99-0410-75-04
99-0410-75-04
    BINDER(宾德)
99-0410-75-04 数据手册
Product data sheet Subminiature connectors Product description M9 IP67 female angled connector, Contacts: 4, 3.5 - 5.0 mm, shieldable, solder, IP67 Area Order number M9 IP67 series 712 99 0410 75 04 Illustration Scale drawing Contact arrangement (Plug-in side) You can find the component part drawing and assembly instructions on the next page. Technical data General features Order number Connector design Version Connector locking system Termination Degree of protection Cross-sectional area Cable outlet Temperature range from/to Mechanical operation Weight (g) Customs tariff number Material 99 0410 75 04 female angled connector connector female angled screw solder IP67 max. 0.25 mm² / max. AWG 24 3.5 - 5.0 mm -40 °C / 85 °C > 500 Mating cycles 26.556 85369010 Contact body material Contact material Contact plating Locking material REACH SVHC PA (UL94 V-0) CuSn (bronze) Au (gold) CuZn (Brass nicke,l plated) CAS 96-45-7 (Imidazolidine-2-thio ne) CAS 7439-92-1 (Lead) Declarations of conformity Low Voltage Directive 2014/35/EU (EN 60204-1:2018;EN 60529:1991) Electrical parameters Rated voltage Rated impulse voltage Rated current (40 °C) Insulation resistance Pollution degree Overvoltage category Insulating material group EMC compliance 125 V 1500 V 3A ≥ 10¹⁰ Ω 1 II III shieldable Date: 2020-10-04 - Page 1 of 3 Product data sheet Subminiature connectors Product description M9 IP67 female angled connector, Contacts: 4, 3.5 - 5.0 mm, shieldable, solder, IP67 Area Order number M9 IP67 series 712 99 0410 75 04 Component part drawing Assembly instructions / Panel cut-out Date: 2020-10-04 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Subminiature connectors Product description M9 IP67 female angled connector, Contacts: 4, 3.5 - 5.0 mm, shieldable, solder, IP67 Area Order number M9 IP67 series 712 99 0410 75 04 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Connectors which are used in circuits with voltages dangerous to the touch may only be installed and used by, or under the supervision of, persons with electrical engineering training, taking into account the applicable regulations and standards. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. To lock the cable connector with the device connector, the threaded ring is tightened "hand-tight" (approx. 50 cNm). Date: 2020-10-04 - Page 3 of 3
99-0410-75-04 价格&库存
很抱歉,暂时无法提供与“99-0410-75-04”相匹配的价格&库存,您可以联系我们找货
