4C.02.9.024.0050
4C.02.9.024.0050
    FINDER
    Module
4C.02.9.024.0050 数据手册
4C SERIES Relay interface modules 8 to 16 A 4C SERIES 4C.P1 1 & 2 CO relay interface modules, 15.8 mm wide with Push-in terminal 4C.P2 Ideal interface for PLC and electronic systems Type 4C.P1 -- 1 CO 10 A Type 4C.P2 -- 2 CO 8 A • AC coils or DC coils • Supply status indication and coil suppression B module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • 1 CO 10 A • Push-in terminals • 2 CO 8 A • Push-in terminals 4C.P1 / 4C.P2 Push-in terminals For outline drawing see page 5 Contact specification Contact configuration Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  A V AC 1 CO (SPDT) 2 CO (DPDT) 10/25 8/15 250/440 250/440 Rated load AC1  VA 4000 2000 Rated load AC15 (230 V AC)  VA 750 350 Single phase motor rating (230 V AC)  kW Breaking capacity DC1: 30/110/220 V  A Minimum switching load  mW (V/mA) Standard contact material 0.55 0.37 10/0.5/0.15 6/0.5/0.15 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 1.2/0.5 1.2/0.5 Coil specification Nominal voltage (UN)  V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W AC (0.8…1.1)UN (0.8…1.1)UN DC (0.73…1.1)UN (0.73…1.1)UN Holding voltage  AC/DC 0.8 UN / 0.4 UN 0.8 UN / 0.4 UN Must drop-out voltage  AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life AC/DC  cycles 10 · 106 10 · 106 Electrical life at rated load AC1  cycles 100 · 103 100 · 103 ms 15/5 (AC) - 15/12 (DC) 10/3 (AC) - 10/10 (DC) kV 6 (8 mm) 6 (8 mm) 1000 1000 –40…+70 –40…+70 IP 20 IP 20 Operating range Technical data V-2016, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 μs)  Dielectric strength between open contacts  Ambient temperature range  Protection category V AC °C Approvals - relay (according to type) 1 4C SERIES 4C SERIES Relay interface modules 8 to 16 A 4C.01 1 & 2 CO relay interface modules, 15.8 mm wide with screw terminal 4C.02 Ideal interface for PLC and electronic systems Type 4C.01 -- 1 CO 16 A Type 4C.02 -- 2 CO 8 A • AC coils or DC coils • Supply status indication and coil suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • 1 CO 16 A • Screw terminals • 2 CO 8 A • Screw terminals 4C.01 / 4C.02 Screw terminals For outline drawing see page 5 Contact specification Contact configuration Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  A V AC 1 CO (SPDT) 2 CO (DPDT) 16/25 8/15 250/440 250/440 Rated load AC1  VA 4000 2000 Rated load AC15 (230 V AC)  VA 750 350 Single phase motor rating (230 V AC)  kW Breaking capacity DC1: 30/110/220 V  A Minimum switching load  mW (V/mA) Standard contact material 0.55 0.37 16/0.5/0.15 6/0.5/0.15 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 1.2/0.5 1.2/0.5 Coil specification Nominal voltage (UN)  V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W AC (0.8…1.1)UN (0.8…1.1)UN DC (0.73…1.1)UN (0.73…1.1)UN Holding voltage  AC/DC 0.8 UN / 0.4 UN 0.8 UN / 0.4 UN Must drop-out voltage  AC/DC 0.2 UN / 0.1 UN 0.2 UN / 0.1 UN Mechanical life AC/DC  cycles 10 · 106 10 · 106 Electrical life at rated load AC1  cycles 100 · 103 100 · 103 ms 15/5 (AC) - 15/12 (DC) 10/3 (AC) - 10/10 (DC) kV 6 (8 mm) 6 (8 mm) 1000 1000 Operating range Technical data Operate/release time  Insulation between coil and contacts (1.2/50 μs)  Dielectric strength between open contacts  Ambient temperature range  Protection category Approvals - relay (according to type) 2 V AC °C ≤ 12 A: –40…+70/>12 A: –40…+50 IP 20 –40…+70 IP 20 V-2016, www.findernet.com B 4C SERIES Relay interface modules 8 to 16 A 4C SERIES Ordering information Example: 4C series, 35 mm rail (EN 60715) mount, Push-in terminal relay interface module, 1 CO 10 A contacts, 24 V DC coil, green LED + diode. 4 C . P A B C D 1 . 9 . 0 2 4 . 0 0 5 0 Series Type 0 = 35 mm rail (EN 60715) mount screw terminal socket P = 35 mm rail (EN 60715) mount Push-in terminal socket A: Contact material 0 = AgNi 4 = AgSnO2 5 = AgNi + Au B D: Special versions 0 = Standard C: Options 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC: green LED + Varistor B: Contact circuit 0 = CO (nPDT) No. of poles 1 = 1 pole 2 = 2 pole Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 4C.02 AC 4C.P2 DC 0-5 0 6 0 0-5 0 5 0 4C.01 AC 0-4-5 0 6 0 4C.P1 DC 0-4-5 0 5 0 Technical data Insulation Insulation according to EN 61810-1 insulation rated voltage  rated impulse withstand voltage  V 250 440 kV 4 4 pollution degree 3 2 overvoltage category III III Insulation between coil and contacts (1.2/50 μs)  kV 6 (8 mm) Dielectric strength between open contacts  V AC 1000 Dielectric strength between adjacent contacts  V AC 2000 Conducted disturbance immunity Burst (5…50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC  ms 2/6 (4C.01/P1) Vibration resistance (10…150)Hz: NO/NC  Power lost to the environment without contact current  W 0.6 with rated current  W 1.6 (4C.01/P1) Terminals Wire strip length  Screw torque  4C.01/4C.02 mm 8 Nm 0.8 Max. wire size V-2016, www.findernet.com 1/4 (4C.02/P2) g 20/12 solid cable mm 2 2 (4C.02/P2) 4C.P1/4C.P2 8 — stranded cable solid cable stranded cable 1 x 6 / 2 x 2.5 1 x 4 / 2 x 2.5 2 x (0.5…1.5) 2 x (0.5…1.5) AWG 1 x 10 / 2 x 14 1 x 12 / 2 x 14 2 x (21…18) 2 x (21…18) 3 4C SERIES Relay interface modules 8 to 16 A 4C SERIES Contact specification F 4C - Electrical life (AC) v contact current Types 4C.02/P2 Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 Cycles B F 4C - Electrical life (AC) v contact current Types 4C.01/P1 limit for 4C.P1 H 4C - Maximum DC1 breaking capacity Current limit 1 CO (SPDT) (*) DC breaking current (A) Current limit 2 CO (DPDT) (*) Type 4C.01 = 12 A, Type 4C.P1 = 10 A • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. DC voltage (V) Coil specifications DC coil data AC coil data Coil code Operating range Resistance Rated coil consumption Nominal voltage Coil code Operating range Rated coil consumption UN Umin Umax R I at UN UN Umin Umax R I at UN V V V Ω mA V V V Ω mA 12 9.012 8.8 13.2 300 40 12 8.012 9.6 13.2 80 90 24 9.024 17.5 26.4 1200 20 24 8.024 19.2 26.4 320 45 125 9.125 91.2 110 8.110 88 121 6900 9.4 120 8.120 96 132 9000 8.4 230 8.230 184 253 28000 138 32000 3.9 R 4C - DC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 5 R 4C - AC coil operating range v ambient temperature Single Pole Relay Contact Current limited to 12 A Single Pole Relay Contact Current limited to 12 A 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. ------ Temperature limit for the single pole version under full 16 A contact current. 4 Resistance V-2016, www.findernet.com Nominal voltage 4C SERIES Relay interface modules 8 to 16 A Combinations Certain relay/socket combinations Code 4C SERIES Type of socket Type of relay Module Retaining clip 4C.P1 97.P1 46.61 99.02 097.01 4C.P2 97.P2 46.52 99.02 097.01 4C.01 97.01 46.61 99.02 097.01 4C.02 97.02 46.52 99.02 097.01 B Outline drawing 4C.01 / 4C.02 Screw terminals 4C.P1 / Push-in terminals 4C.P2 Accessories 8-way jumper link for type 4C.P1 and 4C.P2 097.58 Rated values 10 A - 250 V 2-way jumper link for type 4C.P1 and 4C.P2 097.52 Rated values 10 A - 250 V 2-way jumper link for type 4C.P1 and 4C.P2 097.42 Rated values 10 A - 250 V 097.58 V-2016, www.findernet.com 097.52 097.42 5 4C SERIES Relay interface modules 8 to 16 A 4C SERIES Accessories Marker tag holder for type 4C.P1/P2/01/02 097.00 8-way jumper link for 4C.01 and 4C.02 095.18 (blue) Rated values 10 A - 250 V Sheet of marker tags (CEMBRE'S Thermal transfer printers), plastic, 48 tags, 6 x 12 mm 060.48 097.00 PEAN EUR 095.18 N T E O P A PEAN T EUR B O 060.48 Sheet of marker tags (plotter printing), plastic, 72 tags, 6 x 12 mm 060.72 060.72 Packaging codes How to code and identify retaining clip and packaging options for relay interface module. Example: 4 C . P 1 . 9 . 0 2 4 . 0 0 5 0 S P A A Standard packaging B Blister packaging V-2016, www.findernet.com SP Plastic retaining clip 6
4C.02.9.024.0050 价格&库存
很抱歉,暂时无法提供与“4C.02.9.024.0050”相匹配的价格&库存,您可以联系我们找货
