7L.43.0.230.1200
7L.43.0.230.1200
    FINDER
    FINDER - 7L.43.0.230.1200 - LED Light Bar, Cool White, 600 lm, 6 W, 240 V, 310.6 mm, IP20
7L.43.0.230.1200 数据手册
LED panel light 7L SЕRIES Panels for electrical distribution Control panels FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 7L 7L SERIES LED panel light SERIES 7L.43.0.xxx.0x00 LED light for electrical panels Type 7L.43.0.xxx.0x00 - 600 lumens - Direct magnetic mounting or through a screw-fixed metallic support • Low power consumption • Radiation angle 120° • Colour temperature 5000 K • Push-in terminals for the connection to a single unit • Plug-in terminals for the connection to a single or multiple units (up to 7 lamps) • Design by Minelli - Fossati • 600 lumens, 6 W • Without ON/OFF switch or movement detector G For outline drawing see page 8 Lamp Data Type of lamp LED, viewing angle 120°, Light colour: daylight white, colour temperature: 5000 K Luminous flux Life time lm 600 h 60000 Electrical Data Operating voltage V AC (50/60 Hz)/DC 12…48 - 110…240 V AC/DC 9.6…52.8 - 88…264 Operating range Nominal current @230 V AC mA 39 Nominal current @24 V DC mA 200 Rated power of the lamp @230 V AC W 6 Rated power of the lamp @24 V DC W 6 X-2020, www.findernet.com General data Connection cable to the lamp Sheathed cable 2 x 1.5 mm², flexible with push-in or socket Interconnectors from lamp to lamp Sheathed cable 2 x 1.5 mm², flexible with plug and socket Socket and plug 2-pole with interlock Type of mounting Magnetic or clip fixing Housing Ambient temperature Protection class Protection category Plastic, transparent °C −30…+55 II IP 20 Approvals (according to type) 3 7L SERIES 7L SERIES LED panel light 7L.43.0.xxx.1x00 LED light for electrical panels 7L.46.0.xxx.1x00 Type 7L.43.0.xxx.1x00 - 600 lumens - Direct magnetic mounting or through a screw-fixed metallic support Type 7L.46.0.xxx.1x00 - 1200 lumens - Direct magnetic mounting or through a screw-fixed metallic support • Low power consumption • Radiation angle 120° • Colour temperature 5000 K • Push-in terminals for the connection to a • 600 lumens, 6 W • With ON/OFF switch • 1200 lumens, 9 W • With ON/OFF switch single unit • Plug-in terminals for the connection to a single or multiple units (up to 7 lamps) • Design by Minelli - Fossati G For outline drawing see page 9 Lamp Data Type of lamp LED, viewing angle 120°, Light colour: daylight white, colour temperature: 5000 K Luminous flux lm Life time 600 h 1200 60000 Electrical Data Operating voltage V AC (50/60 Hz)/DC Operating range 12…48 - 110…240 V AC/DC 9.6…52.8 - 88…264 Nominal current @230 V AC mA 39 54 Nominal current @24 V DC mA 200 300 Rated power of the lamp @230 V AC W 6 9 Rated power of the lamp @24 V DC W 6 9 Connection cable to the lamp Sheathed cable 2 x 1.5 mm², flexible with push-in or socket Interconnectors from lamp to lamp Sheathed cable 2 x 1.5 mm², flexible with plug and socket Socket and plug 2-pole with interlock Type of mounting Magnetic or clip fixing Housing Ambient temperature Protection class Protection category Approvals (according to type) 4 Plastic, transparent °C −30…+55 II IP 20 X-2020, www.findernet.com General data 7L 7L SERIES LED panel light SERIES 7L.43.0.xxx.2x00 LED light for electrical panels 7L.46.0.xxx.2x00 Type 7L.43.0.xxx.2x00 - 600 lumens - Direct magnetic mounting or through a screw-fixed metallic support Type 7L.46.0.xxx.2x00 - 1200 lumens - Direct magnetic mounting or through a screw-fixed metallic support • Low power consumption • Radiation angle 120° • Colour temperature 5000 K • Push-in terminals for the connection to a • 600 lumens, 6 W • With movement detector • 1200 lumens, 9 W • With movement detector single unit • Plug-in terminals for the connection to a single or multiple units (up to 7 lamps) • Design by Minelli - Fossati G For outline drawing see page 10 Lamp Data Type of lamp LED, viewing angle 120°, Light colour: daylight white, colour temperature: 5000 K Luminous flux lm Life time 600 h Light ON time after last detection 1200 60000 min 3 Electrical Data Operating voltage V AC (50/60 Hz)/DC Operating range 12…48 - 110…240 V AC/DC 9.6…52.8 - 88…264 Nominal current @230 V AC mA 39 54 Nominal current @24 V DC mA 200 300 Rated power of the lamp @230 V AC W 6 9 Rated power of the lamp @24 V DC W 6 9 X-2020, www.findernet.com General data Connection cable to the lamp Sheathed cable 2 x 1.5 mm², flexible with push-in or socket Interconnectors from lamp to lamp Sheathed cable 2 x 1.5 mm², flexible with plug and socket Socket and plug 2-pole with interlock Type of mounting Magnetic or clip fixing Housing Ambient temperature Protection class Protection category Plastic, transparent °C −30…+55 II IP 20 Approvals (according to type) 5 7L SERIES 7L SERIES LED panel light Ordering information Example: Series 7L, LED light with magnetic fixing, ON/OFF switch, supply voltage 12…48V AC/DC and push-in terminals. 7 L . 4 3 . 0 . 0 2 4 . 1 Series Type 43 = LED lamp 600 lumens 46 = LED lamp 1200 lumens Supply version 0 = AC (50/60 Hz)/DC Supply voltage 024 = (12…48)V AC/DC 230 = (110…240)V AC/DC 1 0 0 Connections 1 = Push-in terminals for the connection to a single unit 2 = Plug-in terminals for the connection to a single or multiple units Switching 0 = Without ON/OFF switch or movement detector 1 = Switching via ON/OFF switch 2 = Switching via movement detector All types 7L.43.0.024.0100 7L.43.0.024.0200 7L.43.0.024.1100 7L.43.0.024.1200 7L.43.0.024.2100 7L.43.0.024.2200 7L.43.0.230.0100 7L.43.0.230.0200 7L.43.0.230.1100 7L.43.0.230.1200 7L.43.0.230.2100 7L.43.0.230.2200 7L.46.0.024.1100 7L.46.0.024.1200 7L.46.0.024.2100 7L.46.0.024.2200 7L.46.0.230.1100 7L.46.0.230.1200 7L.46.0.230.2100 7L.46.0.230.2200 X-2020, www.findernet.com G 6 7L 7L SERIES LED panel light SERIES Accessories 0 7 L . 1 1 Type 07L.11 (included in the box) Sockets and plugs, coded, for connection to a 2-pole cable (2 x 1.5 mm2), e.g. H05VV-F, 2 x 1.5 mm2 11 = Socket, loose for input side 12 = Plug, loose for output side 07L.12 (not included) Outline drawings Type 07L.11 Type 07L.12 Connections G Quick and simple wiring system via push-in terminals for the connection to a single unit, or via plug-in terminals for the connection to a single or multiple units. X-2020, www.findernet.com Multiple connection (up to 7 lamps) 7 7L SERIES 7L SERIES LED panel light Outline drawings Types 7L.4x.0.xxx.0100/0200 X-2020, www.findernet.com G 8 7L SERIES LED panel light 7L SERIES Outline drawings Types 7L.4x.0.xxx.1100 / 1200 X-2020, www.findernet.com G 9 7L SERIES 7L SERIES LED panel light Outline drawings Types 7L.4x.0.xxx.2100 / 2200 X-2020, www.findernet.com G 10 Please see general technical information
7L.43.0.230.1200 价格&库存
很抱歉,暂时无法提供与“7L.43.0.230.1200”相匹配的价格&库存,您可以联系我们找货
