99 9128 00 08
99 9128 00 08
    BINDER(宾德)
    BINDER - 99 9128 00 08 - Circular Connector, 720 Series, Panel Mount Receptacle, 8 Contacts, Solder ...
99 9128 00 08 数据手册
Product sheet Miniature connectors Female socket, black Snap-in connectors IP 67 Pole Article number serie 720 illustration scale drawing Date: 2013-11-06 - Page 1 of 2 Product Area 8 99 9128 00 08 Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Material Connector Design Female socket Connector locking system Snap-in locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Cable outlet - Upper temperature +85 °C Lower temperature -25 °C Material of contact CuSn (bronce) Contact plating Au (gold) Material of contact body PA (UL 94 V-0) Material of housing PA (UL 94 V-0) Cable data Contacts 8, female socket, black Electrical values Rated voltage 125 V Rated impulse voltage 1500 V Pollution degree 2 Overvoltage category II Material group II Rated current (40°C) 2A Volume resistivity ≤ 3 mΩ EMV compliance not shielded Degree of protection IP 67 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 9128 00 08 Product sheet Miniature connectors Female socket, black Snap-in connectors IP 67 serie 720 Pole Article number Date: 2013-11-06 - Page 2 of 2 Product Area 8 99 9128 00 08 Item description Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 9128 00 08
99 9128 00 08 价格&库存
很抱歉,暂时无法提供与“99 9128 00 08”相匹配的价格&库存,您可以联系我们找货
