79-9723-020-08
79-9723-020-08
    BINDER(宾德)
    BINDER - 79-9723-020-08 - Sensor Cable, X-Coding, M12 Plug, RJ45 Plug, 8 Positions, 2 m, 6.6 ft
79-9723-020-08 数据手册
Product data sheet Automation Technology Product description Contacts: 8, Connecting cable 2m, male cable connector M12x1 - RJ45-male connector, shielded, IP67 Area Order number M12-D, M12-X Series 876 X-coding 79 9723 020 08 Illustration Scale drawing Contact arrangement Technical data General values Connector design Connector locking system Termination Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values connecting cord bolted crimp, moulded on cable 4x2xAWG26 85 °C -40 °C Cable data Sheath material Single-lead insulation Single-lead structure Cable sheath Ø Conductor resistance Temperature range, moving cable, °C from Temperature range, moving cable, °C to Temperature range, fixed cable, °C from Temperature range, fixed cable, °C to Bending radius, fixed cable Approval 1 Cable diameter PUR green PE 8 x 0,14 6.2 14,5Ω/100 m -10 60 -40 85 ≥ 50 mm UL listed 6.2 Rated voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation 50V AC, 60V DC V 3 II II 0,5 A ≤ 15 mΩ shielded IP67 > 100 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA PUR Date: 2018-02-05 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation Technology Product description Contacts: 8, Connecting cable 2m, male cable connector M12x1 - RJ45-male connector, shielded, IP67 Area Order number M12-D, M12-X Series 876 X-coding 79 9723 020 08 Sicherheitshinweise The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2018-02-05 - Page 2 of 2
79-9723-020-08 价格&库存
很抱歉,暂时无法提供与“79-9723-020-08”相匹配的价格&库存,您可以联系我们找货
