09-0128-290-07
09-0128-290-07
    BINDER(宾德)
    BINDER - 09-0128-290-07 - CIRCULAR CONNECTOR, RCPT, 7POS, PANEL
09-0128-290-07 数据手册
Product data sheet Miniature connectors Product description   Area Part no. M16 Female panel mount connector, Contacts: 7 (07-a), shieldable, THT, IP67, UL, front fastened   M16 IP67 09 0128 290 07 Illustration Conductor layout Scale drawing Contact arrangement (Plug-in side) You can find the component part drawing and assembly instructions on the next page. Technical data General features Part no. Connector design Type standard Version Connector locking system Termination Degree of protection 09 0128 290 07 Female panel mount connector DIN EN 61076-2-106 Connector socket straight screw THT IP67 Date: 29.05.2024 Product data sheet Miniature connectors Product description   Area Part no. Temperature range from/to Mechanical operation Weight (g) Customs tariff number Country of Origin M16 Female panel mount connector, Contacts: 7 (07-a), shieldable, THT, IP67, UL, front fastened   M16 IP67 09 0128 290 07 -40 °C / 95 °C > 500 Mating cycles 9.54 85369010 DE Electrical parameters Rated voltage Rated impulse voltage Rated current Insulation resistance Pollution degree Overvoltage category Insulating material group EMC compliance Shield connection 125 V 800 V 5.0 A ≥ 1010 Ω 1 I III shieldable Shield pin Material Housing material Contact body material Contact material Contact plating REACH SVHC SCIP number Zinc die-cast nickel-plated PBT (UL94 V-0) CuSn (bronze) Ag (silver) CAS 7439-92-1 (Lead) c0f107c0-57e6-4c88-bfde-6003a23f0667 Authorization/approvals Approvals UL Classifications eCl@ss 11.1 ETIM 9.0 27-44-01-09 EC003569 Date: 29.05.2024 Product data sheet Miniature connectors Product description   Area Part no. M16 Female panel mount connector, Contacts: 7 (07-a), shieldable, THT, IP67, UL, front fastened   M16 IP67 09 0128 290 07 Assembly instructions / Panel cut-out Date: 29.05.2024 Product data sheet Miniature connectors Product description   Area Part no. M16 Female panel mount connector, Contacts: 7 (07-a), shieldable, THT, IP67, UL, front fastened   M16 IP67 09 0128 290 07 Component part drawing Date: 29.05.2024 Product data sheet Miniature connectors Product description   Area Part no. M16 Female panel mount connector, Contacts: 7 (07-a), shieldable, THT, IP67, UL, front fastened   M16 IP67 09 0128 290 07 General Disclaim Notice The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Connectors which are used in circuits with voltages dangerous to the touch may only be installed and used by, or under the supervision of, persons with electrical engineering training, taking into account the applicable regulations and standards. The user must take suitable safety precautions to ensure that the connector cannot be accidentally disconnected. Plug connectors with enclosure protection IP67 and IP68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. The plug connector is not suitable for mains voltages Please observe the pollution degree and the overvoltage category. For further information, please refer to the download center "Technical Information". The protection class specification applies on condition that the four mounting holes are made as blind holes. Date: 29.05.2024
09-0128-290-07 价格&库存
很抱歉,暂时无法提供与“09-0128-290-07”相匹配的价格&库存,您可以联系我们找货
