83.41.0.240.0000
83.41.0.240.0000
    FINDER
    关 - 延迟 延时继电器 SPDT(1 Form C) 0.05 秒 ~ 240 小时 延时 16A @ 250VAC DIN 轨道
83.41.0.240.0000 数据手册
83 SERIES 83 Series - Modular timers 12 - 16 A Features 83.01 83.02 Multi-function timer range 83.01 - Multi-function & multi-voltage, 1 Pole 83.02 - Multi-function & multi-voltage, 2 Pole (timed + instantaneous options), external time setting potentiometer option 22.5 mm wide Eight time scales from 0.05s to 10 days • High input/output isolation • Wide supply range (24...240)V AC/DC • 35 mm rail (EN 60715) mount • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the range and function selectors, the timing trimmer, and to disengage the rail mounting clip • Multi-voltage versions with “PWM clever” technology • • • Multi-voltage Multi-function • Timing can be regulated using ext. Potentiometer • 2 timed contacts or 1 timed + 1 instantaneous contact Multi-voltage Multi-function • • AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on WD: Watchdog (Retriggerable interval with control signal on) Wiring diagram (with control signal) Wiring diagram (without control signal) For outline drawing see page 5 AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on WD: Watchdog (Retriggerable interval with control signal on) Wiring diagram (with control signal) Wiring diagram (without control signal) Timers and Monitoring relays • Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC Rated load AC1 Rated load AC15 (230 V AC) Single phase motor rating (230 V AC) Breaking capacity DC1: 30/110/220 V Minimum switching load 1 CO (SPDT) 2 CO (DPDT) 16/30 12/30 250/400 250/400 VA 4,000 3,000 VA 750 750 kW 0.5 0.5 16/0.3/0.12 12/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 24…240 24...240 A mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) 24…240 24...240 Rated power AC/DC VA (50 Hz)/W < 1.5 / < 2
83.41.0.240.0000 价格&库存
很抱歉,暂时无法提供与“83.41.0.240.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+403.113531+52.21730
  • 5+388.719735+50.35280
  • 10+374.3259410+48.48830
库存:32
