Product sheet
Subminiature connectors
Male cable connector
M9 connectors IP 40
Pole
Article number
serie 711
illustration
scale drawing
Date: 2013-06-04 - Page 1 of 2
Product
Area
4
99 0079 100 04
Contact Arrangement
You can find the item description on the next page.
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
solder
Wire gauge (mm)
0,25 mm²
Wire gauge (AWG)
24
Max. Cable outlet
3 - 4 mm
Upper temperature
+85 °C
Lower temperature
-40 °C
Electrical values
Rated voltage
125 V
Rated impulse voltage
1500 V
Pollution degree
1
Overvoltage category
II
Material group
III
Rated current (40°C)
3A
Volume resistivity
≤ 3 mΩ
EMV compliance
not shieldable
Degree of protection
IP 40
Mechanical operation
>500 mating cycles
Material of contact
CuZn (brass)
Contact plating
Au (gold)
Material of contact body
PA (UL 94 V-0)
Material of housing
PA (UL 94 VH-B)
Cable data
material housing
insulation single lead
single lead structure
conductor resistance
Contacts 4, Male cable connector, cable outlet
3 – 4 mm
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
99 0079 100 04
Product sheet
M9 connectors IP 40
serie 711
Pole
Article number
Date: 2013-06-04 - Page 2 of 2
Product
Area
4
99 0079 100 04
Item description
Powered by TCPDF (www.tcpdf.org)
99 0079 100 04
很抱歉,暂时无法提供与“99 0079 100 04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+102.693641+13.34530
- 5+91.911245+11.94410
- 20+81.7375320+10.62200
- 100+71.56382100+9.29990
