09-5288-00-08
09-5288-00-08
    BINDER(宾德)
    BINDER - 09-5288-00-08 - ADAPTER, 8POS M12-RJ45, IP20
09-5288-00-08 数据手册
Product data sheet Automation technology - data transmission and power supply Product description Contacts: 8, adapter, lead through for control cabinet, female-RJ45, angled Area Order number M12-D, M12-X Series 825/876 X-coding 09 5288 00 08 Illustration Scale drawing Contact arrangement Technical data General values Connector design Connector locking system Upper limit temperature Lower limit temperature Electrical values adapter bolted 85 °C -40 °C Cable data Approval 1 UL Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Volume resistivity Insulation resistance Degree of protection Mechanical operation 0,5 A 50V AC, 60V DC V 800 V 3 II III ≤ 10 mΩ > 10⁸ Ω IP67 > 100 Mating cycles Material Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA Brass nickel-plated, Zinc die-cast nickel-plated Date: 2018-11-22 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - data transmission and power supply Product description Contacts: 8, adapter, lead through for control cabinet, female-RJ45, angled Area Order number M12-D, M12-X Series 825/876 X-coding 09 5288 00 08 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2018-11-22 - Page 2 of 2
09-5288-00-08 价格&库存
很抱歉,暂时无法提供与“09-5288-00-08”相匹配的价格&库存,您可以联系我们找货
