Product sheet
Automation technology
Female cable connector, metal locking system, screw termination
M12 connectors A-Coding
serie 713
illustration
Pole
Article number
scale drawing
Date: 2013-07-03 - Page 1 of 2
Product
Area
5
99 0436 14 05
Contact Arrangement
You can find the item description and assembly instruction on the next page.
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
screw
Wire gauge (mm)
0,75 mm²
Wire gauge (AWG)
18
Upper temperature
+85 °C
Lower temperature
-40 °C
Cable data
Rated voltage
125 V
Contacts 5: cable outlet: 4-6 mm, Female
termination
Rated impulse voltage
1500 V
Pollution degree
3
Overvoltage category
II
Material group
II
Rated current (40°C)
4A
Volume resistivity
≤ 8 mΩ
Degree of protection
IP 67
Mechanical operation
> 50 mating cycles
Electrical values
Material of contact
CuZn (brass)
Contact plating
CuSnZn (Optalloy)
Material of contact body
PA
Material of housing
PA
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
99 0436 14 05
Product sheet
serie 713
Pole
Article number
Date: 2013-07-03 - Page 2 of 2
Product
Area
5
99 0436 14 05
Item description
Installation instructions / Mounting cutout
Powered by TCPDF (www.tcpdf.org)
99 0436 14 05
很抱歉,暂时无法提供与“99-0436-14-05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+138.92059
- 10+136.02554
- 50+132.93263
- 100+131.21435
