58.34.8.024.0060SMA
58.34.8.024.0060SMA
    FINDER
    Module
58.34.8.024.0060SMA 数据手册
58 Series - Relay interface modules 7 - 10 A Features 58.32 58.33 58.34 2, 3 & 4 Pole relay interface modules, 27 mm wide. Ideal interface for PLC and electronic systems 58.32 - 2 Pole 10 A 58.33 - 3 Pole 10 A 58.34 - 4 Pole 7 A • AC coils and DC coils status indication and coil suppression module as standard • Identification label • Cadmium Free contacts • UL Listed • 35 mm rail (EN 50022) mounting • Supply • • 83 • • 3 pole 10 A 35 mm rail mounting • • 4 pole 7 A 35 mm rail mounting 12 41 9 11 COM 9 31 8 21 7 11 COM 12 41 11 31 10 21 9 11 COM 8 44 5 14 NO 6 34 5 24 4 14 NO 8 44 7 34 6 24 5 14 NO 4 42 1 12 NC 3 32 2 22 1 12 NC 4 42 3 32 2 22 1 12 NC 14 A2 13 A1 73 25.9 17.5 17.5 27.5 76 27 2 pole 10 A 35 mm rail mounting 14 A2 32 13 A1 COIL 14 A2 13 A1 — + COIL Example: AC Example: DC Example: AC 2 CO (DPDT) 3 CO (3PDT) 4 CO (4PDT) COIL Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 10/20 10/20 7/15 250/400 250/400 250/250 Rated load AC1 VA 2,500 2,500 1,750 Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi 58 Coil specification Nominal voltage (UN) V AC (50/60 Hz) 12 - 24 - 48 - 110 - 120 - 230 12 - 24 - 48 - 110 - 120 - 230 12 - 24 - 48 - 110 - 120 - 230 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 12 - 24 - 48 12 - 24 - 48 12 - 24 - 48 1.5/1 1.5/1 1.5/1 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN DC Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/50 · 106 20 · 106/50 · 106 Electrical life at rated load AC1 cycles 200 · 103 200 · 103 150 · 103 9/3 (AC) - 9/15 (DC) 9/3 (AC) - 9/15 (DC) 9/3 (AC) - 9/15 (DC) 3.6 3.6 3.6 1,000 1,000 1,000 –40…+70 –40…+70 –40…+70 IP 20 IP 20 IP 20 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category V AC °C Approvals relay (according to type) 139 58 Series - Relay interface modules 7 - 10 A Ordering information Example: 58 series 35 mm rail (EN 55022) mounting interface module, 4 CO (4PDT), 24 V DC coil, green LED + diode. 5 8 . 3 A B C D 4 . 9 . 0 2 4 . 0 0 5 0 Series Type 3 = 35 mm rail mount No. of poles 2 = 2 pole, 10 A 3 = 3 pole, 10 A 4 = 4 pole, 7 A A: Contact material 0 = AgNi Standard D: Special versions 0 = Standard B: Contact circuit 0 = CO (nPDT) C: Options 5 = Standard DC: green LED + diode (polarity +A1) 6 = Standard AC: green LED + Varistor Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage see coil specifications Technical data Insulation Insulation according to EN 61810-1 ed. 2 58 insulation rated voltage rated impulse withstand voltage pollution degree overvoltage category Insulation between coil and contacts (1.2/50 µs) V 400 (2-3 pole) kV 3.6 (2-3 pole) 250 (4 pole) 2.5 (4 pole) 2 III kV 3.6 Dielectric strength between open contacts V AC 1,000 Dielectric strength between adjacent contacts V AC 2,000 (58.32,58.33) 1,550 (58.34) Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 4 (4 kV) Other data Bounce time: NO/NC ms 1/4 Vibration resistance (10…55)Hz, max. ± 1 mm: NO/NC Power lost to the environment Wire strip length Screw torque Max. wire size 140 g/g 6/6 without contact current W 1 with rated current W 3 (58.32, 58.34) 4 (58.33) mm 8 Nm 0.5 solid cable stranded cable mm2 1x6 / 2x2.5 1x4 / 2x2.5 AWG 1x10 / 2x14 1x12 / 2x14 58 Series - Relay interface modules 7 - 10 A Contact specification F 58 - Electrical life (AC) v contact current 2 & 3 pole relays F 58 - Electrical life (AC) v contact current 4 pole relay 7 7 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 Cycles Cycles 10 6 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 5 5 10 10 0 4 8 12 0 16 (A) 4 8 12 16 (A) H 58 - Maximum DC1 breaking capacity DC breaking current (A) 20 2 & 3 pole current limit 4 pole current limit 10 6 4 1 2 2 4 contacts in series 3 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 1 0.2 0.1 20 60 100 140 180 220 DC voltage (V) 58 Coil specifications DC coil data Nominal voltage UN V 12 24 48 AC coil data Coil code Operating range Umin V 9.6 19.2 38.4 9.012 9.024 9.048 Umax V 13.2 26.4 52.8 Resistance Rated coil absorption R I at UN Ω mA 140 86 600 40 2,400 20 R 58 - DC coil operating range v ambient temperature Nominal voltage UN V 12 24 48 110 120 230 Coil code Operating range Umin V 9.6 19.2 38.4 88 96 184 8.012 8.024 8.048 8.110 8.120 8.230 Umax V 13.2 26.4 52.8 121 132 253 Resistance Rated coil absorption R I at UN (50Hz) Ω mA 50 97 190 53 770 25 4,000 12.5 4,700 12 17,000 6 R 58 - AC coil operating range v ambient temperature U 2.0 UN U 2.0 UN 1 1.5 1.0 1.5 1.0 2 0.5 -20 0 20 1 40 60 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 80 (°C) 2 0.5 -20 0 20 40 60 80 (°C) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 141 58 Series - Relay interface modules 7 - 10 A Combinations Code Type of socket Type of relay Module Retaining clip 58.32 94.02 55.32 99.02 094.01 58.33 94.03 55.33 99.02 094.01 58.34 94.04 55.34 99.02 094.01 Accessories 6-way jumper link 094.06 Rated values 10 A - 250 V 094.06 3.3 135 10.3 7 5.1 0.75 26.25 27 27 27 26.25 Sheet of marker tags, plastic, 72 tags, 6x12 mm 060.72 060.72 58 Packaging codes How to code and identify retaining clip and packaging options for relay interface module. Code options according to the last three letters: 5 8 . 3 4 . 9 . 0 2 4 . 0 0 5 0 S P A A B Standard packaging Blister packaging SP Plastic retaining clip 142
58.34.8.024.0060SMA 价格&库存
很抱歉,暂时无法提供与“58.34.8.024.0060SMA”相匹配的价格&库存,您可以联系我们找货
58.34.8.024.0060SMA
  • 1+261.84552
库存:64
