70 SERIES
Line monitoring relay
70
SERIES
70.11
Electronic voltage monitoring relays for
single and three-phase applications
70.31
• Multifunctional types, providing the flexibility
of monitoring Undervoltage, Overvoltage,
Window Mode, Phase rotation, Phase loss
• Positive safety logic - Make output contact
opens if the relay detects an error
• All functions and values can be easily adjusted
by the selector and trimmer on front face
• “Blade + cross” – both flat blade and cross
head screw drivers can be used to adjust the
regulators and the function selector
• Colored LEDs for clear & immediate visual
indication
• 1 CO relay output, 6 or 10 A
• Modular housing, 17.5 or 35 mm wide
• 35 mm rail (EN 60715) mount
• Cd-free contact material
Single-phase (220…240)V
voltage monitoring:
Three-phase (380…415)V
voltage monitoring:
• Undervoltage
• Undervoltage
• Overvoltage
• Overvoltage
• Window mode (overvoltage + • Window mode (overvoltage +
undervoltage)
• Voltage fault memory
selectable
Screw terminal
undervoltage)
selectable
• Phase loss, even under phase
regeneration
• Phase rotation
E
For outline drawing see page 10
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Max. switching voltage
A
V AC
1 CO (SPDT)
1 CO (SPDT)
10/30
6/10
250/400
250/400
Rated load AC1
VA
2500
1500
Rated load AC15
VA
750
500
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220 V
A
Minimum switching load
mW (V/mA)
Standard contact material
0.5
0.185
10/0.3/0.12
6/0.2/0.12
300 (5/5)
500 (12/10)
AgNi
AgNi
220…240
380…415
Supply specification
Nominal system voltage (UN)
Rated power
Operating range
V AC (50/60 Hz)
VA (50 Hz)/W
V AC (50/60 Hz)
2.6/0.8
11/0.9
130…280
220…510
80 · 103
60 · 103
170…270
300…480
Technical data
Electrical life at rated load AC1
cycles
Voltage detection level range
V
Asymmetry detection level range
Switch-off delay time (T on function diagrams) s
Switch-on lock-out time
s
Switch-on hysteresis (H on function diagrams) V
XI-2016, www.findernet.com
Power-on activation time
Insulation between supply
and contacts (1.2/50 µs)
Dielectric strength
between open contacts
Ambient temperature
Protection category
s
kV
V AC
°C
0.5…60
0.5…60
0.5
1
5 (L-N)
10 (L-L)
≈1
≈1
4
4
1000
1000
–20…+60
–20…+60
IP 20
IP 20
Approvals (according to type)
1
70
SERIES
70 SERIES
70.41
70.42
Window Mode, Phase rotation, Phase loss,
Asymmetry and Neutral loss
• Phase loss monitoring, even under phase
regeneration
indication
• 1 or 2 CO relay output, 6 or 8 A
• Modular housing, 35 mm wide
Three-phase (380…415 V,
with neutral) voltage
monitoring:
• Window mode (overvoltage + • Undervoltage
undervoltage)
• Overvoltage
• Phase loss
• Phase rotation
undervoltage)
• Asymmetry
• Neutral loss selectable
selectable
• Phase loss
• Phase rotation
• Asymmetry
• Neutral loss
Screw terminal
Rated voltage/
A
2 CO (DPDT)
6/10
8/15
250/400
250/400
Rated load AC1
VA
1500
2000
Rated load AC15
VA
500
400
kW
0.185
0.3
A
6/0.2/0.12
8/0.3/0.12
mW (V/mA)
500 (12/10)
300 (5/5)
AgNi
AgNi
380…415
380…415
11/0.9
12.5/1
220…510
220…510
60 · 103
60 · 103
300…480
300…480
V AC
1 CO (SPDT)
Rated power
Operating range
V AC (50/60 Hz)
VA (50 Hz)/W
V AC (50/60 Hz)
Technical data
cycles
V
s
Dielectric strength
Ambient temperature
Protection category
2
s
kV
V AC
°C
4…25
5…25
0.5…60
0.5…60
1
1
10 (L-L)
10 (L-L)
≈1
≈1
4
4
1000
1000
–20…+60
–20…+60
IP 20
IP 20
E
Three-phase (380…415 V, with
or without neutral) voltage
monitoring:
70 SERIES
70
SERIES
70.61
Electronic phase loss and rotation monitoring
relays for three-phase applications
70.62
• Universal voltage monitoring (UN from 208 V to
480 V, 50/60 Hz)
regeneration
• Positive safety logic - Make contact opens if the
• 2 versions:
1 CO relay output, 6 A (17.5 mm wide), and
2 CO relay output, 8 A (22.5 mm wide)
European patent pending for the innovative
principle at the root of the 3 phase monitoring
and error survey system (70.61)
Three-phase (208…480)V
voltage monitoring:
voltage monitoring:
• Phase loss
• Phase rotation
• Phase loss
• Phase rotation
Screw terminal
E
Rated voltage/
A
V AC
Rated load AC1
VA
1 CO (SPDT)
2 CO (DPDT)
6/15
8/15
250/400
250/400
1500
2000
Rated load AC15
VA
250
400
kW
0.185
0.3
A
3/0.35/0.2
8/0.3/0.12
mW (V/mA)
500 (10/5)
300 (5/5)
AgSnO2
AgNi
208…480
208…480
Rated power
Operating range
V AC (50/60 Hz)
8/1
11/0.8
V AC (50/60 Hz)
VA (50 Hz)/W
170…500
170…520
cycles
100 · 103
60 · 103
Technical data
s
0.5
0.5
s
0.5
0.5
s
很抱歉,暂时无法提供与“70.61.8.400.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1065.440111+125.17188
- 10+882.0317610+103.62438
- 25+822.8114725+96.66696
- 50+783.3974750+92.03646
- 100+761.75386100+89.49369
