99-9227-400-08
99-9227-400-08
    BINDER(宾德)
    BINDER - 99-9227-400-08 - CIRCULAR CONNECTOR, PLUG, 8POS, PANEL
99-9227-400-08 数据手册
Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9227 400 08 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values male panel mount connector snap solder 0,25 mm² 24 85 °C -25 °C Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance EMC compliance Degree of protection 1A 63 V 800 V 2 II II ≤ 3 mΩ ≥ 10¹⁰Ω Shielding is not possible IP67 Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA (UL 94 V-0) PA Date: 2018-11-22 - Page 1 of 3 Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9227 400 08 Component part drawing Assembly instructions / Panel cut-out Date: 2018-11-22 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Connectors for medical applications Product description Contacts: 8, male panel mount connector Area Order number Snap-in IP67, subminiature Series 620 MED 99 9227 400 08 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2018-11-22 - Page 3 of 3
99-9227-400-08 价格&库存
很抱歉,暂时无法提供与“99-9227-400-08”相匹配的价格&库存,您可以联系我们找货
