99-0771-002-08
99-0771-002-08
    BINDER(宾德)
99-0771-002-08 数据手册
Product sheet Miniature connector Product Contacts: 8, cable plug connector, cable outlet 6 - 8 mm Area Article number Bayonet NCC Series 770 99 0771 002 08 Illustration Scale drawing Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper temperature Lower temperature Electrical values Cable plug connector Bayonet Solder 0.25 mm² max. 24 6 - 8 mm 85 °C -25 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity EMV compliance Degree of protection Mechanical operation 175 V 1750 V 2 II II 2A ≤ 15 mΩ IP67 > 5000 mating cycles Material Material of contact Contact plating Material of contact body Material of housing CuZn (Brass) Au (Gold) PA (UL 94 HB) PA (UL 94 V-0) Date: 2016-01-13 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product sheet Miniature connector Product Contacts: 8, cable plug connector, cable outlet 6 - 8 mm Area Article number Bayonet NCC Series 770 99 0771 002 08 Item description Installation instructions / Mounting cutout Date: 2016-01-13 - Page 2 of 2
99-0771-002-08 价格&库存
很抱歉,暂时无法提供与“99-0771-002-08”相匹配的价格&库存,您可以联系我们找货
  • 1+129.58979
  • 5+125.71584
  • 15+121.82107
  • 25+119.22802
  • 50+116.63498
库存:98
