32
SЕRIES
Subminiature PCB
relays 6 A
Copiers
Hi-Fi systems
Washing
machines
Control
systems
Electronic kits
Medical and
dentistry
Electronic
circuit boards
Programmable
controllers
FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
32 SERIES
Subminiature PCB relays 6 A
32
SERIES
32.21-4000
Printed circuit mount 6 A relay
32.21-4300
• 1 Pole changeover contacts or 1 Pole normally
open contact
A
• Subminiature, low profile package
• Sensitive DC coil - 200 mW
• Wash tight: RT III
• Cadmium Free contacts
• 1 CO (SPDT), 6 A
• Low coil power
• PCB mount
For outline drawing see page 5
• 1 NO (SPST-NO), 6 A
• Low coil power
• PCB mount
Copper side view
Copper side view
1 CO (SPDT)
1 NO (SPST-NO)
6/15
6/15
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
250/400
250/400
Rated load AC1
V AC
VA
1500
1500
Rated load AC15 (230 V AC)
VA
250
250
Single phase motor rating (230 V AC)
kW
0.185
0.185
Breaking capacity DC1: 30/110/220 V
Minimum switching load
A
3/0.35/0.2
3/0.35/0.2
mW (V/mA)
500 (10/5)
500 (10/5)
AgSnO2
AgSnO2
Standard contact material
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
5 - 12 - 24 - 48
5 - 12 - 24 - 48
—/0.2
—/0.2
Operating range
AC
DC
(0.78…1.5)UN
(0.78…1.5)UN
Holding voltage
AC/DC
—/0.4 UN
—/0.4 UN
Must drop-out voltage
AC/DC
—/0.1 UN
—/0.1 UN
Mechanical life AC/DC
cycles
—/20 · 106
—/20 · 106
Electrical life at rated load AC1
cycles
50 · 103
50 · 103
ms
6/4
6/2
kV
5
5
1000
1000
–40…+85
–40…+85
RT III
RT III
Technical data
XI-2018, www.findernet.com
Operate/release time
Insulation between coil
and contacts (1.2/50 µs)
Dielectric strength
between open contacts
Ambient temperature range
Environmental protection
V AC
°C
Approvals (according to type)
3
32 SERIES
32
SERIES
Ordering information
Example: 32 series PCB, 1 NO (SPDT-NO) - 6 A contacts, 24 V sensitive DC coil.
A
A
3 2 . 2
B
C
D
1 . 7 . 0 2 4 . 4 . 3 . 0 . 0
Series
Type
2 = PCB mount
No. of poles
1 = 1 pole, 6 A
A: Contact material
4 = Standard AgSnO2
D: Special versions
0 = Wash tight (RT III)
B: Contact circuit
0=C
O (SPDT)
3=N
O (SPST)
C: Options
0 = None
Coil version
7 = Sensitive DC
Coil voltage
See coil specifications
Selecting features and options: only combinations in the same row are possible.
Preferred selections for best availability are shown in bold.
Type
Coil version
32.21
sens. DC
A
4
B
0-3
C
D
Technical data
Insulation according to EN 61810-1
Nominal voltage of supply system
V AC 230/400
Rated insulation voltage
V AC 250
Pollution degree
2
Insulation between coil and contact set
Type of insulation
Basic
Overvoltage category
III
Rated impulse voltage
kV (1.2/50 µs) 5
Dielectric strength
V AC 4000
Insulation between open contacts
Type of disconnection
Micro-disconnection
Dielectric strength
V AC/kV (1.2/50 µs) 1000/1.5
Insulation between coil terminals
Rated impulse voltage (surge) differential mode
(according to EN 61000-4-5)
kV(1.2/50 µs) 2
Other data
Bounce time: NO/NC
ms 2/10 (changeover)
Vibration resistance (5…55)Hz: NO/NC
Shock resistance
Power lost to the environment
g 10/10 (changeover)
2/— (normally open)
10/— (normally open)
g 20
without contact current
with rated current
W 0.5
mm ≥ 5
Recommended distance between relays mounte d on PCB
W 0.2
4
32 SERIES
32
SERIES
F 32 - Electrical life (AC) v contact current
H 32 - Maximum DC1 breaking capacity
DC breaking current (A)
A
Cycles
Resistive load - cosφ = 1
Inductive load - cosφ = 0.4
DC voltage (V)
• When switching a resistive load (DC1) having voltage and current
values under the curve, an electrical life of ≥ 50 · 103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with the
load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
Coil specifications
DC coil data - 0.2 W sensitive
Nominal
voltage
Coil code
R 32 - DC coil operating range v ambient temperature
Operating range
Resistance
Rated coil
consumption
UN
Umin
Umax
R
I at UN
V
V
V
Ω
mA
7.5
125
40
720
16
5
7.005
3.9
12
7.012
9.4
18
24
7.024
18.7
36
2880
48
7.048
37.4
72
11520
8.3
4
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
Outline drawing
Types 32.21-4000/4300
Please see general technical information
5
很抱歉,暂时无法提供与“32.21.7.024.2300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+92.59920
- 200+36.94680
- 500+35.71560
- 1000+35.10000
