30.22.9.024.0010
30.22.9.024.0010
    FINDER
30.22.9.024.0010 数据手册
30 A SЕRIES Subminiature DIL relays 2 A Electronic circuit boards Hi-Fi systems Printers Toys Medical and dentistry Hoists and cranes Door and gate openers FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 30 SERIES Subminiature DIL relays 2 A 30 SERIES 30.22 Printed circuit mount 2 A signal relay • 2 Pole changeover contacts Low level switching A capability • Subminiature - industry standard DIL package • Sensitive DC coil - 200 mW • Wash tight: RT III • Cadmium Free contact material • Low coil power • Au clad contacts • PCB mount Copper side view Contact specification Contact configuration 2 CO (DPDT) Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 2/3 125/250 Rated load AC1 VA 125 Rated load AC15 (230 V AC) VA 25 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material — 2/0.3/— 10 (0.1/1) AgNi + Au Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W — 5 - 6 - 9 - 12 - 24 - 48 —/0.2 Operating range AC — DC See table page 5 Holding voltage AC/DC —/0.35 UN Must drop-out voltage AC/DC —/0.05 UN Mechanical life AC/DC cycles —/10 · 106 Electrical life at rated load AC1 cycles 100 · 103 Technical data X-2017, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection ms 6/2 kV 1.5 V AC 750 °C –40…+85 RT III Approvals (according to type) 3 30 SERIES Subminiature DIL relays 2 A 30 SERIES Ordering information Example: 30 series PCB relay, 2 CO (DPDT) - 2 A contacts, 12 V sensitive DC coil. A A 3 0 . 2 B C D 2 . 7 . 0 1 2 . 0 . 0 . 1 . 0 Series A: Contact material 0 = Standard AgNi + Au Type 2 = PCB mount B: Contact circuit 0 = CO (DPDT) No. of poles 2 = 2 pole, 2 A D: Special versions 0 = Wash tight (RT III) C: Options 1 = None Coil version 7 = Sensitive DC Coil voltage See coil specifications Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 120…240 single phase Rated insulation voltage V AC 250 125 Pollution degrees 1 2 Basic Basic I II Insulation between coil and contact set Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) 1.5 Dielectric strength 1.5 V AC 1000 1000 Basic Basic I II Insulation between adjacent contacts Type of insulation Overvoltage category Rated impulse voltage kV (1.2/50 µs) 1.5 Dielectric strength V AC 1500 1.5 1500 Insulation between open contacts Type of disconnection Dielectric strength Micro-disconnection V AC/kV (1.2/50 µs) 750/1 Micro-disconnection 750/1 Other data Bounce time: NO/NC ms 1/3 Vibration resistance (5…55)Hz: NO/NC g 15/15 Shock resistance Power lost to the environment g 16 without contact current  W 0.2 with rated current W 0.4 mm ≥ 5 X-2017, www.findernet.com Recommended distance between relays mounted on PCB  4 30 SERIES Subminiature DIL relays 2 A 30 SERIES Contact specification F 30 - Electrical life (AC1) v contact current (125 V) Cycles A Note: The rated current of 2 A corresponds to the limiting continuous current. Coil specifications DC coil data - 0.2 W sensitive Nominal voltage Coil code R 30 - DC coil operating range v ambient temperature Operating range Resistance Rated coil consumption UN Umin Umax R I at UN V V V Ω mA 5 7.005 3.7 7.5 125 40 6 7.006 4.5 9 180 33 9 7.009 6.7 13.5 405 22 12 7.012 8.4 18 720 16 24 7.024 16.8 36 2880 8.3 48* 7.048 36 72 10000 4.8 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. X-2017, www.findernet.com * Rated power: 0.23 W Please see general technical information 5
30.22.9.024.0010 价格&库存
很抱歉,暂时无法提供与“30.22.9.024.0010”相匹配的价格&库存,您可以联系我们找货
