79-3108-32-04
79-3108-32-04
    BINDER(宾德)
79-3108-32-04 数据手册
Product data sheet Automation technology - sensors and actuators Product description M5 female cable connector, Contacts: 4, not shielded, moulded on cable, IP67, M5x0.5, PUR black, 4 x 0.25 mm² Area Order number M5 series 707 79 3108 32 04 Illustration Scale drawing Contact arrangement Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Customs tariff number Electrical values female cable connector screw moulded on cable 0.25 mm² 24 80 °C – 25 °C 85444290 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 2m PUR PVC 32 x 0,1 mm 148Ω/Km - 5 °C 80 °C -25 °C 80 °C Material Cable data Cable length Sheath material Single-lead insulation Single-lead structure Conductor resistance Temperature range, moving cable, °C from Temperature range, moving cable, °C to Temperature range, fixed cable, °C from Temperature range, fixed cable, °C to Contact material Contact plating Contact body material Housing material 1A 60 V 800 V 3 II I > 10⁸ Ω not shielded IP67 > 100 Mating cycles CuSn (bronze) Au (gold) PUR PUR Date: 2019-10-25 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M5 female cable connector, Contacts: 4, not shielded, moulded on cable, IP67, M5x0.5, PUR black, 4 x 0.25 mm² Area Order number M5 series 707 79 3108 32 04 Security notices The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2019-10-25 - Page 2 of 2
79-3108-32-04 价格&库存
很抱歉,暂时无法提供与“79-3108-32-04”相匹配的价格&库存,您可以联系我们找货
