4C SERIES
Relay interface modules 8 to 16 A
4C
SERIES
4C.P1
1 & 2 CO relay interface modules,
15.8 mm wide with Push-in terminal
4C.P2
Ideal interface for PLC and electronic systems
Type 4C.P1
-- 1 CO 10 A
Type 4C.P2
-- 2 CO 8 A
• AC coils or DC coils
• Supply status indication and coil suppression
B
module as standard
• Identification label
• UL Listing (certain relay/socket combinations)
• 35 mm rail (EN 60715) mounting
• 1 CO 10 A
• Push-in terminals
• 2 CO 8 A
• Push-in terminals
4C.P1 / 4C.P2
Push-in terminals
For outline drawing see page 5
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
1 CO (SPDT)
2 CO (DPDT)
10/25
8/15
250/440
250/440
Rated load AC1
VA
4000
2000
Rated load AC15 (230 V AC)
VA
750
350
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220 V
A
Minimum switching load
mW (V/mA)
Standard contact material
0.55
0.37
10/0.5/0.15
6/0.5/0.15
300 (5/5)
300 (5/5)
AgNi
AgNi
12 - 24 - 110 - 120 - 230
12 - 24 - 125
12 - 24 - 125
1.2/0.5
1.2/0.5
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
AC
(0.8…1.1)UN
(0.8…1.1)UN
DC
(0.73…1.1)UN
(0.73…1.1)UN
Holding voltage
AC/DC
0.8 UN / 0.4 UN
0.8 UN / 0.4 UN
Must drop-out voltage
AC/DC
0.2 UN / 0.1 UN
0.2 UN / 0.1 UN
Mechanical life AC/DC
cycles
10 · 106
10 · 106
Electrical life at rated load AC1
cycles
100 · 103
100 · 103
ms
15/5 (AC) - 15/12 (DC)
10/3 (AC) - 10/10 (DC)
kV
6 (8 mm)
6 (8 mm)
1000
1000
–40…+70
–40…+70
IP 20
IP 20
Operating range
Technical data
V-2016, www.findernet.com
Operate/release time
Insulation between coil
and contacts (1.2/50 μs)
Dielectric strength
between open contacts
Ambient temperature range
Protection category
V AC
°C
Approvals - relay (according to type)
1
4C
SERIES
4C SERIES
4C.01
15.8 mm wide with screw terminal
4C.02
Type 4C.01
-- 1 CO 16 A
Type 4C.02
-- 2 CO 8 A
module as standard
• 1 CO 16 A
• Screw terminals
• 2 CO 8 A
• Screw terminals
4C.01 / 4C.02
Screw terminals
Rated voltage/
A
V AC
1 CO (SPDT)
2 CO (DPDT)
16/25
8/15
250/440
250/440
Rated load AC1
VA
4000
2000
VA
750
350
kW
A
mW (V/mA)
0.55
0.37
16/0.5/0.15
6/0.5/0.15
300 (5/5)
300 (5/5)
AgNi
AgNi
12 - 24 - 125
12 - 24 - 125
1.2/0.5
1.2/0.5
Coil specification
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
AC
(0.8…1.1)UN
(0.8…1.1)UN
DC
(0.73…1.1)UN
(0.73…1.1)UN
Holding voltage
AC/DC
0.8 UN / 0.4 UN
0.8 UN / 0.4 UN
AC/DC
0.2 UN / 0.1 UN
0.2 UN / 0.1 UN
cycles
10 · 106
10 · 106
cycles
100 · 103
100 · 103
ms
kV
6 (8 mm)
6 (8 mm)
1000
1000
Operating range
Technical data
Dielectric strength
Protection category
2
V AC
°C ≤ 12 A: –40…+70/>12 A: –40…+50
IP 20
–40…+70
IP 20
B
4C SERIES
4C
SERIES
Ordering information
Example: 4C series, 35 mm rail (EN 60715) mount, Push-in terminal relay interface module, 1 CO 10 A contacts, 24 V DC coil, green LED + diode.
4 C . P
A
B
C
D
1 . 9 . 0 2 4 . 0
Series
Type
0 = 35 mm rail (EN 60715) mount
screw terminal socket
P = 35 mm rail (EN 60715) mount
Push-in terminal socket
A: Contact material
0 = AgNi
4 = AgSnO2
5 = AgNi + Au
B
D: Special versions
0 = Standard
C: Options
5 = Standard for DC:
green LED + diode (polarity +A1)
6 = Standard for AC:
green LED + Varistor
B: Contact circuit
0 = CO (nPDT)
No. of poles
1 = 1 pole
2 = 2 pole
Coil version
8 = AC (50/60 Hz)
9 = DC
Coil voltage
See coil specifications
Selecting features and options: only combinations in the same row are possible.
Preferred selections for best availability are shown in bold.
Type
Coil version A
B
C
D
4C.02
AC
4C.P2
DC
0-5
4C.01
AC
0-4-5
4C.P1
DC
0-4-5
Technical data
Insulation
Insulation according to EN 61810-1
insulation rated voltage
rated impulse withstand voltage
V 250
440
kV 4
4
pollution degree
3
2
overvoltage category
III
III
Insulation between coil and contacts (1.2/50 μs)
kV 6 (8 mm)
Dielectric strength between open contacts
V AC 1000
Dielectric strength between adjacent contacts
V AC 2000
Conducted disturbance immunity
Burst (5…50)ns, 5 kHz, on A1 - A2
EN 61000-4-4
level 4 (4 kV)
Surge (1.2/50 μs) on A1 - A2 (differential mode)
EN 61000-4-5
level 3 (2 kV)
Other data
Bounce time: NO/NC
ms 2/6 (4C.01/P1)
Vibration resistance (10…150)Hz: NO/NC
Power lost to the environment
without contact current
W 0.6
with rated current
W 1.6 (4C.01/P1)
Terminals
Wire strip length
Screw torque
4C.01/4C.02
mm 8
Nm 0.8
Max. wire size
1/4 (4C.02/P2)
g 20/12
solid cable
mm
2
2 (4C.02/P2)
4C.P1/4C.P2
8
stranded cable solid cable
stranded cable
1 x 6 / 2 x 2.5 1 x 4 / 2 x 2.5 2 x (0.5…1.5) 2 x (0.5…1.5)
AWG 1 x 10 / 2 x 14 1 x 12 / 2 x 14 2 x (21…18)
2 x (21…18)
3
4C SERIES
4C
SERIES
F 4C - Electrical life (AC) v contact current
Types 4C.02/P2
Resistive load - cosφ = 1
Inductive load - cosφ = 0.4
Cycles
Cycles
B
Types 4C.01/P1
limit for 4C.P1
H 4C - Maximum DC1 breaking capacity
Current limit 1 CO (SPDT) (*)
DC breaking current (A)
Current limit 2 CO (DPDT)
(*) Type 4C.01 = 12 A, Type 4C.P1 = 10 A
• When switching a resistive load (DC1) having voltage and current
values under the curve, an electrical life of ≥ 100 · 103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with the
load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
DC voltage (V)
Coil specifications
DC coil data
AC coil data
Coil code
Operating range
Resistance
Rated coil
consumption
Nominal
voltage
Coil code
Operating range
Rated coil
consumption
UN
Umin
Umax
R
I at UN
UN
Umin
Umax
R
I at UN
V
V
V
Ω
mA
V
V
V
Ω
mA
12
9.012
8.8
13.2
300
40
12
8.012
9.6
13.2
80
90
24
9.024
17.5
26.4
1200
8.024
19.2
26.4
320
45
125
9.125
91.2
110
8.110
88
121
6900
9.4
120
8.120
96
132
9000
8.4
230
8.230
184
253
28000
138
32000
3.9
R 4C - DC coil operating range v ambient temperature
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
5
R 4C - AC coil operating range v ambient temperature
Single Pole Relay
Contact Current
limited to 12 A
Single Pole Relay
Contact Current
limited to 12 A
------ Temperature limit for the single pole version under full 16 A contact current.
4
Resistance
Nominal
voltage
4C SERIES
Combinations
Certain relay/socket
combinations
Code
4C
SERIES
Type of socket
Type of relay
Module
Retaining clip
4C.P1
97.P1
46.61
99.02
097.01
4C.P2
97.P2
46.52
99.02
097.01
4C.01
97.01
46.61
99.02
097.01
4C.02
97.02
46.52
99.02
097.01
B
Outline drawing
4C.01 / 4C.02
Screw terminals
4C.P1 /
Push-in terminals
4C.P2
Accessories
8-way jumper link for type 4C.P1 and 4C.P2
097.58
Rated values
10 A - 250 V
2-way jumper link for type 4C.P1 and 4C.P2
097.52
Rated values
10 A - 250 V
097.42
Rated values
10 A - 250 V
097.58
097.52
097.42
5
4C SERIES
4C
SERIES
Accessories
Marker tag holder for type 4C.P1/P2/01/02
097.00
8-way jumper link for 4C.01 and 4C.02
095.18 (blue)
Rated values
10 A - 250 V
Sheet of marker tags (CEMBRE'S Thermal transfer printers),
plastic, 48 tags, 6 x 12 mm
060.48
097.00
PEAN
EUR
095.18
N
T E
O
P A
PEAN
T
EUR
B
O
060.48
Sheet of marker tags (plotter printing), plastic, 72 tags, 6 x 12 mm
060.72
060.72
Packaging codes
How to code and identify retaining clip and packaging options for relay interface module.
Example:
4 C . P
1 . 9 . 0 2 4 . 0
S P
A
A Standard packaging
B Blister packaging
SP Plastic retaining clip
6
4C.01.9.024.0050SPA 价格&库存
很抱歉,暂时无法提供与“4C.01.9.024.0050SPA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+219.833101+28.45511
- 10+195.7803010+25.34172
- 30+185.2448530+23.97802
- 50+180.5360150+23.36851
- 100+174.33408100+22.56573
- 250+166.45331250+21.54565
- 500+160.72633500+20.80435
