85.03.0.125.0000
85.03.0.125.0000
    FINDER
    TIMER RLY 3PDT 10A 125V AC/DC
85.03.0.125.0000 数据手册
85 SERIES Miniature plug-in timers 7 - 10 A 85 SERIES 85.02 Plug-in timer 85.03 85.04 85.02 - 2 Pole 10 A 85.03 - 3 Pole 10 A 85.04 - 4 Pole 7 A • Multifunctions • Seven time scales, from 0.05 s to 100 h • 94 series sockets for 35 mm rail (EN 60715) mount with push-in and screw terminal • 2 pole, 10 A • AC/DC supply non polarized • Plug-in for use with 94 series sockets • 4 pole, 7 A • AC/DC supply non polarized • Plug-in for use with 94 series sockets AI: On-delay DI: Interval SW: Symmetrical flasher (starting pulse on) GI: Pulse delayed For UL ratings see: “General technical information” page V • 3 pole, 10 A • AC/DC supply non polarized • Plug-in for use with 94 series sockets AI: On-delay DI: Interval SW: Symmetrical flasher (starting pulse on) GI: Pulse delayed AI: On-delay DI: Interval SW: Symmetrical flasher (starting pulse on) GI: Pulse delayed Wiring diagram (without control signal) Wiring diagram (without control signal) Wiring diagram (without control signal) 2 CO (DPDT) 3 CO (3PDT) 4 CO (4PDT) 10/20 10/20 7/15 250/400 250/400 250/250 2500 2500 1750 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi 230…240 230…240 230…240 Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material H Supply specification Nominal voltage (UN) V AC (50/60 Hz)  Rated power AC/DC Operating range V AC/DC VA (50 Hz)/W 12 - 24 - 48 - 110…125 (non polarized) 2/2 2/2 2/2  AC (0.85…1.1)UN (0.85…1.1)UN (0.85…1.1)UN  DC (0.85…1.1)UN (0.85…1.1)UN (0.85…1.1)UN Technical data III-2016, www.findernet.com Specified time range (0.05…1)s, (0.5…10)s, (5…100)s, (0.5…10)min, (5…100)min, (0.5…10)h, (5…100)h Repeatability % ± 2 ± 2 ± 2 Recovery time ms ≤ 20 ≤ 20 ≤ 20 Minimum control impulse ms — — — Setting accuracy-full range % ± 5 ± 5 ± 5 200 · 103 200 · 103 150 · 103 –20…+60 –20…+60 –20…+60 IP 40 IP 40 IP 40 Electrical life at rated load in AC1 Ambient temperature range Protection category cycles °C Approvals (according to type) 1 85 SERIES 85 SERIES Miniature plug-in timers 7 - 10 A Ordering information Example: 85 series timer, 4 CO (4PDT), 24 V AC/DC supply voltage, AI, DI, GI, SW functions. 8 5 . 0 4 . 0 . 0 2 4 . 0 0 Series 0 0 Supply voltage 012 = 12 V AC/DC 024 = 24 V AC/DC 048 = 48 V AC/DC 125 = (110…125)V AC/DC 240 = (230…240)V AC Type 0 = Multifunction (AI, DI, GI, SW)* * AI = On-delay DI = Interval GI = Pulse delayed SW = Symmetrical flasher (starting pulse on) Supply version 0 = AC (50/60 Hz)/DC 8 = AC (50/60 Hz) for 240 V only No. of poles 2 = 2 pole - 10 A 3 = 3 pole - 10 A 4 = 4 pole - 7 A Technical data Insulation Dielectric strength 85.02, 85.03 2000 1000 2000 6 85.04 2000 1000 1550 4 Reference standard EN 61000-4-2 EN 61000-4-2 EN 61000-4-3 EN 61000-4-4 EN 61000-4-5 EN 61000-4-5 EN 61000-4-6 EN 61000-4-8 EN 55022 n.a. 8 kV 15 V/m 4 kV 4 kV 2 kV 10 V 30 A/m class B 1.6 3.7 (85.02) 4.7 (85.03) 3.6 (85.04) Times scales NOTE: time scales and functions must be set before energising the timer. III-2016, www.findernet.com H between input and output circuit V AC between open contacts V AC between adjacent contactsV AC Insulation (1.2/50 µs) between input and output kV EMC specifications Type of test Electrostatic discharge contact discharge air discharge Radio-frequency electromagnetic field (80 ÷ 1000 MHz) Fast transients (burst) (5-50 ns, 5 kHz) on Supply terminals Surges (1.2/50 µs) on common mode Supply terminals differential mode Radio-frequency common mode (0.15 ÷ 80 MHz) on Supply terminals Power-frequency (50 Hz) Radiated and conducted emission Other data Power lost to the environment without contact current W with rated current W 2 85 SERIES Miniature plug-in timers 7 - 10 A 85 SERIES Functions U = Supply voltage LED = Output contact Wiring diagram Contacts Supply voltage NO (SPDT-NO) output contact Open Closed OFF Open x1 - x4 x1 - x2 ON Open x1 - x4 x1 - x2 ON Open (Timing in Progress) x1 - x4 x1 - x2 ON Closed x1 - x2 x1 - x4 Type: 85.02, 85.03, 85.04 (AI) On-delay. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs when power is removed. 85.02 85.03 (DI) Interval. Apply power to timer. Output contacts transfer immediately. After the preset time has elapsed, contacts reset. (GI) Pulse delayed. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs after a fixed time of 0.5 s. H (SW) Symmetrical flasher (starting pulse on). Apply power to timer. Output contacts transfer immediately and cycle between ON and OFF for as long as power is applied. The ratio is 1:1 (time on = time off ). 85.04 U = Supply voltage S = Signal switch Uc = Supply voltage to the timer 11-14 = Self-holding contact Signal ON Pulse On mometary closure of Signal Switch (S) > 50 ms, the output contacts transfer and remain so (with selfholding on contact 11-14) for the duration of the preset delay, after which they reset. III-2016, www.findernet.com = Output contact 3 85 SERIES 94 SERIES Sockets and accessories for 85 series timers Push-in terminal socket panel or 35 mm (EN 60715) rail mount For timer type Accessories Metal retaining clip 6-way jumper link Identification tag 2-way jumper link 2-way jumper link Marker tag holder Sheet of marker tags for marker tag holder 097.00 , 48 tags, 6 x 12 mm for CEMBRE's thermal transfer printers Sheet of marker tags for marker tag holder 097.00, 72 tags, 6 x 12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Wire strip length mm Min. wire size for 94.P3 and 94.P4 sockets mm2 AWG Max. wire size for 94.P3 and 94.P4 sockets mm2 AWG 94.P4 Approvals (according to type): 060.72 060.48 94.P3 Blue 85.03 94.P4 Blue 85.02, 85.04 094.81 094.56 094.00.4 094.52 097.52 097.00 060.48 060.72 10 A - 250 V 2 kV AC IP 20 –40…+70 8 solid wire 0.5 21 solid wire 2 x 1.5 / 1 x 2.5 2 x 18 / 1 x 14 stranded wire 0.5 21 stranded wire 2 x 1.5 / 1 x 2.5 2 x 18 / 1 x 14 H R 94.P3 EAN OP EU N T T E P A 94.P4 094.56 (blue) 10 A - 250 V 2-way jumper link for 94.P3 and 94.P4 sockets Rated values 094.52 10 A - 250 V 2-way jumper link for 94.P3 and 94.P4 sockets Rated values 097.52 10 A - 250 V Marker tag holder for 94.P3 and 94.P4 sockets 097.00 EUR 6-way jumper link for 94.P3 and 94.P4 sockets Rated values OP EAN 094.56 094.52 097.00 4 III-2016, www.findernet.com 097.52 94 SERIES Sockets and accessories for 85 series timers Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For timer type Accessories Metal retaining clip 6-way jumper link Identification tag Marker tag holder Sheet of marker tags marker tag holder 097.00 , 48 tags, 6 x 12 mm for CEMBRE's thermal transfer printers Sheet of marker tags for marker tag holder 097.00, 72 tags, 6 x 12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature 94.04 Approvals (according to type): 060.72 Screw torque Wire strip length Max. wire size for 94.02/03/04 sockets R 060.48 OP 85 SERIES EAN EU N T T E P A 6-way jumper link for 94.02, 94.03 and 94.04 sockets Rated values 94.02 Blue 85.02 094.06 94.02.0 94.03 Black Blue 85.03 94.03.0 94.04 Black Blue 85.04 094.81 094.06.0 094.06 094.06.0 094.06 094.00.4 097.00 94.04.0 Black 094.06.0 060.48 060.72 10 A - 250 V 2 kV AC IP 20 °C –40…+70 Nm 0.5 mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 094.06 (blue) 10 A - 250 V stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 H 094.06.0 (black) EUR OP EAN III-2016, www.findernet.com 094.06 5 85 SERIES 94 SERIES Sockets and accessories for 85 series timers Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For timer type Accessories Metal retaining clip (supplied with socket - packaging code SMA) 6-way jumper link Identification tag Technical data Rated values Dielectric strength Protection category Ambient temperature 94.84.2 Approvals (according to type): 94.84.2 Blue 85.02, 85.04 094.06 94.84.20 Black 094.81 094.06.0 094.80.3 10 A - 250 V 2 kV AC IP 20 °C –40…+70 Screw torque Nm 0.5 Wire strip length Max. wire size for 94.84.2 socket mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 Top terminals R Bottom terminals OP EAN EU N T T E P A EUR OP H 94.84.2 6-way jumper link for 94.84.2 socket 094.06 (blue) Rated values 10 A - 250 V 094.06.0 (black) EAN III-2016, www.findernet.com 094.06 6 94 SERIES Sockets and accessories for 85 series timers 85 SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount For timer type Accessories Metal retaining clip 6-way jumper link Identification tag Technical data Rated values Dielectric strength Protection category Ambient temperature 94.94.3 Approvals (according to type): 94.92.3 (blue) 85.02 94.92.30 (black) 094.06 094.06.0 94.94.3 (blue) 85.04 094.81 094.06 094.80.3 94.94.30 (black) 094.06.0 10 A - 250 V 2 kV AC IP 20 °C –25…+70 Screw torque Nm 0.5 Wire strip length Max. wire size for 94.92.3 and 94.94.3 sockets mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 Top terminals R Bottom terminals OP EAN EU N T T E P A 94.94.3 6-way jumper link for 94.92.3 and 94.94.3 sockets 094.06 (blue) Rated values 10 A - 250 V 094.06.0 (black) EUR H OP EAN III-2016, www.findernet.com 094.06 7 85 SERIES 94 SERIES Sockets and accessories for 85 series timers 94.74 Approvals (according to type): 94.82 Approvals (according to type): 94.72 Blue 85.02 Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 60715) mount For timer type Accessories Metal retaining clip (supplied with timer) Screw terminal socket panel or 35 mm rail (EN 60715) mount For timer type Accessories Metal retaining clip (supplied with timer) Technical data Rated values Dielectric strength Protection category Ambient temperature Screw torque 94.72.0 Black 94.73 Blue 85.03 94.82 Blue 85.02 94.73.0 Black 94.74 94.74.0 Blue Black 85.02, 85.04 094.81 94.82.0 Black 85.02 094.81 10 A - 250 V 2 kV AC IP 20 °C –40…+70 Nm 0.5 Wire strip length mm Max. wire size for 94.72, 94.73, 94.74 and 94.82 sockets mm2 AWG 94.72 94.73 8 (94.72, 94.73, 94.74) solid wire 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 9 (94.82) stranded wire 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 94.74 H III-2016, www.findernet.com 94.82 8
85.03.0.125.0000 价格&库存
很抱歉,暂时无法提供与“85.03.0.125.0000”相匹配的价格&库存,您可以联系我们找货
