LED panel light
7L
SЕRIES
Panels for
electrical
distribution
Control panels
FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
7L
7L SERIES
LED panel light
SERIES
7L.43.0.xxx.0x00
LED light for electrical panels
Type 7L.43.0.xxx.0x00
- 600 lumens
- Direct magnetic mounting or through
a screw-fixed metallic support
• Low power consumption
• Radiation angle 120°
• Colour temperature 5000 K
• Push-in terminals for the connection to a
single unit
• Plug-in terminals for the connection to a single
or multiple units (up to 7 lamps)
• Design by Minelli - Fossati
• 600 lumens, 6 W
• Without ON/OFF switch or movement detector
G
For outline drawing see page 8
Lamp Data
Type of lamp
LED, viewing angle 120°, Light colour: daylight white, colour
temperature: 5000 K
Luminous flux
Life time
lm
600
h
60000
Electrical Data
Operating voltage
V AC (50/60 Hz)/DC
12…48 - 110…240
V AC/DC
9.6…52.8 - 88…264
Operating range
Nominal current @230 V AC
mA
39
Nominal current @24 V DC
mA
200
Rated power of the lamp @230 V AC
W
6
Rated power of the lamp @24 V DC
W
6
X-2020, www.findernet.com
General data
Connection cable to the lamp
Sheathed cable 2 x 1.5 mm², flexible with push-in or socket
Interconnectors from lamp to lamp
Sheathed cable 2 x 1.5 mm², flexible with plug and socket
Socket and plug
2-pole with interlock
Type of mounting
Magnetic or clip fixing
Housing
Ambient temperature
Protection class
Protection category
Plastic, transparent
°C
−30…+55
II
IP 20
Approvals (according to type)
3
7L
SERIES
7L SERIES
LED panel light
7L.43.0.xxx.1x00
7L.46.0.xxx.1x00
Type 7L.43.0.xxx.1x00
- 600 lumens
Type 7L.46.0.xxx.1x00
- 1200 lumens
• 600 lumens, 6 W
• With ON/OFF switch
• 1200 lumens, 9 W
single unit
G
For outline drawing see page 9
Lamp Data
Type of lamp
temperature: 5000 K
Luminous flux
lm
Life time
600
h
1200
60000
Electrical Data
Operating voltage
V AC (50/60 Hz)/DC
Operating range
12…48 - 110…240
V AC/DC
9.6…52.8 - 88…264
mA
39
54
mA
200
300
W
6
9
W
6
9
Socket and plug
Type of mounting
Housing
Ambient temperature
Protection class
Protection category
4
°C
−30…+55
II
IP 20
General data
7L
7L SERIES
LED panel light
SERIES
7L.43.0.xxx.2x00
7L.46.0.xxx.2x00
Type 7L.43.0.xxx.2x00
- 600 lumens
Type 7L.46.0.xxx.2x00
- 1200 lumens
• 600 lumens, 6 W
• With movement detector
• 1200 lumens, 9 W
single unit
G
For outline drawing see page 10
Lamp Data
Type of lamp
temperature: 5000 K
Luminous flux
lm
Life time
600
h
Light ON time after last detection
1200
60000
min
3
Electrical Data
Operating voltage
V AC (50/60 Hz)/DC
Operating range
12…48 - 110…240
V AC/DC
9.6…52.8 - 88…264
mA
39
54
mA
200
300
W
6
9
W
6
9
General data
Socket and plug
Type of mounting
Housing
Ambient temperature
Protection class
Protection category
°C
−30…+55
II
IP 20
5
7L
SERIES
7L SERIES
LED panel light
Ordering information
Example: Series 7L, LED light with magnetic fixing, ON/OFF switch, supply voltage 12…48V AC/DC and push-in terminals.
7 L . 4 3 . 0 . 0 2 4 . 1
Series
Type
43 = LED lamp 600 lumens
46 = LED lamp 1200 lumens
Supply version
0 = AC (50/60 Hz)/DC
Supply voltage
024 = (12…48)V AC/DC
230 = (110…240)V AC/DC
1
Connections
1 = Push-in terminals for the connection to a
single unit
2 = Plug-in terminals for the connection to a
single or multiple units
Switching
0 = Without ON/OFF switch or movement detector
1 = Switching via ON/OFF switch
2 = Switching via movement detector
All types
7L.43.0.024.0100
7L.43.0.024.0200
7L.43.0.024.1100
7L.43.0.024.1200
7L.43.0.024.2100
7L.43.0.024.2200
7L.43.0.230.0100
7L.43.0.230.0200
7L.43.0.230.1100
7L.43.0.230.1200
7L.43.0.230.2100
7L.43.0.230.2200
7L.46.0.024.1100
7L.46.0.024.1200
7L.46.0.024.2100
7L.46.0.024.2200
7L.46.0.230.1100
7L.46.0.230.1200
7L.46.0.230.2100
7L.46.0.230.2200
G
6
7L
7L SERIES
LED panel light
SERIES
Accessories
0 7 L . 1 1
Type
07L.11 (included in the box)
Sockets and plugs, coded, for connection to
a 2-pole cable (2 x 1.5 mm2), e.g. H05VV-F, 2 x 1.5 mm2
11 = Socket, loose for input side
12 = Plug, loose for output side
07L.12 (not included)
Outline drawings
Type 07L.11
Type 07L.12
Connections
G
Quick and simple wiring system via
push-in terminals for the connection
to a single unit, or via plug-in
single or multiple units.
Multiple connection (up to 7 lamps)
7
7L
SERIES
7L SERIES
LED panel light
Outline drawings
Types 7L.4x.0.xxx.0100/0200
G
8
7L SERIES
LED panel light
7L
SERIES
Outline drawings
Types 7L.4x.0.xxx.1100 / 1200
G
9
7L
SERIES
7L SERIES
LED panel light
Outline drawings
Types 7L.4x.0.xxx.2100 / 2200
G
10
Please see general technical information
很抱歉,暂时无法提供与“07L.12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+85.09320
- 200+33.95520
- 500+32.82120
- 1000+32.25960
