Panel Heaters
25 - 50 - 100 - 150 250 - 400 W
Drying kilns
7H
SЕRIES
Hoists and cranes
Road / tunnel
lighting
Plastic
moulding
machines
Automatic
car-washes
Panels for
electrical
distribution
Control panels
Forced-air
ventilators
FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
7H
7H SERIES
Panel Heaters 25 - 50 - 100 - 150 W
SERIES
7H.51.0.230.0025
Panel heaters
7H.51.0.230.0050
Type 7H.51.0.230.0025
- Heating power 25 W
Type 7H.51.0.230.0050
- Heating power 50 W
• Nominal voltage (110...230)V AC/DC
• Safe touch
• PTC resistor, self regulating heating system
• Clip for 35 mm rail (EN 60715) mount
• Heating power 25 W
• Nominal voltage
7H.51.0025/0050
Screw terminal
(110…230)V AC/DC
• Safe touch
• Heating power 50 W
• Nominal voltage
(110…230)V AC/DC
• Safe touch
G
* At 20°C ambient temperature
** Except upper protection grille
For outline drawings see page 7
Heating specification
Heating power *
W
Heater
25
50
PTC resistor, self-regulating heating system
Surface temperature**
°C
Housing
≤ 100
≤ 100
Plastic according to UL94 – V0, black
Supply specification
Nominal voltage (UN)
V AC (50/60 Hz)/DC
Rated current
Operating range
A
V AC/DC
110…230
110…230
0.13
0.20
88…253
88…253
Technical data
IV-2020, www.findernet.com
Radiator
Alluminium profile
Electrical connection
Screw terminals
Fitting position
Ambient temperature
Protection category
Vertical
°C
–45…+50
–45…+50
IP 20
IP 20
Approvals (according to type)
3
7H
SERIES
7H SERIES
7H.51.0.230.0100
Panel heaters
7H.51.0.230.0150
Type 7H.51.0.230.0100
- Heating power 100 W
Type 7H.51.0.230.0150
- Heating power 150 W
• Safe touch
• PTC self regulating heating system
• Heating power 100 W
• Nominal voltage
7H.51.0100/0150
Screw terminal
(110…230)V AC/DC
• Safe touch
• Heating power 150 W
• Nominal voltage
(110…230)V AC/DC
• Safe touch
G
For outline drawings see page 8
Heating power *
W
Heater
100
150
°C
Housing
≤ 80
≤ 80
V AC (50/60 Hz)/DC
Rated current
Operating range
A
V AC/DC
110…230
110…230
0.45
0.70
88…253
88…253
Technical data
Alluminium profile
Screw terminals
Fitting position
Ambient temperature
Protection category
4
Vertical
°C
–45…+50
–45…+50
IP 20
IP 20
Radiator
7H
7H SERIES
Panel Heaters 250 - 400 W
SERIES
Panel heaters fan assisted
7H.51.8.230.0250
7H.51.8.230.0400
• Heating power 250 W
• Nominal voltage 230 V AC
• Fan assisted
• Heating power 400 W
• Fan assisted
Type 7H.51.8.230.0250
- Heating power 250 W
Type 7H.51.8.230.0400
- Heating power 400 W
• Safe touch
• Fast wiring terminals
7H.51.0250/0400
Push-in terminal
G
Heating power *
W
Heater
Air flow rate
Fan - Life time at 25 °C
250
400
°C
≤ 30
m3/h
h
Housing
≤ 30
30
50 000
50 000
Rated current
Operating range
V AC (50/60 Hz)
A
V AC
230
230
1
1.7
184...253
184...253
Technical data
Radiator
Alluminium profile
Screwless terminal
Fitting position
Ambient temperature
Protection category
Vertical
°C
-40…+50
-40…+50
IP 20
IP 20
5
7H
7H SERIES
Panel Heaters
SERIES
Ordering information
Example: 7H series, Panel heaters, heating power 50 W, 110…230 V AC/DC.
7 H . 5 1 . 0 . 2 3 0 . 0
Series
Type
51 = Panel heaters safe touch
Supply version
0 = AC (50/60 Hz)/DC
8 = AC (50/60 Hz) only fan assisted version
Supply voltage
230 = 110…230 V
230 = 230 V only fan assisted version
Heater power
0025 = 25 W
0050 = 50 W
0100 = 100 W
0150 = 150 W
0250 = 250 W
0400 = 400 W
General data
Terminals
stranded cable
2 x 1.5
2 x 1.5
mm2
AWG
2 x 16
2 x 16
Max. wire size (screw terminals)
mm2
1 x 2.5
1 x 1.5
AWG
1 x 12
Screw torqueNm
1 x 16
0.5
Wiring diagrams
Fan assisted version
NOTE: Separate supply (L) terminals for the heater
and the internal fan allow them to be powered
independently.
So,dependent on the specific situation, the installer
might wish the heating element to be controlled by
an upstream thermostat but require the fan to run
continuously (although the latter will significantly
reduce the product’s life).
7T.81.0.000.240x
1 = L (heater)
2=N
3 = L (fan)
F = aM 6.3 A
G
solid cable
Max. wire size (push-in terminals)
6
7H
7H SERIES
Panel Heaters
SERIES
Wiring diagrams
NOT Fan assisted versions
AC version
DC version
SAFETY NOTE
For reasons of safety and performance , heaters must be mounted in the following way:
1. keep a distance of 100 mm. from components above and below and of 60 mm from side components
2. install vertically (cables below heater) in the bottom part of cabinet
3. do not mount heaters over easily inflammable materials
4. do not operate in corrosive ambient air
WARNING
Do not cover the heater.
The 7H.51 Heater surface is very hot for 15-20 minutes after disconnecting.
During working and maintenance, don’t touch it.
Caution: risk of burns, temperatur of the side less than +100 °C..
G
Outline drawings
Type 7H.51.0050
Screw terminal
Type 7H.51.0025
Screw terminal
7
7H
SERIES
7H SERIES
Panel Heaters
Outline drawings
Type 7H.51.0100
Screw terminal
Type 7H.51.0150
Screw terminal
G
Types 7H.51.0250 / 0400
Push-in terminal
8
Please see general technical information
很抱歉,暂时无法提供与“7H.51.0.230.0100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+715.03488
- 5+686.18855
- 25+617.59261
- 国内价格
- 1+725.06642
- 5+657.71320
- 10+625.58587
