99 0076 100 03
99 0076 100 03
    BINDER(宾德)
99 0076 100 03 数据手册
Product sheet Subminiature connectors Female cable connector M9 connectors IP 40 Pole Article number serie 711 illustration scale drawing Date: 2012-10-08 Product Area 2 99 0072 102 02 Item description Contact Arrangement Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet 4 - 5 mm Upper temperature +85 °C Lower temperature -40 °C Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >500 mating cycles Powered by TCPDF (www.tcpdf.org) Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 VH-B) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 2, Female cable connector, cable outlet 4 – 5 mm 99 0072 102 02
99 0076 100 03 价格&库存
很抱歉,暂时无法提供与“99 0076 100 03”相匹配的价格&库存,您可以联系我们找货
  • 5+161.033475+20.82601
  • 20+107.8682720+13.95030
  • 100+94.45578100+12.21570
库存:60
99 0076 100 03
  • 1+104.151341+13.46960
  • 5+93.316815+12.06840
  • 20+82.9191520+10.72370
  • 100+72.60887100+9.39030
库存:60
