99-4225-00-07
99-4225-00-07
    BINDER(宾德)
99-4225-00-07 数据手册
Product data sheet Power Product description Contacts: 6+PE, cable plug connector with cable strain relief, PG 9 with VDE, ETS, UL approval, solder Area Order number RD24 Power Series 692/693 99 4225 00 07 Illustration Scale drawing Contact arrangement Derating curve You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Electrical values cable connector bolted solder max. 0,75 mm² max. 20 6,0 - 9,5 mm 100 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation UL ESTI+ VDE Material Cable data Approval 1 Approval 2 Approval 3 Contact material Contact plating Contact body material 250 V 4000 V 3 III III 10 A (8 A UL) ≤ 5 mΩ Shielding is not possible IP67 > 500 Mating cycles CuZn (brass) Ag (silver) PBT (UL 94 V-0) Date: 2018-02-05 - Page 1 of 3 Product data sheet Power Product description Contacts: 6+PE, cable plug connector with cable strain relief, PG 9 with VDE, ETS, UL approval, solder Area Order number RD24 Power Series 692/693 99 4225 00 07 Component part drawing Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Power Product description Contacts: 6+PE, cable plug connector with cable strain relief, PG 9 with VDE, ETS, UL approval, solder Area Order number RD24 Power Series 692/693 99 4225 00 07 Sicherheitshinweise The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE 0140-1). Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2018-02-05 - Page 3 of 3
99-4225-00-07 价格&库存
很抱歉,暂时无法提供与“99-4225-00-07”相匹配的价格&库存,您可以联系我们找货
  • 1+159.47750
  • 10+156.67618
  • 50+152.50023
  • 100+148.08477
  • 250+144.49199
库存:496
