99 0071 100 02
99 0071 100 02
    BINDER(宾德)
    BINDER - 99 0071 100 02 - Circular Connector, 711 Series, Cable Mount Plug, 2 Contacts, Solder Pin, ...
99 0071 100 02 数据手册
Product sheet Subminiature connectors Male cable connector M9 connectors IP 40 Pole Article number serie 711 illustration scale drawing Date: 2013-10-02 - Page 1 of 2 Product Area 2 99 0071 100 02 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet 3 - 4 mm Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >500 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 VH-B) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 2, Male cable connector, cable outlet 3 – 4 mm Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0071 100 02 Product sheet Subminiature connectors Male cable connector M9 connectors IP 40 serie 711 Pole Article number Date: 2013-10-02 - Page 2 of 2 Product Area 2 99 0071 100 02 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0071 100 02
99 0071 100 02 价格&库存
很抱歉,暂时无法提供与“99 0071 100 02”相匹配的价格&库存,您可以联系我们找货
