Input PLC - Input Input devices Input devices 3 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterBASIC - EMR 39.11/39.01 1 Pole interface module, 6.2 mm wide, ideal for PLC and electronic systems • Common connection possible with optional jumper links (terminals A1, A2 and 11) • UL Listing (certain relay/socket combinations) B • 6 A electromechanical relay • 6 to 24 and 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.11 Screw terminal 39.01 Push-in terminal For outline drawing see page 22, 23 Contact specification Contact configuration 1 CO (SPDT) Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC 6/10 250/400 Rated load AC1  VA Rated load AC15 (230 V AC) VA 300 Single phase motor rating (230 V AC) kW 0.185 Breaking capacity DC1: 30/110/220 V A 6/0.2/0.12 mW (V/mA) 500 (12/10) Minimum switching load Standard contact material 1500 AgNi Supply specification Nominal voltage (UN) V AC/DC V AC (50/60 Hz) Rated power VA (50 Hz)/W 6 - 12 - 24 - 110…125 220…240 See page 18 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Mechanical life AC/DC cycles 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts  Ambient temperature range Protection category Approvals relay (according to type) 4 ms 5/6 kV 6 (8 mm) V AC °C 1000 –40…+70 IP 20 XI-2016, www.findernet.com Technical data 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES MasterBASIC - SSR 39.10/39.00 1 Pole interface module, 6.2 mm wide, ideal for PLC and electronic systems • Common connection possible with optional jumper links (terminals A1, A2 and 13+) • UL Listing (certain relay/socket combinations) B • 0.1 or 2 A solid state relay • 6 to 24 and 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.10 Screw terminal 39.00 Push-in terminal For outline drawing see page 22, 23 Output specification (SSR) 39.x0.x.xxx.9024 39.x0.x.xxx.7048 39.x0.x.xxx.8240 Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage A Switching voltage range 2/20 DC 0.1/0.5 DC 2/40 AC V 24/33 DC 48/60 DC 240/— AC V (1.5…24) DC (1.5…48) DC (12…275) AC 600 Repetitive peak off-state voltage Vpk — — Minimum switching current mA 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 V 0.12 1 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN)V AC/DC 110…125 V AC (50/60 Hz) 220…240 V DC Rated power 6 - 12 - 24 VA (50 Hz)/W See page 19 Operating range (0.8…1.1)UN Must drop-out voltage 0.1 UN Technical data Operate/release time Dielectric strength between input/output Ambient temperature range XI-2016, www.findernet.com Protection category ms V AC °C 0.2/0.6 0.04/0.6 12/12 2500 –20…+55 IP 20 Approvals relay (according to type) 5 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterPLUS - EMR 39.31/39.61 39.31.3/39.61.3 1 Pole interface modules, 6.2 mm wide, ideal for PLC and electronic systems • Accepts output fuse module 093.63, • • • 6 A electromechanical relay • 6 to 125 V AC/DC, 125 and 220 V DC, 230 V AC, 24…240 V AC/DC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.31/39.31.3 Screw terminal • 6 A electromechanical relay • Leakage current suppression version, 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal 39.61/39.61.3 Push-in terminal Fuse module 093.63 093.63.0.024 093.63.8.230 For outline drawing see page 22, 23 Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1  VA 1 CO (SPDT) 1 CO (SPDT) 6/10 6/10 250/400 250/400 1500 1500 Rated load AC15 (230 V AC) VA 300 300 Single phase motor rating (230 V AC) kW 0.185 0.185 Breaking capacity DC1: 30/110/220 V Minimum switching load A 6/0.2/0.12 6/0.2/0.12 mW (V/mA) 500 (12/10) 500 (12/10) AgNi AgNi 6 - 12 - 24 - 60 - 110…125 - 24…240 110…125 220…240 220…240 Standard contact material Supply specification Nominal voltage (UN) V AC/DC V AC (50/60 Hz) V DC 110…125 - 220 — See page 18 See page 18 Operating range (0.8…1.1)UN (0.8…1.1)UN Holding voltage 0.6 UN 0.6 UN Must drop-out voltage 0.1 UN 0.3 UN Rated power VA (50 Hz)/W Technical data Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 60 · 10 60 · 103 ms 5/6 5/6 kV 6 (8 mm) 6 (8 mm) Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts  Ambient temperature range Protection category Approvals relay (according to type) 6 V AC °C 3 1000 1000 –40…+70 (+55 for 220 V DC) –40…+70 IP 20 IP 20 XI-2016, www.findernet.com B 093.63.0.024, 093.63.8.230 (for 5 x 20 mm fuses) for quick and easy load protection, see page 27 Common connection possible with optional jumper links (terminals A1, A2 and 11) UL Listing (certain relay/socket combinations) 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES MasterPLUS - SSR 39.30/39.60 39.30.3/39.60.3 1 Pole interface modules, 6.2 mm wide, ideal for PLC and electronic systems • Accepts output fuse module 093.63, 093.63.0.024, 093.63.8.230 (for 5 x 20 mm fuses) for quick and easy load protection, see page 27 • Common connection possible with optional jumper links (terminals A1, A2 and 13+) • UL Listing (certain relay/socket combinations) B • 0.1 or 2 A solid state relay • 24 - 125 V AC/DC, 6 to 220 V DC and 230 V AC, 24…240 V AC/DC supply 125 V AC DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.30/39.30.3 Screw terminal • 0.1 or 2 A solid state relay • Leakage current suppression version, • Screw terminal and push-in terminal 39.60/39.60.3 Push-in terminal Fuse module 093.63 093.63.0.024 093.63.8.230 For outline drawing see page 22, 23 Output specification (SSR) 39.x0.x.xxx.9024 39.x0.x.xxx.7048 39.x0.x.xxx.8240 39.x0.3.xxx.9024 39.x0.3.xxx.7048 39.x0.3.xxx.8240 Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage A Switching voltage range 2/20 DC 1 NO (SPST-NO) 0.1/0.5 DC 2/40 AC 2/20 DC 0.1/0.5 DC 2/40 AC V 24/33 DC 48/60 DC 240/— AC 24/33 DC 48/60 DC 240/— AC V (1.5…24) DC (1.5…48)DC (12…275) AC (1.5…24) DC (1.5…48)DC (12…275) AC 600 Repetitive peak off-state voltage Vpk — — 600 — — Minimum switching current mA 1 0.05 22 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 0.001 0.001 1.5 V 0.12 1 1.6 0.12 1 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN)V AC/DC V AC (50/60 Hz) V DC Rated power 24 - 110…125 - 24…240 110…125 220…240 220…240 6 - 12 - 24 - 60 - 110…125 - 220 — See page 19 See page 19 (0.8…1.1)UN (0.8…1.1)UN 0.1 UN 0.3 UN VA (50 Hz)/W Operating range Must drop-out voltage Technical data Operate/release time Dielectric strength between input/output Ambient temperature range XI-2016, www.findernet.com Protection category ms V AC °C 0.2/0.6 0.04/0.6 12/12 0.2/0.6 0.04/0.6 2500 2500 –20…+55 –20…+55 IP 20 IP 20 12/12 Approvals relay (according to type) 7 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterINPUT - EMR 39.41/39.71 1 Pole interface module, 6.2 mm wide, ideal for PLC and electronic systems • Jumper link option for the quick and easy • • • 6 A electromechanical relay • 6 - 12 - 24 - 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.41 Screw terminal 39.71 Push-in terminal For outline drawing see page 22, 23 Contact specification Contact configuration 1 CO (SPDT) Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC 6/10 250/400 Rated load AC1  VA Rated load AC15 (230 V AC) VA 300 Single phase motor rating (230 V AC) kW 0.185 Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material 1500 6/0.2/0.12 50 (5/2) AgNi + Au Supply specification Nominal voltage (UN) V AC/DC V AC (50/60 Hz) Rated power VA (50 Hz)/W 6 - 12 - 24 - 110…125 220…240 See page 18 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts  Ambient temperature range Protection category Approvals relay (according to type) 8 ms 5/6 kV 6 (8 mm) V AC °C 1000 –40…+70 IP 20 XI-2016, www.findernet.com B distribution of supply voltage to proximity switches and similar input devices (Bus-bar connection BB) Gold plated output contact as standard, for better compatibility with low energy PLC inputs UL Listing (certain relay/socket combinations) 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES MasterINPUT - SSR 39.40/39.70 1 Pole interface modules, 6.2 mm wide, ideal for PLC and electronic systems • Jumper link option for the quick and easy distribution of supply voltage to proximity switches and similar input devices (Bus-bar connection BB) • UL Listing (certain relay/socket combinations) B • 0.1 or 2 A solid state relay • 6 - 12 - 24 V DC, 24 - 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.40 Screw terminal 39.70 Push-in terminal For outline drawing see page 22, 23 Output specification (SSR) 39.x0.x.xxx.9024 39.x0.x.xxx.7048 39.x0.x.xxx.8240 Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage A Switching voltage range 2/20 DC 0.1/0.5 DC 2/40 AC V 24/33 DC 48/60 DC 240/— AC V (1.5…24) DC (1.5…48) DC (12…275) AC 600 Repetitive peak off-state voltage Vpk — — Minimum switching current mA 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 V 0.12 1 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN)V AC/DC 24 - 110…125 V AC (50/60 Hz) 220…240 V DC Rated power 6 - 12 - 24 VA (50 Hz)/W See page 19 Operating range (0.8…1.1)UN Must drop-out voltage 0.1 UN Technical data Operate/release time Dielectric strength between input/output XI-2016, www.findernet.com Ambient temperature range Protection category ms V AC °C 0.2/0.6 0.04/0.6 12/12 2500 –20…+55 IP 20 Approvals relay (according to type) 9 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterOUTPUT - EMR 39.21/39.51 1 Pole interface modules, 6.2 mm wide, ideal for PLC and electronic systems • Jumper link option for the quick and easy • • 6 A electromechanical relay • 6 - 12 - 24 - 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.21 Screw terminal 39.51 Push-in terminal For outline drawing see page 22, 23 Contact specification Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC 6/10 250/400 Rated load AC1  VA Rated load AC15 (230 V AC) VA 300 Single phase motor rating (230 V AC) kW 0.185 Breaking capacity DC1: 30/110/220 V A 6/0.2/0.12 mW (V/mA) 500 (12/10) Minimum switching load Standard contact material 1500 AgNi Supply specification Nominal voltage (UN) V AC/DC V AC (50/60 Hz) Rated power VA (50 Hz)/W 6 - 12 - 24 - 110…125 220…240 See page 18 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts  Ambient temperature range Protection category Approvals relay (according to type) 10 ms 5/6 kV 6 (8 mm) V AC °C 1000 –40…+70 IP 20 XI-2016, www.findernet.com B distribution of supply voltage to output side (Bus-bar connection BB) and its connection to electromagnetic valves and similar output devices UL Listing (certain relay/socket combinations) 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES MasterOUTPUT - SSR 39.20/39.50 1 Pole interface modules, 6.2 mm wide, ideal for PLC and electronic systems • Jumper link option for the quick and easy distribution of supply voltage to output side (Bus-bar connection BB) and its connection to electromagnetic valves and similar output devices • UL Listing (certain relay/socket combinations) B • 0.1 or 2 A solid state relay • 6 to 24 V DC, 125 V AC/DC and 230 V AC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.20 Screw terminal 39.50 Push-in terminal For outline drawing see page 22, 23 Output specification (SSR) 39.x0.x.xxx.9024 39.x0.x.xxx.7048 39.x0.x.xxx.8240 Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage A Switching voltage range 2/20 DC 0.1/0.5 DC 2/40 AC V 24/33 DC 48/60 DC 240/— AC V (1.5…24) DC (1.5…48) DC (12…275) AC Repetitive peak off-state voltage Vpk — — 600 Minimum switching current mA 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 V 0.12 1 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN)V AC/DC 110…125 V AC (50/60 Hz) 220…240 V DC Rated power 6 - 12 - 24 VA (50 Hz)/W See page 19 Operating range (0.8…1.1)UN Must drop-out voltage 0.1 UN Technical data Operate/release time Dielectric strength between input/output Ambient temperature range XI-2016, www.findernet.com Protection category ms V AC °C 0.2/0.6 0.04/0.6 12/12 2500 –20…+55 IP 20 Approvals relay (according to type) 11 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterTIMER - EMR 39.81/39.91 Slim timed interface module, 6.2 mm wide, ideal for space-saving timing solutions in panels • Timer adjustment via top mounted rotary knob, accessible after assembly • Control signal terminal • DIP-switch for selection of 4 time scales and 8 functions • Accepts output fuse module 093.63, • • 093.63.0.024, 093.63.8.230 (for 5 x 20 mm fuses) for quick and easy load protection, see page 27 Common connection possible with optional jumper links (terminals A1, A2 and 15) UL Listing (certain relay/socket combinations) 39.81 Screw terminal • 6 A electromechanical relay • 12 - 24 V AC/DC supply • Screw terminal and push-in terminal • 35 mm­rail (EN 60715) mounting 39.91 Push-in terminal Fuse module 093.63 093.63.0.024 093.63.8.230 AI: On-delay DI: Interval GI: Pulse (0.5 s) delayed SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on EE: Interval with control signal off For outline drawing see page 22, 23 Contact specification Contact configuration 1 CO (SPDT) Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1  VA 6/10 250/400 1500 Rated load AC15 (230 V AC) VA 300 Single phase motor rating (230 V AC) kW 0.185 Breaking capacity DC1: 30/110/220 V A 6/0.2/0.12 mW (V/mA) 500 (12/10) Minimum switching load Standard contact material AgNi Supply specification Nominal voltage (UN) V AC/DC Rated power AC/DC VA (50 Hz)/W 12 - 24 See page 18 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Technical data Specified time range Repeatability (0.1…3)s, (3…60)s, (1…20)min, (0.3…6)h % ± 1 Recovery time ms ≤ 50 Minimum control impulse ms 50 Setting accuracy - full range  Electrical life at rated load AC1 Ambient temperature range Protection category Approvals relay (according to type) 12 % cycles °C 5 60 · 103 –20…+50 IP 20 XI-2016, www.findernet.com B 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES MasterTIMER - SSR 39.80/39.90 Slim timed interface module, 6.2 mm wide, ideal for space-saving timing solutions in panels • Timer adjustment via top mounted rotary knob; accessible after assembly • Start terminal • DIP-switch for selection of 4 time scales and 8 functions B • Accepts output fuse module 093.63, 093.63.0.024, 093.63.8.230 (for 5 x 20 mm fuses) for quick and easy load protection, see page 27 • Common connection possible with optional jumper links (terminals A1, A2 and 15+) • UL Listing (certain relay/socket combinations) 39.80 Screw terminal • 0.1 or 2 A solid state relay • 12 - 24 V AC/DC supply • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting 39.90 Push-in terminal Fuse module 093.63 093.63.0.024 093.63.8.230 AI: On-delay DI: Interval GI: Pulse (0.5 s) delayed SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on EE: Interval with control signal off For outline drawing see page 22, 23 Output specification (SSR) 39.x0.x.xxx.9024 39.x0.x.xxx.7048 39.x0.x.xxx.8240 Contact configuration Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage Switching voltage range 1 NO (SPST-NO) A 2/20 DC 0.1/0.5 DC 2/40 AC V 24/33 DC 48/60 DC 240/— AC V (1.5…24) DC (1.5…48) DC (12…275) AC 600 Repetitive peak off-state voltage Vpk — — Minimum switching current mA 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 V 0.12 1 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN)V AC/DC Rated power VA (50 Hz)/W 12 - 24 See page 19 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Technical data XI-2016, www.findernet.com Specified time range (0.1…3)s, (3…60)s, (1…20)min, (0.3…6)h Repeatability% ± 1 Recovery time ms ≤ 50 Minimum control impulse ms 50 Setting accuracy – full range  % 5 Ambient temperature range °C –20…+50 Protection category IP 20 Approvals relay (according to type) 13 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterBASIC - EMR ATEX 39.11/39.01 - x073 1 Pole interface module, 6.2 mm wide, ideal for PLC and electronic systems ATEX compliant (EX nA nC) • 1 CO 6 A • Screw terminal and push-in terminal • 35 mm rail (EN 60715) mounting • ATEX compliant jumper links (terminals A1, A2 and 11) and multipole connector MasterADAPTER • 35 mm rail (EN 60715) mounting 39.11 Screw terminal 39.01 Push-in terminal For outline drawing see page 22, 23 Contact specification Contact configuration 1 CO (SPDT) Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1  VA 6/10 250/400 1500 Rated load AC15 (230 V AC) VA 300 Single phase motor rating (230 V AC) kW 0.185 Breaking capacity DC1: 30/110/220 V Minimum switching load A 6/0.2/0.12 mW (V/mA) 500 (12/10) Standard contact material AgNi Coil specification Nominal voltage (UN)V AC/DC V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W 6 - 12 - 24 - 110…125 - 24…240 230…240 6 - 12 - 24 See page 18 Operating range (0.8…1.1)UN Holding voltage 0.6 UN Must drop-out voltage 0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts  Ambient temperature range Protection category Approvals relay (according to type) 14 ms 5/6 kV 6 (8 mm) V AC °C 1000 –40…+70 IP 20 XI-2016, www.findernet.com B • Electromechanical relay • AC, DC and AC/DC Version • Screw terminal and Push-in terminal • UL Listed • Cadmium free contacts • Complies with: --EN 60079-0: 2012 and EN 60079-15:2010 --94/9/CE and 2014/34/UE • Common connection possible with optional 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES Ordering information ATEX versions Example: 39 series, screw terminals interface module, electromechanical relay output, 1 CO 6 A, 24 V DC, ATEX Version. 3 9 . 1 Series Type 0 = Push-in terminals 35 mm rail (EN 60715) mount 1 = Screw terminals 35 mm rail (EN 60715) mount A B C D 1 . 7 . 0 2 4 . 0 0 7 3 A: Contact material 0 = AgNi Standard 5 = AgNi + Au C - D: Option 73 = ATEX Complaiant (Ex nA nC) B B: Contact circuit 0 = CO (nPDT) No. of poles 1 = 1 CO, 6 A Coil version 0 = AC/DC 7 = DC sensitive 8 = AC (50/60 Hz) Coil voltage See coil specifications Other data ATEX versions Max current @ 70 °C Single piece mount > 8 piece mount Type 39.11/01 A 6 5 Type 39.11/01 (110…125)V AC/DC only A 6 4 Terminals Wire strip length  Screw torque  Screw terminals Push-in Terminals mm 10 8 Nm 0.5 — Wire size solid and stranded cable solid and stranded cable 1 x 2.5 1 x 2.5 AWG 1 x 14 1 x 14 mm 2 Markings - ATEX versions - ATEX, II 3G Ex nA nC IIC Gc MARKING XI-2016, www.findernet.com GAS Specific marking of explosion protection II Component for surface plant (different from mines) 3 Category 3: normal level of protection G Explosive atmosphere due to presence of combustible gas vapour or mist Ex nA Non-sparking equipment Ex nC Sealed device (type of protection for category 3G) IIC Gas group Gc Equipment Protection Level –40 °C ≤ Ta ≤ +70 °C Ambient temperature EPT 15 ATEX 0194 U EPT: laboratory which issues the CE type certificate 15: year of issue of certificate 0194: number of CE type certificate U: ATEX component 15 39 SERIES 39 SERIES Relay interface modules - Ordering information Ordering information Example: MasterPLUS 39 series screw terminal interface module, electromechanical relay output, 1 CO (SPDT), 24 V AC/DC coil. 3 9 . 3 B C D 1 . 0 . 0 2 4 . 0 0 6 0 Series Type 1 = MasterBASIC, screw terminal 0 = MasterBASIC, push-in terminal 3 = MasterPLUS, screw terminal, fuse-protectable output 6 = MasterPLUS, push-in terminal, fuse-protectable output 4 = MasterINPUT, screw terminal 7 = MasterINPUT, push-in terminal 2 = MasterOUTPUT, screw terminal 5 = MasterOUTPUT, push-in terminal 8 = MasterTIMER multifunction, screw terminal, fuse-protectable output 9 = MasterTIMER multifunction, push-in terminal, fuse-protectable output No. of poles 1 = 1 CO (only EMR, except 39.21/51, 1 NO) 0 = 1 NO (only SSR) Coil version, EMR / Input version, SSR 0 = AC (50/60 Hz)/DC 3 = Leakage current suppression AC (50/60 Hz) 7 = DC sensitive 8 = AC (50/60 Hz) Coil voltage, EMR/Input voltage, SSR See page 18 D: Special Version, EMR 0 = Standard C: Options, EMR 6 = Standard B: Contact circuit, EMR 0 = CO (except 39.21/51, 1 NO) A: Contact material, EMR 0 = AgNi Standard 4 = AgSnO2 5 = AgNi + Au ABCD: Output version, SSR 7048 = 0.1 A - 48 V DC 8240 = 2 A - 230 V AC 9024 = 2 A - 24 V DC EMR - Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type 39.11/01 39.31/61 39.41/71 39.21/51 39.81/91 Coil version 0.006 - 0.012 0.024 - 0.125 - 8.230 0.006 - 0.012 0.024 - 0.060 0.125 - 0.240 - 8.230 7.125 - 7.220 3.125 - 3.230 0.006 - 0.012 0.024 - 0.125 8.230 0.006 - 0.012 0.024 - 0.125 8.230 0.012 - 0.024 A B C D 0-4-5 0 6 0 0-4-5 0 6 0 0-4-5 0 6 0 0-4-5 0 6 0 0 0 6 0 SSR - Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type 39.10/00 39.30/60 39.40/70 39.20/50 39.80/90 16 Input version 7.006 - 7.012 7.024 - 0.125 - 8.230 7.006 - 7.012 7.024 - 7.060 7.125 - 7.220 0.024 - 0.125 - 0.240 8.230 3.125 - 3.230 7.006 - 7.012 7.024 - 0.024 - 0.125 8.230 7.006 - 7.012 7.024 - 0.125 8.230 0.012 - 0.024 Output version, ABCD 7048 - 8240 - 9024 7048 - 8240 - 9024 7048 - 8240 - 9024 7048 - 8240 - 9024 7048 - 8240 - 9024 XI-2016, www.findernet.com B A 39 SERIES Relay interface modules - Technical data 39 SERIES Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 400 3 2 Insulation between coil and contact set Type of Insulation Reinforced Overvoltage category III Rated impulse voltage B kV (1.2/50)μs 6 Dielectric strength V AC 4000 Insulation between open contacts (EMR) Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50)μs 1000/1.5 Conducted disturbance immunity UN ≤ 60 V Fast transients (burst 5/50 ns, 5 kHz) according to EN 61000-4-4 at supply terminals Voltage pulses (surge 1.2/50 μs) according to EN 61000-4-5 at supply terminals (differential mode) UN = 125 V UN = 230 V kV 4 4 4 kV 0.8 2 4 Other data Bounce time (EMR): NO/NC ms 1/6 Vibration resistance (EMR,10…55 Hz): NO/NC Power lost to the environment g 10/15 without contact current W 0.2 (24 V) - 0.4 (230 V) with rated current W 0.6 (24 V) - 0.9 (230 V) Terminals Screw terminal Wire strip length Screw torque Push-in terminal mm 10 8 Nm 0.5 — Solid and stranded cable Max. wire size Min. wire size Solid and stranded cable mm2 1 x 2.5 / 2 x 1.5 1 x 2.5 AWG 1 x 14 / 2 x 16 1 x 14 mm2 1 x 0.2 1 x 0.2 AWG 1 x 24 1 x 24 Contact specification (EMR) Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 H 39 - Maximum DC1 breaking capacity DC breaking current (A) Cycles F 39 - Electrical life (AC) v contact current XI-2016, www.findernet.com DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 60 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the ­­­­ load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 17 39 SERIES Relay interface modules - Technical data 39 SERIES Coil specifications - Electromechnical Relay Coil data DC, type 39.31/61 Nominal voltage Must drop‑out voltage Rated power at UN UN Umin Umax Ur Rated input current at UN IN V V V V mA W Operating range 125 (110…125) 7.125 88 138 12.5 4.6 0.6 220 7.220 176 242 22 3.0 0.6 Coil data AC/DC, type 39.11/21/31/41/01/51/61/71 Nominal voltage Coil code Operating range Must drop‑out voltage UN Umin Umax V V V 4.8 6.6 0.6 35 Ur Rated power at UN Rated input current at UN IN V mA VA/W 6 0.006 12 0.012 9.6 13.2 1.5 15 0.2/0.2 24 0.024 19.2 26.4 2.4 11 0.25/0.25 60(1) 0.060 48 66 6.0 5.7 0.35/0.35 0.125 88 138 12.5 5.6 0.7/0.7 0.240 20.4 264 2.4 125 (110…125) 240 (24…240)(2) 0.2/0.2 19 (1) (2) 60 V AC/DC for type 39.31/61 only 24…240 V AC/DC for type 39.31/61 only 1.5/0.3 Coil data AC, type 39.11/21/31/41/01/51/61/71 Nominal voltage Coil code UN Umin Umax Ur V V V V mA VA/W 184 264 23 4.3 1/0.4 Rated power at UN 230 (230…240) 8.230 Must drop‑out voltage Rated power at UN Rated input current at UN IN Operating range Coil data leakage current suppression versions, type 39.31.3/61.3 Nominal voltage Coil code UN Umin Umax Ur Rated input current at UN IN V V V V mA VA/W 3.125 88 138 44 8.4 1.1/1 3.230 184 264 72 5.9 1.4/0.5 125 (110…125) 230 (230…240) Operating range Must drop‑out voltage The 39 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110…125)V AC/DC and (230…240)V AC. This problem can occur, for example, when connecting the interface modules to PLC's with triac outputs or when connecting via relatively long cables.­­ Coil data AC/DC timer, type 39.81/91 Nominal voltage Coil code Operating range (AC/DC) Must drop‑out voltage Rated input current at UN DC AC Rated power at UN UN Umin Umax Ur DC AC V V V V mA mA W VA/W 12 0.012 9.6 13.2 1.2 15 23 0.2 0.3/0.2 24 0.024 19.2 26.4 2.4 11 19 0.25 0.4/0.3 XI-2016, www.findernet.com B Coil code 18 39 SERIES Relay interface modules - Technical data 39 SERIES Input specifications - Solid State Relay Input data DC, type 39.10/20/30/40/00/50/60/70 Nominal voltage Input code Must drop‑out voltage Rated power at UN UN Umin Umax Ur Rated input current at UN IN V V V V mA W Operating range 6 7.006 4.8 6.6 0.6 7.5 0.2 12 7.012 9.6 13.2 1.2 20.7 0.25 B 24 7.024 19.2 26.4 2.4 10.5 0.25 60 (1) 7.060 38 66 6.0 6.4 0.4 125 (1) (110…125) 7.125 88 138 12.5 4.6 0.6 220 (1) 7.220 176 242 22 3.0 0.6 Rated input current at UN IN Rated power at UN (1) 60 V DC, 125 V DC and 220 V DC for type 39.30/60 only (2) 24 V AC/DC for type 39.30/40/60/70 only 24…240 V AC/DC for type 39.30/60 only Input data AC/DC, type 39.10/20/30/40/00/50/60/70 Nominal voltage Input code Operating range UN Umin Umax V V V 24 (2) 125 (110…125) 240 (24…240)(3) 0.024 19.2 0.125 88 0.240 20.4 Must drop‑out voltage Ur V mA VA/W 2.4 17.5 0.4/0.3 138 12.5 5.5 0.7/0.7 264 2.4 17.5 1.5/0.3 26.4 (3) Input data AC, type 39.10/20/30/40/00/50/60/70 Nominal voltage Input code UN Umin Umax Ur V V V V mA VA/W 184 264 23 4.2 1/0.4 230 (230…240) 8.230 Must drop‑out voltage Rated power at UN Rated input current at UN IN Operating range Input data leakage current suppression versions, type 39.30.3/60.3 Nominal voltage Input code UN Umin Umax Ur V V V V mA VA/W 3.125 88 138 44 8.4 1.1/1 3.230 184 264 72 5.9 1.4/0.5 125 (110…125) 230 (230…240) Must drop‑out voltage Rated power at UN Rated input current at UN IN Operating range The 39 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110…125)V AC/DC and (230…240)V AC. This problem can occur, for example, when connecting the interface modules to PLC's with triac outputs or when ­­connecting via relatively long cables. Input data AC/DC timer, type 39.80/90 Nominal voltage Input code Operating range (AC/DC) Must drop‑out voltage UN Umin Umax Ur V V V V Rated input current at UN DC AC mA mA Rated power at UN DC AC W VA/W 0.012 9.6 13.2 1.2 15 23 0.2 0.3/0.2 0.024 19.2 26.4 2.4 11 19 0.25 0.4/0.3 XI-2016, www.findernet.com 12 24 19 39 SERIES 39 SERIES Timed interface modules Timer specifications EMC specifications Type of test Reference standard Electrostatic discharge Fast transients (burst) (5-50 ns, 5 and 100 kHz) Surges (1.2/50 μs) on supply and control signal terminals 4 kV air discharge EN 61000-4-2 8 kV (80 ÷ 1000 MHz) EN 61000-4-3 10 V/m (1400 ÷ 2700 MHz) EN 61000-4-3 10 V/m on Supply terminals EN 61000-4-4 4 kV on control signal terminals EN 61000-4-4 4 kV common mode EN 61000-4-5 2 kV differential mode EN 61000-4-5 on Supply terminals EN 61000-4-6 Radio-frequency common mode (0.15 ÷ 80 MHz) on control signal terminals EN 61000-4-6 Radiated and conducted emission EN 55022 0.8 kV 10 V 3 V class B Other data Bounce time (EMR): NO/NC ms 1/6 Vibration resistance (EMR,10..55 Hz): NO/NC g 10/15 Power lost to the environment without contact current W 0.3 with rated current W 0.8 Terminals Screw terminal Wire strip length Screw torque Max. wire size 8 Nm 0.5 — mm 2 Min. wire size Push-in terminal mm 10 Solid and stranded cable Solid and stranded cable 1 x 2.5 / 2 x 1.5 1 x 2.5 AWG 1 x 14 / 2 x 16 1 x 14 mm2 1 x 0.2 1 x 0.2 AWG 1 x 24 1 x 24 Times scales 1 2 3 4 5 (0.1…3)s Functions 20 LED 1 2 3 4 5 (3…60)s 1 2 3 4 5 (1…20)min 1 2 3 4 5 (0.3…6)h Supply voltage NO contact/output OFF Open ON Open ON Open (timing to close in progress) ON Closed XI-2016, www.findernet.com B Radio-frequency electromagnetic field contact discharge EN 61000-4-2 39 SERIES Timed interface modules Wiring diagram U = Supply voltage Without control signal 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 With control signal 1 2 3 4 5 * * With DC supply, positive polarity has to be conneted to B1, terminal (according to EN 60204-1). 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 39 SERIES S = Signal switch = Output contact (AI) On-delay Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs when power is removed. (DI) Interval Apply power to timer. Output contacts transfer immediately. After the preset time has elapsed, contacts reset. (GI) Pulse (0.5 s) delayed Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs after a fixed time of 0.5 s. (SW) Symmetrical flasher (starting pulse on) Apply power to timer. Output contacts transfer immediately and cycle between ON and OFF for as long as power is applied. The ratio is 1:1 (time on = time off ). (BE) Off-delay with control signal Power is permenently applied to the timer. The output contacts transfer immediately on closure of the Signal Switch (S). Opening the Signal Switch initiates the preset delay, after which time the output contacts reset. (CE) On- and off-delay with control signal Power is permenently applied to the timer. Closing the Signal Switch (S) initiates the preset delay, after which time the output contacts transfer. Opening the Signal switch initiates the same preset delay, after which time the output contacts reset. (DE) Interval with control signal on Power is permenently applied to the timer. On momentary or maintained closure of Signal Switch (S), the output contacts transfer, and remain so for the duration of the preset delay, after which they reset. (EE) Interval with control signal off Power is permenently applied to the timer. On opening of the Signal Switch (S) the output contacts transfer, and remain so for the duration of the preset delay, after which they reset. XI-2016, www.findernet.com • Possible to control an external load, such as another relay coil or timer, connected to the control signal terminal B1. ** A voltage other than the supply voltage can be applied to the command Start (B1), example: A1 - A2 = 24 V AC B1 - A2 = 12 V DC 21 B 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A Outline drawings - Screw terminal sockets 39.10/39.20 39.11/39.21 Screw terminal 39.30/39.30.3 39.31/39.31.3 Screw terminal 39.40 39.41 Screw terminal 39.80 39.81 Screw terminal XI-2016, www.findernet.com B 22 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES Outline drawings - Push-in terminal sockets 39.00/39.01 39.50/39.51 Push-in terminal 39.60/39.60.3 39.61/39.61.3 Push-in terminal B 39.70 39.71 Push-in terminal 39.90 39.91 Push-in terminal Main features Push-in terminals The push-in terminals permit the quick connection of solid wires or ferrules by their simple insertion into the terminal (A). It is possible to open the terminal to extract the wire by first pushing down on the push-button using a screwdriver (C). For stranded cable it is necessary first to open the terminal using the push button, both for the extraction (C) and insertion (B). It is possible at any time to check the connection via the test aperture, using a 2 mm diameter test probe (D). B C D XI-2016, www.findernet.com A 23 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A Electromechanical Relay (1 Pole 6 A) & Screw Socket Combinations Interface Module Code MasterBASIC 39.11.0.006.0060 39.11.0.012.0060 39.11.0.024.0060 39.11.0.125.0060 39.11.8.230.0060 MasterPLUS 39.31.0.006.0060 39.31.0.012.0060 39.31.0.024.0060 39.31.0.060.0060 39.31.0.125.0060 39.31.0.240.0060 39.31.8.230.0060 39.31.7.125.0060 39.31.7.220.0060 39.31.3.125.0060 39.31.3.230.0060 MasterINPUT 39.41.0.006.5060 39.41.0.012.5060 39.41.0.024.5060 39.41.0.125.5060 39.41.8.230.5060 MasterOUTPUT  1 NO, 6 A only 39.21.0.006.0060 39.21.0.012.0060 39.21.0.024.0060 39.21.0.125.0060 39.21.8.230.0060 MasterTIMER 39.81.0.012.0060 39.81.0.024.0060 B Coil voltage Relay Socket 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 93.61.7.024 93.61.7.024 93.61.7.024 93.61.0.125 93.61.8.230 6 V AC/DC 12 V AC/DC 24 V AC/DC 60 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC (110…125)V DC 220 V DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 93.63.7.024 93.63.7.024 93.63.7.024 93.63.7.060 93.63.0.125 93.63.0.240 93.63.8.230 93.63.7.125 93.63.7.220 93.63.3.125 93.63.3.230 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.5010 34.51.7.012.5010 34.51.7.024.5010 34.51.7.060.5010 34.51.7.060.5010 93.64.7.024 93.64.7.024 93.64.7.024 93.64.0.125 93.64.8.230 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 93.62.7.024 93.62.7.024 93.62.7.024 93.62.0.125 93.62.8.230 12 V AC/DC 24 V AC/DC 34.51.7.012.0010 34.51.7.024.0010 93.68.0.024 93.68.0.024 Example: .xxxx .9024 .7048 .8240 24 Interface Module Code MasterBASIC 39.10.7.006.xxxx 39.10.7.012.xxxx 39.10.7.024.xxxx 39.10.0.125.xxxx 39.10.8.230.xxxx MasterPLUS 39.30.7.006.xxxx 39.30.7.012.xxxx 39.30.7.024.xxxx 39.30.7.060.xxxx 39.30.7.125.xxxx 39.30.7.220.xxxx 39.30.0.024.xxxx 39.30.0.125.xxxx 39.30.0.240.xxxx 39.30.8.230.xxxx 39.30.3.125.xxxx 39.30.3.230.xxxx MasterINPUT 39.40.7.006.xxxx 39.40.7.012.xxxx 39.40.7.024.xxxx 39.40.0.024.xxxx 39.40.0.125.xxxx 39.40.8.230.xxxx MasterOUTPUT 39.20.7.006.xxxx 39.20.7.012.xxxx 39.20.7.024.xxxx 39.20.0.125.xxxx 39.20.8.230.xxxx MasterTIMER 39.80.0.012.xxxx 39.80.0.024.xxxx Input voltage Relay Socket 6 V DC 12 V DC 24 V DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.61.7.024 93.61.7.024 93.61.7.024 93.61.0.125 93.61.8.230 6 V DC 12 V DC 24 V DC 60 V DC (110…125)V DC 220 V DC 24 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.63.7.024 93.63.7.024 93.63.7.024 93.63.7.060 93.63.7.125 93.63.7.220 93.63.0.024 93.63.0.125 93.63.0.240 93.63.8.230 93.63.3.125 93.63.3.230 6 V DC 12 V DC 24 V DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.64.7.024 93.64.7.024 93.64.7.024 93.64.0.024 93.64.0.125 93.64.8.230 6 V DC 12 V DC 24 V DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.62.7.024 93.62.7.024 93.62.7.024 93.62.0.125 93.62.8.230 12 V AC/DC 24 V AC/DC 34.81.7.012.xxxx 34.81.7.024.xxxx 93.68.0.024 93.68.0.024 XI-2016, www.findernet.com Solid State Relay (1 Pole 0.1 or 2 A) & Screw Socket Combinations 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES Electromechanical Relay (1 Pole 6 A) & Push-in Socket Combinations Interface Module Code MasterBASIC 39.01.0.006.0060 39.01.0.012.0060 39.01.0.024.0060 39.01.0.125.0060 39.01.8.230.0060 MasterPLUS 39.61.0.006.0060 39.61.0.012.0060 39.61.0.024.0060 39.61.0.060.0060 39.61.0.125.0060 39.61.0.240.0060 39.61.8.230.0060 39.61.7.125.0060 39.61.7.220.0060 39.61.3.125.0060 39.61.3.230.0060 MasterINPUT 39.71.0.006.5060 39.71.0.012.5060 39.71.0.024.5060 39.71.0.125.5060 39.71.8.230.5060 MasterOUTPUT  1 NO, 6 A only 39.51.0.006.0060 39.51.0.012.0060 39.51.0.024.0060 39.51.0.125.0060 39.51.8.230.0060 MasterTIMER 39.91.0.012.0060 39.91.0.024.0060 Coil voltage Relay Socket 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 93.60.7.024 93.60.7.024 93.60.7.024 93.60.0.125 93.60.8.230 6 V AC/DC 12 V AC/DC 24 V AC/DC 60 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC (110…125)V DC 220 V DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 93.66.7.024 93.66.7.024 93.66.7.024 93.66.7.060 93.66.0.125 93.66.0.240 93.66.8.230 93.66.7.125 93.66.7.220 93.66.3.125 93.66.3.230 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.5010 34.51.7.012.5010 34.51.7.024.5010 34.51.7.060.5010 34.51.7.060.5010 93.67.7.024 93.67.7.024 93.67.7.024 93.67.0.125 93.67.8.230 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 93.65.7.024 93.65.7.024 93.65.7.024 93.65.0.125 93.65.8.230 12 V AC/DC 24 V AC/DC 34.51.7.012.0010 34.51.7.024.0010 93.69.0.024 93.69.0.024 B XI-2016, www.findernet.com Solid State Relay (1 Pole 0.1 or 2 A) & Push-in Socket Combinations Example: .xxxx .9024 .7048 .8240 Interface Module Code MasterBASIC 39.00.7.006.xxxx 39.00.7.012.xxxx 39.00.7.024.xxxx 39.00.0.125.xxxx 39.00.8.230.xxxx MasterPLUS 39.60.7.006.xxxx 39.60.7.012.xxxx 39.60.7.024.xxxx 39.60.7.060.xxxx 39.60.7.125.xxxx 39.60.7.220.xxxx 39.60.0.024.xxxx 39.60.0.125.xxxx 39.60.0.240.xxxx 39.60.8.230.xxxx 39.60.3.125.xxxx 39.60.3.230.xxxx MasterINPUT 39.70.7.006.xxxx 39.70.7.012.xxxx 39.70.7.024.xxxx 39.70.0.024.xxxx 39.70.0.125.xxxx 39.70.8.230.xxxx MasterOUTPUT 39.50.7.006.xxxx 39.50.7.012.xxxx 39.50.7.024.xxxx 39.50.0.125.xxxx 39.50.8.230.xxxx MasterTIMER 39.90.0.012.xxxx 39.90.0.024.xxxx Input voltage Relay Socket 6 V DC 12 V DC 24 V DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.60.7.024 93.60.7.024 93.60.7.024 93.60.0.125 93.60.8.230 6 V DC 12 V DC 24 V DC 60 V DC (110…125)V DC 220 V DC 24 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.66.7.024 93.66.7.024 93.66.7.024 93.66.7.060 93.66.7.125 93.66.7.220 93.66.0.024 93.66.0.125 93.66.0.240 93.66.8.230 93.66.3.125 93.66.3.230 6 V DC 12 V DC 24 V DC 24 V AC/DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.67.7.024 93.67.7.024 93.67.7.024 93.67.0.024 93.67.0.125 93.67.8.230 6 V DC 12 V DC 24 V DC (110…125)V AC/DC (230…240)V AC 34.81.7.005.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.65.7.024 93.65.7.024 93.65.7.024 93.65.0.125 93.65.8.230 12 V AC/DC 24 V AC/DC 34.81.7.012.xxxx 34.81.7.024.xxxx 93.69.0.024 93.69.0.024 25 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A MasterBASIC ATEX version, Screw Socket Combinations Interface Module Code MasterBASIC ATEX 39.11.0.006.0073 39.11.0.012.0073 39.11.0.024.0073 39.11.0.125.0073 39.11.0.240.0073 39.11.8.230.0073 39.11.7.006.0073 39.11.7.012.0073 39.11.7.024.0073 B Coil voltage Relay Socket 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC 6 V DC 12 V DC 24 V DC 34.51.7.005.0000 34.51.7.012.0000 34.51.7.024.0000 34.51.7.060.0000 34.51.7.024.0000 34.51.7.060.0000 34.51.7.005.0000 34.51.7.012.0000 34.51.7.024.0000 93.61.0.024.7 93.61.0.024.7 93.61.0.024.7 93.61.0.125.7 93.61.0.240.7 93.61.8.230.7 93.61.7.024.7 93.61.7.024.7 93.61.7.024.7 MasterBASIC ATEX version, Push-in Socket Combinations Input voltage Relay Socket 6 V AC/DC 12 V AC/DC 24 V AC/DC (110…125)V AC/DC (24…240)V AC/DC (230…240)V AC 6 V DC 12 V DC 24 V DC 34.51.7.005.0000 34.51.7.012.0000 34.51.7.024.0000 34.51.7.060.0000 34.51.7.024.0000 34.51.7.060.0000 34.51.7.005.0000 34.51.7.012.0000 34.51.7.024.0000 93.60.0.024.7 93.60.0.024.7 93.60.0.024.7 93.60.0.125.7 93.60.0.240.7 93.60.8.230.7 93.60.7.024.7 93.60.7.024.7 93.60.7.024.7 XI-2016, www.findernet.com Interface Module Code MasterBASIC ATEX 39.01.0.006.0073 39.01.0.012.0073 39.01.0.024.0073 39.01.0.125.0073 39.01.0.240.0073 39.01.8.230.0073 39.01.7.006.0073 39.01.7.012.0073 39.01.7.024.0073 26 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES Accessories Output fuse module for 39.31/30/81/80/61/60/91/90 types - For 5 x 20 mm fuses up to 6 A, 250 V - Easy visibility of the fuse condition through the window - Type 093.63.0.024 - (6…24)V AC/DC - Type 093.63.8.230 - (110…240)V AC - Quick connection to socket 093.63 Approvals (according to type): 093.63 093.63.0.024 093.63.8.230 Notes Safety: Because the output circuit can be reinstated (point 3 below), even with the fuse removed, it is important not to consider the removal of the fuse as a “safety disconnect”. Always isolate elsewhere before working on the circuit. UL: According to UL508A, the fuse module cannot be installed in power circuits (in which it is mandatory that a fuse certified according to UL category JDDZ be fitted). However, where the MasterInterface is connected as an output interface to a PLC no such restrictions apply, and the fuse module can be usefully employed. Type 093.63 Type 093.63.0.24 / 093.63.8.230 093.63.0.024 093.63.8.230 Multi-state fuse module 0. As delivered, the socket comes without a fuse module. However, the absent fuse is internally replaced with an electrical link - which allows the interface relay to be used without a fuse module. In this state, the peg/indicator is visually hidden and the connection is protected by a special cap. 1. With fuse module inserted after removing the cap, the fuse is positioned electrically in series with the common output terminal of the interface module (11 for EMR versions, 13+ for SSR versions, 15 for EMR timer, 15+ for SSR timer). This state is indicated by the peg/indicator. 2. If the fuse module is extracted (for example; because the fuse element has blown) the output circuit will be locked open, as this will generally be the “safe option”. This state is indicated by the peg/indicator. XI-2016, www.findernet.com 3. In order to reinstate the output circuit it is necessary to either re-insert the fuse module (complete with functional fuse), or alternatively, return the peg/indicator to position 0 by gently applying pressure in the direction of the arrow. 27 B 39 SERIES 39 SERIES Relay interface modules 0.1 - 2 - 6 A Accessories 16-way jumper link Rated values Possibility of multiple connection, side by side 093.16 093.16 (blue) 6 A - 250 V 093.16.0 (black) 093.16.1 (red) 093.16.0 B 093.16.1 Approvals (according to type): Dual-purpose plastic separator (1.8 mm or 6.2 mm separation) 093.60 1. By breaking off the protruding ribs (by hand), the separator becomes only 1.8 mm thick; useful for the visual separation of different groups of interfaces, or necessary for the protective separation of different voltages of neighbouring interfaces, or for the protection of cut ends of jumper links. 093.60 2. Leaving the ribs in place provides 6.2 mm separation. Simply cutting (with scissors) the relevant segment(s) permits the interconnection across the separator of 2 different groups of interface relays, using the standard jumper link. Sheet of marker tags (CEMBRE'S Thermal transfer printers) ,48 tags, 6 x 12 mm 060.48 XI-2016, www.findernet.com 060.48 28 39 SERIES Relay interface modules 0.1 - 2 - 6 A 39 SERIES Accessories Terminal doubler (for Push-in sockets only) 093.62 Total load 6 A - 300 V Solid and stranded cable Max. wire size mm 2 2 x 1.5 AWG 2 x 16 B MasterADAPTER 093.68.14.1 The MasterADAPTER permits the easy connection of A1/A2 terminals of up to MasterINTERFACE modules to PLC outputs via a 14-Pole ribbon cable, plus simple 2-wire power supply connection ATEX Version. Technical data A 1 Rated current (per signal path) Minimum required supply power W 3 Nominal voltage (UN) V DC 24 093.68.14.1 Operating range (0.8…1.1)UN Approvals (according to type): Control logic Positive switching (to A1) Power supply status indication Green LED Ambient temperature range  °C –40…+70 Terminals for 24 V control logic Type of connector 14 pole, according to IEC 60603-13 ATEX version II 3G Ex nA IIC Gc Terminals for 24 V power supply Wire strip length mm 9.5 Screw torque Nm 0.5 Max. wire size solid wire mm2 1 x 4 / 2 x 1.5 AWG 1 x 12 / 2 x 16 Connected MasterADAPTER stranded wire mm2 1 x 2.5 / 2 x 1.5 AWG 1 x 14 / 2 x 16 XI-2016, www.findernet.com Wiring diagram 29
39.31.3.230.0060 价格&库存
很抱歉,暂时无法提供与“39.31.3.230.0060”相匹配的价格&库存,您可以联系我们找货
  • 1+196.216281+25.45890
  • 10+178.1013310+23.10850
  • 20+167.8245820+21.77510
  • 1+276.20620
库存:2
