99-3782-210-08
99-3782-210-08
    BINDER(宾德)
    BINDER - 99-3782-210-08 - SENSOR CONNECTOR, M12, RCPT, 8POS
99-3782-210-08 数据手册
Powered by TCPDF (www.tcpdf.org) Product sheet Automation technology - Speciality connectors Product Contacts 8: Female panel mount connector with X-coding, dip-solder, fixed housing contacts Area Article number M12-D, M12-X Series 825/876 X-coding 99 3782 210 08 Illustration Conductor layout Scale drawing Contact Arrangement Technical data Common values Connector Design Connector locking system Termination Upper temperature Lower temperature Electrical values Cable plug connector screw dip-solder 85 °C -40 °C Cable data material housing Insulation single lead Single lead structure Conductor resistance Bending radius cable fixed Bending radius cable movable - Rated voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity Degree of protection Mechanical operation 50 V AC / 60 V DC 3 II III 0.5 A ≤ 10 mΩ IP67 > 100 mating cycles Material Material of contact Contact plating Material of contact body Material of housing CuSn (Bronze) Au (Gold) PA Nickel-plated zinc die casting Date: 2016-01-13 - Page 1 of 1
99-3782-210-08 价格&库存
很抱歉,暂时无法提供与“99-3782-210-08”相匹配的价格&库存,您可以联系我们找货
