99-9228-00-08
99-9228-00-08
    BINDER(宾德)
99-9228-00-08 数据手册
Product sheet Subminiature connectors Female socket Snap-in connectors IP 67 Pole Article number serie 620 illustration scale drawing Date: 2013-05-16 - Page 1 of 2 Product Area 8 99 9228 00 08 Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Snap-in locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet 3 - 5 mm Upper temperature +85 °C Lower temperature -25 °C Electrical values Rated voltage 63 V Rated impulse voltage 800 V Pollution degree 2 Overvoltage category II Material group II Rated current (40°C) 1A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 67 Mechanical operation >500 mating cycles Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 V-0) Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 8, Female socket Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 9228 00 08 Product sheet Subminiature connectors Female socket Snap-in connectors IP 67 serie 620 Pole Article number Date: 2013-05-16 - Page 2 of 2 Product Area 8 99 9228 00 08 Item description Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 9228 00 08
99-9228-00-08 价格&库存
很抱歉,暂时无法提供与“99-9228-00-08”相匹配的价格&库存,您可以联系我们找货
  • 1+103.36775
  • 10+101.54533
  • 50+98.25456
  • 100+96.22386
  • 250+94.03695
库存:312
