7S.23.9.012.0210
7S.23.9.012.0210
    FINDER
    SFTY RLY GUIDE 2NO+1NC 10A 12VDC
7S.23.9.012.0210 数据手册
7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES 7S.12....5110 Relay module with forcibly guided contacts 7S.14....0220/0310 7S.16....0420 7S.12 with 2 pole (1NO + 1 NC) 7S.14 with 4 pole (2 NO + 2 NC and 3 NO + 1 NC) 7S.16 with 6 pole (4 NO + 2 NC) • For safety applications, with class A forcibly guided contact relays (EN 50205) according to IEC 61508 • For functional reliability in machinery and plant engineering according to EN 13849-1 • For railway applications; materials compliant with fire and smoke characteristics (UNI 11170-3); mechanical and climatic characteristics compliant with EN 61373 and EN 50155 • DC and AC supply versions • 24 and 110 V DC versions with extended operating range (0.7…1.25)UN • Coil status visual indication with LED • 35 mm rail (EN 60715) mount • For applications up to SIL 2 • 2 pole (1 NO + 1 NC) • 4 pole (2 NO + 2 NC and • 6 pole (4 NO + 2 NC) 3 NO + 1 NC) C Screwless terminal * Single contact current ≤ 6 A, total NO contacts current ≤ 12 A For outline drawing see page 8 Contact specification Contact configuration Rated current/Max. peak current Rated switching voltage A 1 NO + 1 NC 2 NO + 2 NC, 3 NO + 1 NC 4 NO + 2 NC 6/15 6*/12 6*/12 V AC (50/60 Hz) 250 250 250 Rated load AC1 VA 1500 1500 1500 Rated load AC15 (230 V AC) VA 700 500 500 A 6/0.6/0.2 6/0.6/0.3 6/0.6/0.3 Breaking capacity DC1: 30/110/220 V Breaking capacity DC13: 24 V Minimum switching load A 1 1 1 60 (5/5) 60 (5/5) 60 (5/5) AgNi + Au AgNi with notched crown AgNi with notched crown 110…125 - 230…240 110…125 - 230…240 110…125 - 230…240 12 - 24 12 - 24 - 110 12 - 24 - 110 2.3/1 2.3/1 2.3/1 AC (0.85…1.1)UN (0.85…1.1)UN (0.85…1.1)UN DC (0.8…1.2)UN (0.8…1.2)UN (0.8…1.2)UN mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power Operating range VA (50 Hz)/W (0.7…1.25)UN (0.7…1.25)UN (0.7…1.25)UN Holding voltage DC extended range (24 and 110 V only) AC/DC 0.45 UN / 0.45 UN 0.55 UN / 0.55 UN 0.55 UN / 0.55 UN Must drop-out voltage AC/DC 0.1 UN / 0.1 UN 0.1 UN / 0.1 UN 0.1 UN / 0.1 UN Mechanical life cycles 10 · 106 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 100 · 103 Technical data XI-2017, www.findernet.com Operate/release time 7/11 12/10 12/10 Insulation between coil and contacts (1.2/50 µs) kV 6 6 (4 against 13-14) 6 (4 against 13-14) Dielectric strength between open contacts V AC 1500 1500 1500 –40….+70 –40….+70 –40….+70 IP 20 IP 20 IP 20 Ambient temperature Protection category ms °C Approvals (according to type) 1 7S SERIES 7S SERIES Relay module with forcibly guided contacts 6 A Relay module with forcibly guided contacts 7S.23 7S.23 with 3 pole (2NO + 1 NC) • For safety applications, with class A forcibly guided contact relays (EN 50205) • For functional reliability in machinery and plant engineering according to EN 13849-1 • DC coil • Damium free contacts • 17.5 mm wide • Coil status visual indication with LED • 35 mm rail (EN 60715) mount • 3 pole (2 NO + 1 NC) Screw terminal For outline drawing see page 7 Contact specification Contact configuration 2 NO + 1 NC Rated current/Max. peak current Rated switching voltage A 10/20 V AC (50/60 Hz) 250 Rated load AC1 VA 2500 Rated load AC15 (230 V AC) VA 500 Breaking capacity DC1: 30/110/220 V A 6/0.6/0.2 Breaking capacity DC13: 24 V A 1 Minimum switching load mW (V/mA) Standard contact material 60 (5/5) AgNi + Au Coil specification Nominal voltage (UN) Rated power V DC VA (50 Hz)/W 12 - 24 - 48 -110 2.3/1 Operating range DC (0.8…1.2)UN Holding voltage DC 0.45 UN Must drop-out voltage DC 0.1 UN Mechanical life cycles 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 Technical data Operate/release time ms 7/11 Insulation between coil and contacts (1.2/50 µs) kV 6 Dielectric strength between open contacts V AC 1500 Ambient temperature Protection category Approvals (according to type) 2 °C –40….+70 IP 20 XI-2017, www.findernet.com C 7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES Ordering information Example: 7S series Relay module with forcibly guided contacts, 6 contact (4 NO + 2 NC) 6 A, supply voltage 24 V DC. 7 S . 1 Series Type 1 = 22.5 mm wide, screwless terminals 2 = 17.5 mm wide, screw terminals Output 2 = 2 contacts 3 = 3 contacts 4 = 4 contacts 6 = 6 contacts Supply version 8 = AC (50 /60 Hz) 9 = DC 4 2 0 Special versions 0 = Standard NO and NC contatcs 11 = 1 NO + 1 NC 21 = 2 NO + 1 NC 22 = 2 NO + 2 NC 31 = 3 NO + 1 NC 42 = 4 NO + 2 NC C Contact material 0 = AgNi 0 = AgNi+Au (7S.23) 5 = AgNi + Au Codes, Preferred selections for best availability are shown in bold. 7S.12.9.012.5110 7S.14.9.012.0220 7S.16.9.012.0420 7S.12.9.024.5110 7S.14.9.012.0310 7S.16.9.024.0420 7S.12.8.120.5110 7S.14.9.024.0220 7S.16.9.110.0420 7S.12.8.230.5110 7S.14.9.024.0310 7S.16.8.120.0420 7S.14.9.110.0220 7S.16.8.230.0420 7S.14.9.110.0310 7S.23.9.012.0210 7S.14.8.120.0220 7S.23.9.024.0210 7S.14.8.120.0310 7S.23.9.048.0210 7S.14.8.230.0220 7S.23.9.110.0210 7S.14.8.230.0310 XI-2017, www.findernet.com Supply voltage See page 6 6 . 9 . 0 2 4 . 0 3 7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 2 Insulation between coil and contact set Type of Insulation Reinforced* Overvoltage category Rated impulse voltage Reinforced* III III II kV (1.2/50 µs) 6 4 4 2500 2500 Dielectric strength V AC 4000 Insulation between adjacent contacts Type of Insulation Reinforced* Basic* Reinforced* Overvoltage category III III II kV (1.2/50 µs) 6 4 4 2500 2500 Rated impulse voltage Dielectric strength V AC 4000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1500/2.5 * Tables below indicate, for each 7S type, those contacts (R) meeting Reinforced Insulation Overvoltage category III, those contacts (R2) meeting Reinforced Insulation Overvoltage category II, and those contacts (B) meeting Basic Insulation Overvoltage category III. EMC specifications Reference standard Burst (5/50 ns) on supply terminals EN 61000-4-4 Surge (1.2/50 µs) on supply terminals differential mode EN 61000-4-5 1.5 kV solid cable stranded cable Terminals Max. wire size Wire strip length 4 kV mm2 1 x 1.5 1 x 1.5 AWG 1 x 14 1 x 16 mm 9 Other data 7S.12 Bounce time: NO/NC 7S.14 7S.16 1/20 1/20 g 10/5 15/4 15/4 ms 2/8 Vibration resistance (10…200)Hz: NO/NC Shock resistance: NO/NC Power lost to the environment g 20/6 25/13 25/13 without contact current W 0.8 0.8 0.8 with rated current W 1.4 2.3 2.8 Type of insulation between coil and contacts and between adjacent contacts Code Type of Insulation 7S.12....5110 Overvoltage category R Reinforced III Coil B Basic III 13-14 R2 Reinforced II 21-22 7S.14....0310 Coil 13-14 21-22 — R R Coil — B/R2 13-14 — 21-22 Coil 13-14 21-22 33-34 — B R R R — B R R — R R — B/R2 33-34 43-44 — 7S.16....0420 Coil Coil 13-14 21-22 31-32 43-44 53-54 63-64 4 — 13-14 21-22 31-32 7S.14....0220 43-44 53-54 63-64 Coil B R R R R R Coil — B R R R R 11-12 R R R R 21-22 — B/R2 R R 33-34 — B/R2 R 43-44 — B/R2 — 43-44 — — 11-12 21-22 33-34 43-44 R R R R — R R R — R R — B/R2 — XI-2017, www.findernet.com C Basic* 7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES Contact specifications Contact diagrams 7S.12 7S.14....0220 7S.14....0310 7S.16 7S.23 C Resistive load - cosϕ = 1 Inductive load - AC15 H 7S12 - Maximum DC breaking capacity - 7S.12 DC.breaking current (A) Cycles F 7S12 - Electrical life (AC) v contact current - 7S.12 Resistive load Inductive load - DC13 DC voltage (V) • When switching a load having voltage and current values under the Resistive load - cosϕ = 1 Inductive load - AC15 curve, an electrical life of ≥ 100 · 103 can be expected. H 7S16 - Maximum DC breaking capacity - 7S.14 / 7S.16 DC breaking current (A) Cycles F 7S16 - Electrical life (AC) v contact current - 7S.14 / 7S.16 Resistive load Inductive load - DC13 DC voltage (V) • When switching a load having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. XI-2017, www.findernet.com Resistive load - cosϕ = 1 Inductive load - AC15 H 7S23 - Maximum DC breaking capacity - 7S.23 DC breaking current (A) Cycles F 7S23 - Electrical life (AC) v contact current - 7S.23 Resistive load Inductive load - DC13 DC voltage (V) • When switching a load having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. 5 7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES Coil specifications DC coil data - type 7S.12 Nominal Coil Operating range voltage code Rated power at UN Umax V 14.4 30 Rated input current at UN IN mA 55 38.2 DC coil data - type 7S.14 / 7S.16 Operating range Nominal Coil voltage code Rated input current Rated power at UN UN V 12 24 UN V 12 24 110 9.012 9.024 9.110 Umin V 9.6 16.8 77 Umax V 14.4 30 138 at UN IN mA 56 28 9.2 W 0.7 0.9 W 0.7 0.7 0.7 UN V 110…125 230…240 8.120 8.230 Umin V 93 195 Umax V 138 264 AC coil data - type 7S.14 / 7S.16 Nominal Coil Operating range voltage code UN V 110…125 230…240 8.120 8.230 Umin V 93 195 Umax V 138 264 Rated input current at UN IN mA 9.5 9 Rated power at UN Rated input current at UN IN mA 8.9 8.5 Rated power at UN VA/W 1.1/1 2/0.8 VA/W 1.1/0.9 2/0.8 DC coil data - type 7S.23 Nominal voltage Coil code Umin UN V Umax Rated input current at UN IN Operating range Rated power at UN V V mA W 12 9.012 9.6 14.4 50 0.6 24 9.024 16.8 30 25 0.6 48 9.048 33.6 60 12.5 0.6 110 9.110 77 138 5.4 0.6 R 7S - DC coil operating range v ambient temperature 7S.12 / 7S.23 / 7S.14 / 7S.16 R 7S - AC coil operating range v ambient temperature 7S.12 / 7S.14 / 7S.16 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. - - - - - 24 and 110 V DC coils only (extended range) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. XI-2017, www.findernet.com C 9.012 9.024 Umin V 9.6 16.8 AC coil data - type 7S.12 Nominal Coil Operating range voltage code 6 7S SERIES Relay module with forcibly guided contacts 6 A 7S SERIES Wiring diagrams Type 7S.12 Type 7S.14....0220 Safety PLC feedback output Safety PLC feedback output C XI-2017, www.findernet.com feedback 7 7S SERIES 7S SERIES Relay module with forcibly guided contacts 6 A Outline drawings 7S Screwless terminal C 7S.23 Screw terminal Accessories Sheet of marker tags, plastic, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers 060.48 XI-2017, www.findernet.com 060.48 8
7S.23.9.012.0210 价格&库存
很抱歉,暂时无法提供与“7S.23.9.012.0210”相匹配的价格&库存,您可以联系我们找货
