09-0454-300-14
09-0454-300-14
    BINDER(宾德)
    BINDER - 09-0454-300-14 - Circular Connector, 423/723/425 Series, Panel Mount Receptacle, 14 Contact...
09-0454-300-14 数据手册
Product data sheet Miniature connectors Product description M16 IP67 square female panel mount connector, Contacts: 14, unshielded, solder, IP67, UL Area Order number M16 IP67 series 723 09 0454 300 14 Illustration Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number Connector design Version Connector locking system Termination Degree of protection Cross-sectional area Temperature range from/to Mechanical operation Weight (g) Customs tariff number Material 09 0454 300 14 square female panel mount connector connector female straight screw solder IP67 0.25 mm² / AWG 24 -40 °C / 95 °C > 500 Mating cycles 9.986 85369010 Housing material Contact body material Contact material Contact plating Locking material REACH SVHC Zinc die-cast nickelplated PBT (UL94 V-0) CuZn (brass) Au (gold) Zinc die-cast nickelplated CAS 7439-92-1 (Lead) Classifications eCl@ss 11.1 ETIM 7.0 27-44-01-09 EC003569 Electrical parameters Rated voltage Rated impulse voltage Rated current (40 °C) Insulation resistance Pollution degree Overvoltage category Insulating material group EMC compliance 60 V 500 V 3A ≥ 10¹⁰ Ω 1 I III unshielded Date: 2021-04-19 - Page 1 of 3 Product data sheet Miniature connectors Product description M16 IP67 square female panel mount connector, Contacts: 14, unshielded, solder, IP67, UL Area Order number M16 IP67 series 723 09 0454 300 14 Assembly instructions / Panel cut-out Date: 2021-04-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Miniature connectors Product description M16 IP67 square female panel mount connector, Contacts: 14, unshielded, solder, IP67, UL Area Order number M16 IP67 series 723 09 0454 300 14 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. The protection class specification applies on condition that the four mounting holes are made as blind holes. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 2021-04-19 - Page 3 of 3
09-0454-300-14 价格&库存
很抱歉,暂时无法提供与“09-0454-300-14”相匹配的价格&库存,您可以联系我们找货
