55.34.9.024.0074
55.34.9.024.0074
    FINDER
    SOCKETABLE
    RLY 4PDT 7A 24V DC
55.34.9.024.0074 数据手册
55 Series - General purpose relays 7 - 10 A Features 55.12 55.13 55.14 Printed circuit mount, general purpose 2, 3 & 4 Pole relays 55.12 - 2 Pole 10 A 55.13 - 3 Pole 10 A 55.14 - 4 Pole 7 A AC coils & DC coils Cadmium Free contacts (preferred version) • Contact material options • RT III (wash tight) option available • • • • 55.12 55.13 2 pole, 10 A PCB mount • • 3 pole, 10 A PCB mount • • 4 pole, 7 A PCB mount 55.14 FOR UL HORSEPOWER AND PILOT DUTY RATINGS SEE “General technical information” page V Copper side view Copper side view Copper side view 2 CO (DPDT) 3 CO (3PDT) 4 CO (4PDT) Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 10/20 10/20 7/15 250/400 250/400 250/250 Rated load AC1 VA 2,500 2,500 1,750 Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 1.5/1 1.5/1 1.5/1 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 20 · 106/50 · 106 DC Technical data Mechanical life AC/DC Electrical life at rated load AC1 Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 3 200 · 10 3 200 · 10 150 · 103 9/3 9/3 9/3 4 4 4 1,000 1,000 1,000 –40…+85 –40…+85 –40…+85 RT I RT I RT I Approvals (according to type) 1 55 Series - General purpose relays 7 - 10 A Features 55.32 55.33 55.34 Plug-in mount, general purpose 2, 3 & 4 Pole relays 55.32 - 2 Pole 10 A 55.33 - 3 Pole 10 A 55.34 - 4 Pole 7 A Lockable test button and mechanical flag indicator as standard on 2 & 4 pole types • AC coils & DC coils • UL Listing (certain relay/socket combinations) • Cadmium Free contacts (preferred version) • Contact material options • 94 series sockets • Coil EMC suppression • Timer accessories 86 series • 55.32 55.33 • • 2 pole, 10 A Plug-in 94 series sockets • • 3 pole, 10 A Plug-in 94 series sockets • • 4 pole, 7 A Plug-in 94 series sockets 55.34 FOR UL HORSEPOWER AND PILOT DUTY RATINGS SEE “General technical information” page V Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 3 CO (3PDT) 4 CO (4PDT) 10/20 10/20 7/15 250/400 250/400 250/250 Rated load AC1 VA 2,500 2,500 1,750 Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 125 - 220 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 1.5/1 1.5/1 1.5/1 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 20 · 106/50 · 106 DC Technical data Mechanical life AC/DC Electrical life at rated load AC1 Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection Approvals (according to type) 2 °C 3 3 200 · 10 200 · 10 150 · 103 9/3 9/3 9/3 4 4 4 1,000 1,000 1,000 –40…+85 –40…+85 –40…+85 RT I RT I RT I 55 Series - General purpose relays 7 - 10 A Ordering information Example: 55 series plug-in relay, 4 CO (4PDT), 12 V DC coil, lockable test button and mechanical indicator. 5 5 . 3 A B C D 4 . 9 . 0 1 2 . 0 0 4 0 Series Type 1 = PCB 3 = Plug-in No. of poles 2 = 2 pole, 10 A 3 = 3 pole, 10 A 4 = 4 pole, 7 A A: Contact material 0 = Standard AgNi 2 = AgCdO 5 = AgNi + Au (5 µm) D: Special versions 0 = Standard 1 = Wash tight (RT III) for 55.12, 55.13 and 55.14 only B: Contact circuit 0 = CO (nPDT) C: Options 0 = None 1 = Lockable test button 2 = Mechanical indicator 3 = LED (AC) 4 = Lockable test button+mechanical indicator 5 = Lockable test button + LED (AC) 54 = Lockable test button + LED (AC) + mechanical indicator 6* = Double LED (DC non-polarized) 7* = Lockable test button + double LED (DC non-polarized) 74* = Lockable test button + double LED (DC non-polarized) + mechanical indicator 8* = LED + diode (DC, polarity positive to pin A1/13) 9* = Lockable test button + LED + diode (DC, polarity positive to pin A1/13) 94* = Lockable test button + LED + diode (DC, polarity positive to pin A1/13) + mechanical indicator * Option not available for the 220 V DC version. Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version 55.32/34 AC-DC AC AC DC DC 55.33 AC-DC AC DC 55.12/13/14 AC-DC A 0-2-5 0-2-5 0-2-5 0-2-5 0-2-5 0-2-5 0-2-5 0-2-5 0-2-5 B 0 0 0 0 0 0 0 0 0 C 0 2-3-4-5 54 2-4 -6 -7-8-9 74 - 94 0 1-3-5 1-6-7-8-9 0 D 0 0 / 0 / 0 0 0 0-1 Descriptions: options and special versions C: Option 3, 5, 54 LED (AC) C: Option 6, 7, 74 Double LED (DC non-polarized) C: Option 8, 9, 94 LED + diode (DC, polarity positive to pin A1/13) 3 1 2 Lockable test button and mechanical flag indicator (0010, 0040, 0050, 0054, 0070, 0074, 0090, 0094) The dual-purpose Finder test button can be used in two ways: Case 1) The plastic pip (located directly above the test button) remains intact. In this case, when the test button is pushed, the contacts operate. When the test button is released the contacts return to their former state. Case 2) The plastic pip is broken-off (using an appropriate cutting tool). In this case, (in addition to the above function), when the test button is pushed and rotated, the contacts are latched in the operating state, and remain so until the test button is rotated back to its former position. In both cases ensure that the test button actuation is swift and decisive. 3 55 Series - General purpose relays 7 - 10 A Technical data Insulation according to EN 61810-1 2 pole - 3 pole Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 400 Pollution degree 4 pole 230 250 2 2 Insulation between coil and contact set Type of Insulation Basic Basic Overvoltage category III III Rated impulse voltage kV (1.2/50 µs) 4 4 Dielectric strength V AC 2,000 2,000 Insulation between adjacent contacts Type of insulation Basic Basic Overvoltage category III II Rated impulse voltage kV (1.2/50 µs) 4 Dielectric strength 2.5 V AC 2,000 1,550 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength Micro-disconnection V AC/kV (1.2/50 µs) 1,000/1.5 1,000/1.5 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 4 (4 kV) Other data Bounce time: NO/NC ms 1/4 Vibration resistance (5…55)Hz: NO/NC g 15/15 Shock resistance g 16 Power lost to the environment without contact current with rated current Recommended distance between relays mounted on PCB W 1 W 3 (2 pole) 4 (3 pole) 3 (4 pole) mm ≥ 5 Contact specification F 55 - Electrical life (AC) v contact current 4 pole relay Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Cycles Cycles F 55 - Electrical life (AC) v contact current 2 and 3 pole relays Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 DC breaking current (A) H 55 - Maximum DC1 breaking capacity 2 & 3 pole current limit 4 pole current limit contacts in series DC voltage (V) 4 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 55 Series - General purpose relays 7 - 10 A Coil specifications DC coil data Nominal voltage UN V 6 12 24 48 60 110 125 220 AC coil data Coil code Operating range 9.006 9.012 9.024 9.048 9.060 9.110 9.125 9.220 Umin V 4.8 9.6 19.2 38.4 48 88 100 176 Umax V 6.6 13.2 26.4 52.8 66 121 138 242 Resistance Rated coil consumption R I at UN Ω mA 40 150 140 86 600 40 2,400 20 4,000 15 12,500 8.8 17,300 7.2 54,000 4 Nominal voltage UN V 6 12 24 48 60 110 120 230 240 Coil code 8.006 8.012 8.024 8.048 8.060 8.110 8.120 8.230 8.240 Operating range Umin V 4.8 9.6 19.2 38.4 48 88 96 184 192 Umax V 6.6 13.2 26.4 52.8 66 121 132 253 264 Resistance Rated coil consumption R I at UN (50Hz) Ω mA 12 200 50 97 190 53 770 25 1,200 21 4,000 12.5 4,700 12 17,000 6 19,100 5.3 R 55 - DC coil operating range v ambient temperature R 55 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Accessories Top flange mount adaptor for 55.32, 55.33, 55.34 056.25 056.25 with relay 056.25 056.27 Rear flange mount adaptor for 55.32, 55.33, 55.34 056.26 056.25 with relay 056.27 with 056.26 relay 056.26 with relay 056.26 Top 35 mm rail (EN 60715) adaptor for 55.32, 55.33, 55.34 056.27 056.25 056.26 with relay 056.27 056.27 with relay 056.27 056.27 with relay 5
55.34.9.024.0074 价格&库存
很抱歉,暂时无法提供与“55.34.9.024.0074”相匹配的价格&库存,您可以联系我们找货
  • 1+98.01504
库存:1190
55.34.9.024.0074
  • 10+136.5466910+17.67455
