99 0605 00 03
99 0605 00 03
    BINDER(宾德)
    BINDER - 99 0605 00 03 - Circular Connector, 678 Series, Cable Mount Plug, 3 Contacts, Solder Pin, N...
99 0605 00 03 数据手册
Product sheet Miniature connectors Male cable connector, cable outlet 4-6 mm Bayonet connectors illustration Pole Article number serie 678 scale drawing Date: 2013-06-04 - Page 1 of 2 Product Area 3 DIN 99 0605 00 03 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Bayonet-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 7A Volume resistivity ≤ 5 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >500 mating cycles Material of contact CuZn (brass) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 V-0) Cable data Contacts 3 DIN, male cable connector, cable outlet 4 – 6 mm Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0605 00 03 Product sheet Miniature connectors Male cable connector, cable outlet 4-6 mm Bayonet connectors serie 678 Pole Article number Date: 2013-06-04 - Page 2 of 2 Product Area 3 DIN 99 0605 00 03 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0605 00 03
99 0605 00 03 价格&库存
很抱歉,暂时无法提供与“99 0605 00 03”相匹配的价格&库存,您可以联系我们找货
