99-9127-490-08
99-9127-490-08
    BINDER(宾德)
    BINDER - 99-9127-490-08 - Circular Connector, 720 Series, Panel Mount Plug, 8 Contacts, PCB Pin, Sna...
99-9127-490-08 数据手册
Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector, lightgrey, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 99 9127 490 08 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values male panel mount connector snap dip-solder 0,25 mm² 24 85 °C -40 °C Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection Mechanical operation 2A 125 V 2500 V 2 II II ≤ 3 mΩ ≥ 10¹⁰Ω not shielded IP67 > 500 Mating cycles Material Contact material Contact plating Contact body material Housing material CuSn (bronze) Au (gold) PA (UL 94 V-0) PA Date: 2018-11-22 - Page 1 of 3 Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector, lightgrey, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 99 9127 490 08 Component part drawing Assembly instructions / Panel cut-out Date: 2018-11-22 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector, lightgrey, dip-solder Area Order number Snap-in IP67, miniature Series 720 MED 99 9127 490 08 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2018-11-22 - Page 3 of 3
99-9127-490-08
1. 物料型号:Series 720 MED 99 9127 490 08,为8个接触点的男性面板安装连接器,浅灰色,浸锡焊接,快插式IP67。
2. 器件简介:该连接器设计用于医疗应用,具有轻触式连接和浸锡焊接。
3. 引脚分配:提供了8个接触点的排列,包括具体的位置和尺寸。
4. 参数特性: - 额定电流:2A(40°C) - 额定电压:125V - 额定脉冲电压:2500V - 接线规格:0.25 mm²,24 AWG - 污染等级:2 - 过电压类别:II - 上限温度:85°C - 下限温度:-40°C
5. 功能详解:详细描述了连接器的设计,包括锁定系统、接线方式、绝缘材料、接触材料、外壳材料等。
6. 应用信息:该连接器适用于工厂、控制系统和电气设备。并强调了连接器不能在负载下连接或分离,以避免人身伤害。
7. 封装信息:提供了组件部分的图纸,包括六角螺母、男性插入件、平板密封、女性插入件等,并提供了组装说明和面板开孔尺寸。
99-9127-490-08 价格&库存
很抱歉,暂时无法提供与“99-9127-490-08”相匹配的价格&库存,您可以联系我们找货
